edowney Samba Member
Posted: Fri Sep 19, 2008 5:45 am Post subject: Mounting a DP1600 to a universal engine stand |
Hi Folks,
I borrowed a universal engine stand from a buddy of mine in order to tear down my engine. It's one of those stands with the extensions that are tightened down in a specific pattern to mount to any engine - hence the universal part I guess. Anyway I read in my how-to-take-a-vw-engine-apart book that you should only bolt the left side so you can split the case when the time comes. When they say left do they mean the side that does not have the nut that is pressed into the case? Thanks! |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80464 Location: Sneaking up behind you
Posted: Fri Sep 19, 2008 5:54 am Post subject: |
First you will need to remove the flywheel to mount it.
Use all 4 bolts since they do not have enough support for a complete engine and can break the "ears" off the case. Strip it down to a short block and then unbolt the two on the #1 / #2 side so you can split the case. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Fri Sep 19, 2008 6:40 am Post subject: |
Yeah, I already stripped it down almost to the block. Fly wheel, Fan shroud, intake manifold, muffler, distributor, sheet metal - all gone. I'm down to removing the heat exchangers which I wanted to wait until it was in the air.
Any idea what type of bolts to use? Can the top two that have the nuts on pressed in (one one side) and the only nut you can get at from the engine compartment be taken out of the tranny? I didn't try taking them out after the engine came out.
Wow, remove the bolts off of the #1, #2 cylinder side, huh? okdoke - that's what I needed to know - thanks! |
Posted: Wed Sep 24, 2008 7:35 am Post subject: |
| Ok, the universal stand doesn't work as-is and because I'm borrowing it from a friend I can't modify it. What is the diameter of the VW bench versions mounting cylinder? I'm wondering if I could buy the VW bench mount version and stick in my universal engine stands dolly. Sound plausible? Thanks! |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Glenn  Mr. 010
Posted: Wed Sep 24, 2008 9:05 am Post subject: |
That's what I have...
Member #1009
#BlueSquare
frank1380 Samba Member
Posted: Wed Sep 24, 2008 10:09 am Post subject: |
| My setup looks exactly like Glenn's. I tried the universal setup but it was too sketchy. I'm borrowing the stand from my father-in-law and he probably wouldn't care if I modified it but with the adapter no modifications were required. |
Posted: Mon Oct 06, 2008 1:46 pm Post subject: |
| Ok, I just got the above listed adapter that Glenn has. According to the directions it looks like they want it mounted to the bottom and top mounting bolts on the distributor side. How do you handle the botton bolt? I didn't look to closely at the case yet - is that bolt a permanent fixature? |
VintageWorldTools Samba Member
Joined: April 07, 2008 Posts: 34 Location: Rogue River, Oregon
Posted: Tue Oct 07, 2008 9:42 pm Post subject: engine stands |
| Just wanted to clarify that both the stands shown are made by me. The photo of the yoke in the red stand is the older version, all now have the gussets. Just haven't found time to take new photos. |
redhot Samba Member
Posted: Wed Oct 08, 2008 12:33 pm Post subject: Re: engine stands |
| VintageWorldTools wrote: |
Hi,
What`s the reason for reinforcing them? Did the old design brake/crack? Wondering since I have one of them.
Great quality part! |
Posted: Sun Oct 12, 2008 8:44 pm Post subject: vwalley/vintageworldtools stands- gussets |
| no problems, the gussets are scrap from making my harley engine stands. just hated to throw the little buggers away, so decided to put them to use on the vw stands. kevin |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20896 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Oct 13, 2008 10:34 am Post subject: |
| edowney wrote: |
Use some oversize nuts or length of steel sleeve to create a space to keep nut on threads of engine case stud...... Do not remove stud unless necessary to save wear on case threads...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
