Just Jake Samba Member
Joined: August 23, 2008 Posts: 143 Location: Southern Oregon
Posted: Tue Oct 07, 2008 11:35 pm Post subject: L74-79 Ignition lock cylinder / ignition switch blues. FAQ |
To link to this thread
| Code: |
| [url=https://www.thesamba.com/vw/forum/viewtopic.php?t=322935&start=0&postdays=0&postorder=asc&highlight=]L74-79 Ignition lock cylinder / ignition switch blues. FAQ[/url] |
btw, the key is stuck in the lock cylinder (yes i've tried it, yes my dad tried it, my wife, friend, and even a locksmith), so the lock cylinder has to go also. and also, I've searched infinitum.
ok, So I have followed this tutorial to a T. (btw thanks randy in maine)
http://www.ratwell.com/mirror/bclausen/How_to_files/IgnSw/index.html
I've also read through this looking for additional info, if you have an older than 75ish bus this tutorial is definitely for you.
http://www.dolgyfre.adsl24.co.uk/spooky/barrel/barrel.html
How do I remove the peening?
My ignition switch is out of the steering lock. This was exactly what my problem was, that ignition switch has trouble turning even sticking a screw driver in it. In other words, it's toast. And in my haste, I cut off the key to remove the housing because the diameter of the key's head was too large to lift the housing over the head of the key.
Now my current dilemma. Although they're blurry bare with me. The Bentley manual designates a place to drill into the steering lock assembly. (consult your own for better clarity if necessary)
Now it doesn't tell you how far you need to drill in, only that you need a 3mm bit, or about 1/8th of an inch. And based on the location of where to drill in the diagram, i would be drilling straight across into nothing but open air, heres a couple pics that better describe what I am having trouble with.
If you follow the diagrams in the Bentley, you drill into nothing. then another piece of cast metal, into nothing again.
So where do I need to drill? Do I even need to get the peening out of the side?
I want this lock cylinder out of there so I can put in the new ignition switch and new lock cylinder so I can be done with this headache!!!!
expletives enunciated!!! Arghhhh!!!!! _________________ If MacGyver only had a Bentley service manual.... |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53181 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Oct 08, 2008 6:13 am Post subject: |
You want to drill at the top end of the left arrow (on the side of the cylinder), the hole needs to be approx 1/8" deep, you'll feel the drill fall in a tiny bit. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
1975 Kombi Samba Member
Joined: August 12, 2007 Posts: 2459 Location: Acton, Ontario, Canada
Posted: Wed Oct 08, 2008 6:25 am Post subject: |
You can put a piece of tape on the bit so that only 1/8" of drill bit is showing. That way you know when to stop. You don't want a lot of pressure on the drill or speed. Just let it drill without pressure so you don't over drill and take your time. SLOW. _________________ Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10804 Location: the past
Posted: Wed Oct 08, 2008 6:32 am Post subject: Re: The lock cylinder / ignition switch blues. |
| Just Jake wrote: |
you don't drill where the arrows are. the arrows are to show the 13mm measurement as to how far down on the housing to drill the hole.
you are essentially drilling the housing so you can have access to the release tab on the ignition lock cylinder. don't drill too fast, and yes, you will feel the drill "drop through" the housing. that is when to stop, because you don't want to drill a hole in the tab. when the hole is drilled, you stick a metal pin or even the drill bit back in the hole, press the tab, and pull the cylinder out.
here's a pic of where to drill the hole. my deepest and most sincere apologies to nigel for the center of the hole being 12mm from the edge (the near edge of the hole is 10.7mm from the housing edge, the far edge of the hole is 13.3mm from the housing edge) and the hole only being 2.6mm in diameter rather than the specified 3mm :
the relation of the drill bit to the housing when drilling :
you can see the release tab on the side of the cylinder:
Posted: Wed Oct 08, 2008 10:41 am Post subject: |
Thank you all for your insight, now this is finally clarified and easily searched for those of us that come across this very issue again.
It's quite the motorfinger. _________________ If MacGyver only had a Bentley service manual.... |
delliott101 Samba Member
Joined: February 22, 2008 Posts: 1315 Location: Caldwell - Lake Lowell ID
Posted: Sat Aug 28, 2010 7:03 am Post subject: |
I checked the two links, but how do you get the mount off of the steering column? It's stuck and the key doesn't turn. '71 Bus _________________ Transplanted Jersey Boy living in Idaho by way of Northern California!
We don't own old VWs, we just take care of them for the next driver |
Posted: Sat Aug 28, 2010 5:03 pm Post subject: |
Well I got it all figured out _________________ Transplanted Jersey Boy living in Idaho by way of Northern California!
