BigBlueVW.blogspot.com Samba Member
Joined: October 04, 2007 Posts: 317 Location: Petaluma, CA
Posted: Thu Oct 16, 2008 7:55 pm Post subject: Setting the timing with a petronix - need help tonight |
Hey all. I'm here helping Marc (of Marc and Eliana) set his timing. He has a pertonix, so the coil is a little different than my bus/bug. If I connect the timing light to the coil, I get a constant light, no matter where the distributor is pointing. I'm a little confused on how to help him with this? Any help? _________________ '56 Bug - no name yet
'63 Bug "Little Blue"
'68 Bus "Big Blue"
Find bus camping friends at http://VWCamperFamily.com/
A west coast VW bus camping adventure at: http://bigbluevw.com/
Interested in VW buses and have a Facebook account? Check out Big Blue's Fan page: http://www.facebook.com/bigbluevw |
Joined: January 01, 2007 Posts: 17949 Location: sticksville, ct.
Posted: Thu Oct 16, 2008 8:10 pm Post subject: Re: Setting the timing with a petronix - need help tonight |
| BigBlueVW.blogspot.com wrote: |
| Hey all. I'm here helping Marc (of Marc and Eliana) set his timing. He has a pertonix, so the coil is a little different than my bus/bug. If I connect the timing light to the coil, I get a constant light, no matter where the distributor is pointing. I'm a little confused on how to help him with this? Any help? |
why are you connecting a t-light to the coil? hook up the light to the battery and the lead to #1 spark plug. there is no mystery to it |
Posted: Thu Oct 16, 2008 8:24 pm Post subject: |
Um. I am using a static light (test light). I'm guessing you are referring to a stobe? Is there a way to set the timing with a static timing light? _________________ '56 Bug - no name yet
'68 Bus "Big Blue"
whc03grady Samba Member
Joined: February 07, 2004 Posts: 337 Location: Livingston Montana
He's not using a strobe, he's timing it statically using a test light. _________________ 1974 Westfalia "Ludwig"
1971 Squareback "Gertie"
Read about their adventures
| blankmange wrote: |
| The Bentley assumes that the car is complete. |
Posted: Thu Oct 16, 2008 8:25 pm Post subject: |
Aarrgh! Beat me to it! I shouldn't've been so fancy with the links.... _________________ 1974 Westfalia "Ludwig"
| blankmange wrote: |
towd Samba Member
Posted: Thu Oct 16, 2008 9:04 pm Post subject: |
| negative side ...aka ,, black wire from the dizzy, not the red |
Posted: Fri Oct 17, 2008 12:04 am Post subject: |
whc03grady - you crack me up.
We went and bought a strobe at the parts store. Worked fine and he is back on his way...
Thanks. _________________ '56 Bug - no name yet
'68 Bus "Big Blue"
roger rabbit Samba Member
Posted: Fri Oct 17, 2008 9:23 am Post subject: |
| You should still be able to use a static test light to time a pertronix equiped distributor. Although the pertronix kit replaces the mechanical points, it still has to create an open circuit same as the points did to cause the magnetic flux created around the coil when there is power to "collapse" resulting in the high voltage output for the spark plugs. I have never tried this on a pertronix equiped distributor but have done it on GM HEI type distributor/coils. I suspect that if you hooked up the test light between the negative terminal on the coil and the black wire on the pertronix that you will see the same effect as with points. I might not be right on how the pertronix is wired, but the pertronix kit still has to do the same thing as mechanical points with regards 12 volts to the coil. |
