VR6 vanagon Samba Member
Joined: October 26, 2008 Posts: 93 Location: New Port Richey Florida
Posted: Sun Oct 26, 2008 7:15 am Post subject: Will Eurovan tranny work in my Vanagon converted to a VR6? |
I have a 1982 Vanagon that I converted to use the motor from my 2000 Jetta that was demolished from the rear. It runs great, I really love it, but am not happy with the RPM's @ 60 or 70 miles an hour.
The shop that did the conversion says they changed third and fourth gear, but it sure doesn't seem like it.
I was wondering if the tranny from a 99 or newer Eurovan would work in my vanagon?
Also, is there any way I can tell if the shop actually changed my tranny gears or not without actually removing the tranny?
Thank you and have a great day! |
the caveman Samba Member
Joined: August 09, 2004 Posts: 885 Location: island state of Montreal
Posted: Sun Oct 26, 2008 7:48 am Post subject: |
| Uh, no. A eurovan is front wheel drive |
suebicum Samba Member
Joined: May 17, 2008 Posts: 173 Location: Richmond, VT
Posted: Sun Oct 26, 2008 8:06 am Post subject: |
Morning
Well, a Eurovan trany can’t fit, you could have seen that by looking at it.
But, you can figure out your gearing. If, you have a tach, you can go from speed and RPM to the gearing. Little math, but a gearing chart/calculator will make that pretty easy.
Don’t forget your tire size and look up the # of your gearbox.
If you got the data, we can help you, figure out the gearing.
Michael _________________ 1986 Vanagon GL Syncro |
fastwagens Samba Member
Joined: March 01, 2004 Posts: 1028 Location: Michigan (The other west coast)
Posted: Mon Oct 27, 2008 3:56 am Post subject: |
| Yes, Increase of your tire size will do wonders. In my vr6 automatic conversion it made all the difference and the vr had no trouble turning over the tires. |
Posted: Mon Oct 27, 2008 12:37 pm Post subject: tranny gearing |
My mechanic was supposed to have changed third and fourth gear, but it sure isn't seeming like he did. At this time I don't have a tachometer, but I will be installing one soon. But in fourth gear, doing about 55 mph. it sounds like it is turning at least 4 thousand rpm's. Seems to me that if he did in fact change third and fourth gear, that it would be turning less rpm's than that. Am I wrong in thinking that?
To install a tach, I am under the impression that I need a universal one for a 6 cylinder, does it hook into the computer? Does anyone know where?
Thank you in advance, any and all input is appreciated.  |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19045 Location: Retired South Florida
Posted: Mon Oct 27, 2008 1:12 pm Post subject: |
| Would a VR6 be ODBII compliant? If so, you can plug a scan gauge into the ODBII two connector to read rpm clear codes etc. I have my connector mounted in the front ashtray for easy access with the Scan Gauge or my VAG-COM. 4000 rpm sounds about right for stock gearing. With my conversion using stock gear box from an 80 aircooled, I was seeing 3500 at 70mph. The taller tires knocked off about 300 rpm at 70. Without a tach you will just be guessing your rpm. My tach is connected to the ECU directly. I have a TDI not a VR6. |
devesvws Samba Member
Joined: January 05, 2004 Posts: 1540 Location: madison va
Posted: Tue Oct 28, 2008 5:22 pm Post subject: |
| Quote: |
| the audi 100/200 works with the the proper mod's |
Well that would be a in line Gearbox.
And if you don’t do a hole lot of work you got 1 forward and 5 reverse
And as far as I remember the Audi Gearbox has the bell/diff housing in one so you have to go with the engine angle the gearbox has or use adaptors ….
Looked into it with my Syncro, it’s a lot of work/money to get it functional.
Ok the Automatic fits, if you couple it with the Vanagon auto differential.
VisPacem Samba Member
Joined: July 15, 2007 Posts: 1143 Location: Las Vegas
Posted: Tue Oct 28, 2008 8:19 pm Post subject: Re: Will Eurovan tranny work in my Vanagon converted to a VR |
| VR6 vanagon wrote: |
Going after the wrong fox.
I just do not comprehend how changing gear ratios on third and fourth, or why not on first and second or even reverse (lol) will/would affect the speed vs rpms in top gear. Having 1, or 10 gears would not change a iota to said ratio.
How about talking of the differential/rear end/final drive ratio ? _________________ LG aka VisPacemPB, *The* party Pooper
No Regrets (Nothing to do with Vanagons) |
Posted: Wed Oct 29, 2008 6:26 am Post subject: Re: Will Eurovan tranny work in my Vanagon converted to a VR |
| VisPacem wrote: |
How about talking of the differential/rear end/final drive ratio ? |
The calculated final drive ratio for highway speeds would include the 4th gear and tire diameter. The only way 4th gear would be removed from the calculation would be if 4th gear ratio is one to one. At this time, there are not many tall ring and pininions available for conversion vanagons. There are taller tire and wheel combinations and some taller 3rd and 4th gears available. With a conversion you need to work with what is readily available in most cases. If you replace only 4th gear with a taller ratio, you could end up with a huge rpm drop on the 3rd 4th shift. The TDI could probably live with it.
From memory, the ring and pinion in an Audi automatic differential can be flipped without modification. You need to pay attention when you rebuild one not to accidentally flip it. Regards |
