Mike1973 Samba Member
Joined: August 05, 2005 Posts: 498 Location: Southampton UK
Posted: Thu Nov 06, 2008 8:15 am Post subject: 30hp engine failure - strip down and evaluation |
Right, I'm an engine numpty here, so could do with some help working out why my faithful old 30hp gave out on me recently, so that -
a - I can fix it back up
b - I don't do the same thing again
It was in the Kombi when I got it in 2004. The Kombi had been stood since 1990. I just did a top end overhaul, changed the oil, plugs, etc... adjusted the valves, statically timed it with a test light off the coil to 7.5˚btdc.
The motor had a little endfloat, and used oil, so I knew it would need rebuilding sooner rather than later, but I got nearly 30mpg and it ran strong. Also, I've done 11,000 miles since getting it back on the road, a lot of them on the motorway at 45-55mph.
Lost power suddenly on motorway at 50mph, pulled over a mile later and died on the hard shoulder. Loss of compression seemed likely, and on inspection once the motor was out No1 had no compression at all. (but only tested by sticking a finger in the sparkplug hole... )
No1 barrel smooth? I thought it would be really scuffed up?
Heavy scoring to the edge of No1 cylinder. All the rings in place, but the piston rings are really bedded in and flush with the piston. Oil ring is still free.
I'm using this manual to help with the rebuild. I do have a Bentley but for later model splits.
Cheers, Mike. _________________ Gaffa Tape Tourist - Touring Europe at 45mph
Editor - Split Screen Scene, the Journal of the SSVC.
My flickr http://www.flickr.com/photos/29051501@N08/
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Thu Nov 06, 2008 8:21 am Post subject: |
Looks like it was running lean and hot and the top of that piston started to burn and once that started it was all over...
Might have been a vaccum leak or jetting... Or you could have used the wrong mark when you set timing only static and did not check distributor and how well it was advancing and what the total degrees of advance was with a light. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Thu Nov 06, 2008 9:55 am Post subject: |
Detonation!
Time for new P+C's, and I would check that head too. Having a look at that cylinder's rod bearing might not be a bad idea either, detonation can pound the crap out of bearings. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| Glenn wrote: |
| satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7542 Location: Whittier,CA
Posted: Thu Nov 06, 2008 11:39 am Post subject: |
Yikes! Was that piston starting to melt or is the white color from something else?  |
SRP1 Samba Member
Posted: Thu Nov 06, 2008 12:19 pm Post subject: |
Lean mixture for sure, the question is what caused it to go lean? Vacuum leak, insufficient fuel supply, or a change of parts used on the engine.
Unless you made a change to the engine just prior to this happening I would say a vacuum leak is the culprit. Generally speaking on an engine with as many miles as appears to be on this one, a lean mixture problem would have come into play a long time ago, so that rules jetting out.
Other things follow a lean mixture like detonation, and high cylinder temps, but you should be able to hear detonation severe enough to have caused this. |
hoghead5150 Samba Member
Posted: Thu Nov 06, 2008 2:24 pm Post subject: |
| how do the rest of the pistons look? is #1 the only one that is like that? might help narrow it down. i agree with detonation causing this, but if all pistons are pretty much the same i would suspect lean conditions or timing. if only #1 is like this, i would suspect vacuum leak. |
The Noof Samba Member
Posted: Thu Nov 06, 2008 2:36 pm Post subject: |
| SRP1 wrote: |
If the man is driving along at 50 mph and the engine squeeks like that,there's no way it's a vacuum leak.The throttle is nearly wide open at 50 mph on a 30 horse.Lean mixture, maybe.Timing issue, probably.Vacuum leak, no way. |
Posted: Thu Nov 06, 2008 3:21 pm Post subject: |
Oh, really? Same exact thing happened to my old roomate's split window on the way back from Pomona, and it most definitely was a vacuum leak. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| Glenn wrote: |
Posted: Thu Nov 06, 2008 3:26 pm Post subject: |
| miniman82 wrote: |
| Oh, really? Same exact thing happened to my old roomate's split window on the way back from Pomona, and it most definitely was a vacuum leak. |
Where was the vacuum leak?Did it idle? |
SRP1 Samba Member
Posted: Thu Nov 06, 2008 3:48 pm Post subject: |
| The Noof wrote: |
| SRP1 wrote: |
Ok all great one, whats your analysis? I don't see anything on here other than a ridiculous statement that makes no sense at all.
By the way, an air leak into the intake system after the carburetor is called a vacuum leak. That leak will lean the fuel mixture across the RPM band regardless of RPM, if the engine was already on the edge as far as jetting is concerned or having fuel supply issues it does not take much to put it over the edge so to speak.
I thought you where a little more knowledgeable than your statement implies, I guess I was wrong.
If what I'm seeing in that picture is correct, that head appears to be
hemi cut. Those are detonation monsters, and power killers at best. It would not take much to push this engine into a lean band of high cylinder temp and detonation. |
Posted: Thu Nov 06, 2008 3:56 pm Post subject: |
It could be a combination of all... what ever it is I have seen it enough times, and so have you guy's to recognize... it ain't pretty... and arguing about EXACTLY what it was is not going to help
But he needs to check for evidence of a vac leak at the intake and make sure the timing is set correct on the rebuild... lest we see him post again in a few thousand miles.  |
Posted: Thu Nov 06, 2008 3:57 pm Post subject: |
| SRP1 wrote: |
| The Noof wrote: |
| SRP1 wrote: |
Sorry...I misunderstood what you where saying:I thought you meant maniifold vacuum (closed throttle/throttle side) leak could cause that damage, rather than above the throttle side.My mistake. |
Posted: Thu Nov 06, 2008 4:02 pm Post subject: |
| The Noof wrote: |
| Sorry...I misunderstood what you where saying: I thought you meant manifold vacuum (closed throttle/throttle side) leak could cause that damage, rather than above the throttle side.My mistake. |
Vacuum leak, as in air getting into the intake from anywhere it cannot be metered by the carb or other metering device, hence causing a lean condition. The leak in my mate's Bus was at the connection between the head and manifold. It melted everything on one cylinder, but suprizingly still run. No power, but it ran.  _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| Glenn wrote: |
Posted: Thu Nov 06, 2008 4:56 pm Post subject: |
Cheers for you expertese fellas, it is much appreciated.
I'm still stripping the motor down, but here are some pics so far.
Pistons 2 and 1. No2 is covered in oil, but No1 is dry in comparrison. I guess it failing would burn the oil off?
And with the head off the other side, 3 and 4.
I removed the manifold 12 months ago to help change the dynamo/fan. Refitted with new gaskets. Not done anything major since. I'm still running the exhaust the bus came with though, which is a bit of a frankenstien affair, with 30hp pipes mated onto a later zorst Might be a candidate for pulling the inlet manifold out of true, making a leak at the heads?
Anyway, because of the endfloat, I want to totally strip the block down, and go through all the bearings. And yes miniman82, the rod for No1 does flap about a bit now
I've been given a set of clean heads that need new valve guides. And I was hoping to get away with just replacing piston rings on the other pistons... whats the score with this? Can you replace just one barrel and piston on a rebuild or is this a no-no? Or do all these barrels and pistons all look worn out? Again, unknown territory for me so forgive my ignorance...  _________________ Gaffa Tape Tourist - Touring Europe at 45mph
My flickr http://www.flickr.com/photos/29051501@N08/ |
Posted: Thu Nov 06, 2008 5:19 pm Post subject: |
You've got it pulled down that far, might as well go all the way. Just think how much your motor will appreciate new bearings and some TLC!  |
Posted: Thu Nov 06, 2008 7:25 pm Post subject: |
| change all pistons and barrels. no since in taking it down that far and just changing one. looking at the pics of the 3&4 pistons, i would say that the problem was a vacuum leak on the 1&2 side. most likely intake gaskets causing the #1 piston to go real lean and #2 looked a little lean also. |
krusher Samba Member
Joined: September 24, 2002 Posts: 7661 Location: europe
Posted: Fri Nov 07, 2008 1:48 am Post subject: |
Some words of warning as its a 30hp rebuild.
Simple parts arnt as easy to get as a 1600.
A set of barrels and pistons is going to be expensive.
The heads arnt semi hemi cut thats whats 30hp combustion chambers look like stock.
Dont have the case line bored or the crank ground until you have the bearing in your hand that are the size your going to go to. If your case is going to its first line bore and the crank to its first grind then those are the hardest bearing sizes to find as that what most people need, and 30hp stuff isnt falling off the shelves like 1600 stuff does.
I would expect you will have to shop online outside the uk to find parts.
You may be able in the Uk to pick up a complete 30hp engine for peanuts as no one wants them. _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
Posted: Fri Nov 07, 2008 3:32 am Post subject: |
Cheers fellas. While I was dragging the bike out of the garage this morning for work I picked the manifold up and had a quick shufti... Holding it up to the light I could see a crack of daylight through the inlet where it fixes to the head, on 1+2 side... I'm hoping it's something that can be repaired....
Krusher is spot about parts supply here in the UK. Difficult to get 25/30hp stuff over here, not much 'off the shelf', and when it is it's usually not cheap I dread to think what a set of new barrels and pistons will cost me, and that will probably knock the rebuild on the head.
I'm always struggling to keep the Kombi on the road as stock as possible, but doing it on a very limited budget. I'd already assumed the best place to get bearings and gaskets would be the States, (from doing the top end rebuild a few years ago) but I'll do the rounds of suppliers and compare prices. KK in the UK and BBT in Belgium are closer suppliers.
Second hand 30hp motors turn up occasionally in the UK, anything from £30 to £250. But then you've got another used, maybe high mileage engine. It may 'run really well', but for how long? I'd love to do my own rebuild and know I've got a solid engine under me. Maybe getting a set of good used barrels and pistons is an option? _________________ Gaffa Tape Tourist - Touring Europe at 45mph
Posted: Fri Nov 07, 2008 10:33 am Post subject: |
Your a brave man to keep on the 30hp road, I used to use my barndoor with a stock 30hp, was great fun on country lanes and pushed the bus along happily at 50mph, but I never took it on the motorway, did not want a lorry smashing into the back of me as i did 30mph up a hill.
Maybe you should look into a vintage performance rebuild for a bit more power.
I was going down that route, even have ported heads on the shelf, but was in search of more power int he end and ditched vintage speed.
These might get you started
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111198057
http://www.wolfsburgwest.com/wolfsburg_new/engine/25-36_hp_engine.cfm _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
cal63look Samba Member
Joined: January 14, 2006 Posts: 1027 Location: Colorado
Posted: Fri Nov 07, 2008 3:02 pm Post subject: |
In your last picture you posted, It looks like the left sparkplug isnt seated all they way? It looks like 3 or so threads left, that could def create some heat. Are those the correct lenght sparkplugs?
Just thowrin that out there |
