White wall inserts on a 135r15???? help
floorsMIA63
floorsMIA63 is offline
PostPosted: Fri Jan 16, 2009 9:49 am    Post subject: White wall inserts on a 135r15???? help Reply with quote
Hey guys, I did some research on the inserts and I found pros and cons, I dont care and I want them, I have 135r15 in the front and 165r15 rears, I called a suppier today and they said the 135's wont work, due to the sidewall being so little, I was wondering if I get like a 3in insert for the rear and 2in in the front maybe it would?? or if anyone has made the insert work on a 135 let me know,the suplier I called today said they have 2 1/2 and it wouldnt work, let me know, thanks., Joel
hutton65
hutton65 is offline
PostPosted: Fri Jan 16, 2009 11:56 am    Post subject: Reply with quote
try cokertire.com. they handle many different sizes of those inserts. If one is available, they probably have it.
jmallen05
jmallen05 is offline
PostPosted: Fri Jan 16, 2009 4:30 pm    Post subject: Reply with quote
I have the 135/165 combo and have 2 1/2 atlas insert. I like them and haven't had any problems except its hard to keep the fronts clean because of the small sidewall. I bought the 3''ers first and were way to big for 135's and I think there to big for 165's too, but I think they'd work.
andk5591
andk5591 is offline
PostPosted: Sat Jan 17, 2009 6:37 am    Post subject: Reply with quote
135s dont exist in a whitewall. Tire paint may be your only option. I'm in the same boat.
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
FEAZYWEAZY
Kusten Kreuzer
FEAZYWEAZY is offline
PostPosted: Sun Jan 18, 2009 8:41 am    Post subject: Reply with quote
135 and 165 set up. no problems here. like jmallen05 said the front are hard to keep clean. jmallen05, are you getting that dark ring on the outside too? have you found anything that cleans it?
www.KUSTENKREUZERS.com
rontof
rontof is offline
PostPosted: Sun Jan 18, 2009 2:56 pm    Post subject: whitewall inserts Reply with quote
Where would you go to get a good set for a 165? How much?
I'm in Phoenix AZ area.
Thanks
Ron
58 rag
72 bug
FEAZYWEAZY
Kusten Kreuzer
PostPosted: Sun Jan 18, 2009 3:14 pm    Post subject: Re: whitewall inserts Reply with quote
Thanks
Ron
58 rag
72 bug
try the classifieds here on TheSamba. look up atlas or portawall. 165 doesnt matter. just the diameter wheel. 14,15,16 etc.
HerrrKafer
HerrrKafer is offline
PostPosted: Mon Jan 19, 2009 2:37 am    Post subject: Reply with quote
Have you tried Westley's Bleche-Wite? This stuff was designed for keeping whitewalls clean and it is NASTY powerful. Read the warning on the back. You'll want to wear gloves. Shocked
Evan H.
In a perfect world, anyone running chromies would be shot.
Kuncle
I am Kyle Deese
Kuncle is offline
PostPosted: Mon Jan 19, 2009 3:19 am    Post subject: Reply with quote
x2 thats how hard core stuff.. it does its job.
Ost Kuste.
eguti66
eguti66 is offline
PostPosted: Mon Jan 19, 2009 8:53 am    Post subject: Re: whitewall inserts Reply with quote
Thanks
Ron
58 rag
72 bug
Here you go
https://www.mooneyesusa.com/Store/product_info.php...c0478a78f9
drscope wrote:
Ummmm, if you can't find out where the hole is by feeling around, then FORGET about installing the light!
66 beetle
65 karmann ghia
58 beetle
58 convertible beetle
64 11w standard
68 Squareback
