ram air intake
bluebug79
bluebug79 is offline
PostPosted: Fri Jan 23, 2009 11:54 pm    Post subject: ram air intake Reply with quote
are these type of intakes beneficial to vw carbureted aircooled engines ,specifically a single carb?
Eaallred
Eaallred is offline
PostPosted: Sat Jan 24, 2009 10:12 am    Post subject: Reply with quote
From what i've read, "Ram air" intake systems only start working once you hit around 100mph.
I don't think it would be worth the fabrication on a street car.
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
michael1968
michael1968 is offline
PostPosted: Sun Jan 25, 2009 2:32 am    Post subject: Reply with quote
Actully getting pressuried air into your carb from an intake system can be hard work but there is a definate bonus from running a cold air intake (as long as it's not freezing out side). Power can drop about 1% for every 7 degrees C rise in temp.
Eaallred
Eaallred is offline
PostPosted: Sun Jan 25, 2009 10:02 am    Post subject: Reply with quote
True, but with all the stock cooling tin and seals in place, the upper engine bay is ambient air temp. Bone stock VW's in that sense, are all ready "cold air" intake if you disconnect the hot air tube.
That's all? Thats 44.6 degrees farenheit. Doesn't seem like much worth the effort either. That would be 2 hp on a 200hp car if for some reason it was pulling in 115 degree air into the intakes on a 70 degree day. Datalogging my car at the track (back end cut open, air recirculates around pretty bad), I was pulling in 106 degree air on a 70 degree day and was thinking on the best way to modify the intake to pull in cool air. Maybe I won't worry about that too much either. It would make about 2hp difference on my car, I can make that much power somewhere else easier and cheaper mabye. I'll have to look into it further.
Eric Allred
fastinradford
fastinradford is offline
PostPosted: Sun Jan 25, 2009 6:00 pm    Post subject: Reply with quote
In theory, but have you ever put your hand in there after driving around town on a 100F day?
Eaallred
Eaallred is offline
PostPosted: Sun Jan 25, 2009 6:04 pm    Post subject: Reply with quote
No, but I've driven around with a remote BBQ thermometer in the engine bay to watch the temp. Wink
With all the seals and tin in place (everything like it should), I read the same temp in the upper engine bay as I do the thermometer hanging out the wing-window.
That's how I check my street VW's to see if I'm recirculating hot air or not. You should be within a degree or two. If not, start checking for gaps and also check to see what your engine bay vacuum is.
Eric Allred
michael1968
PostPosted: Mon Jan 26, 2009 12:13 am    Post subject: Reply with quote
You're right, if you're engine tin is all sealed up the engine bay in a bug wont be much hotter than outside. I guess it's different on a WC car with the intake behind the rad.
1% isn't much but if you're searching for that last bit of power it could be worth while.
bluebug79
PostPosted: Mon Jan 26, 2009 3:24 am    Post subject: warm air intakes Reply with quote
http://www.osintakes.com/
what are your thoughts about this link?
Eaallred
Eaallred is offline
PostPosted: Mon Jan 26, 2009 7:23 am    Post subject: Re: warm air intakes Reply with quote
Looks like someone with good intentions, but doesn't understand what he's doing IMHO. It's no more "cold air" than the stock system.
Eric Allred
Viande
Viande is offline
PostPosted: Mon Jan 26, 2009 7:37 am    Post subject: Reply with quote
In my opinion on a type 1 it is a waste of money. The cooling fan and carburetor are pulling in fresh air constantly and exhausting them out and under the rear of the vehicle. This is a completely different setup from your typical automobile. These have a radiator and ac condenser mounted ahead of the engine which exhausts its heated air directly on the engine.
Bobby
New Items In Stock, NOS & OEM Seals,Parts and Terminals
My Feedback Here
The bitter taste of poor quality lingers long after the joy of the cheap price fades away.
Eaallred
Eaallred is offline
PostPosted: Mon Jan 26, 2009 7:55 am    Post subject: Reply with quote
Exactly right.
Eric Allred
ALB
ALB is offline
PostPosted: Mon Jan 26, 2009 8:09 am    Post subject: Reply with quote
Looked at the osintakes site. I emailed him asking for any data to substantiate his claims. I'll let you guys know if i get anything back.
And to think all this time there's been 12+ hp right there and it was that simple! Surprised Wink
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
Stripped66
Stripped66 is offline
PostPosted: Mon Jan 26, 2009 8:32 am    Post subject: Reply with quote
It looks like his "lime green COLD AIR intake" is placing the filter right into the stream of the waste cooling air from the head and cylinders (which would be hot air Laughing ).
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
Viande
Viande is offline
PostPosted: Mon Jan 26, 2009 8:45 am    Post subject: Reply with quote
To be less than kind it would appear the guy is clueless. Laughing
But for every shiny or brightly colored lollipop there is a potential sucker.
Bobby
My Feedback Here
Stripped66
PostPosted: Mon Jan 26, 2009 8:51 am    Post subject: Reply with quote
I've got vinyl stickers with more HP potential than that intake set-up... Laughing
Scott Novak
Scott Novak is offline
PostPosted: Mon Jan 26, 2009 10:27 am    Post subject: Reply with quote
The bigger problem is getting enough air into the engine compartment so that the fan isn't robbing air from the carbs. Using a deck lid with more louvers or propping open the deck lid may help.
Scott Novak
Eaallred
Eaallred is offline
PostPosted: Mon Jan 26, 2009 12:16 pm    Post subject: Reply with quote
Scott Novak
That is true.
My testing has shown that engine bay vacuum is a major issue with these cars. Primarily due to the fact that most VW's out there are running engines/cooling systems larger than what came in the car.
Relieving that vacuum in a way that does not promote recirculating of the hot air from underneath has shown much larger differences in engine operating temps than anything else I have tested.
Eric Allred
gerico
gerico is offline
PostPosted: Mon Jan 26, 2009 5:48 pm    Post subject: Reply with quote
Eric,
How do you measure engine bay vacuum? Is it low enough even at high speeds to register on a vacuum meter?
`70 street Ghia, 2276 NA
Thanks to:
Darren at DRD Racing
Jason at VW Paradise
Bill at Shear Speed
Kevin at KCR trans
Cuog
Cuog is offline
PostPosted: Mon Jan 26, 2009 6:57 pm    Post subject: Reply with quote
You might be able to get some extra HP, but you have to look at is it worth it. From what I've seen on various vehicles at standard speeds you're looking at a maybe 5hp max increase, and is that max potential really worth the work? Also you'd need to look at where you get the most pressure on the vehicle to take your "ram air" from. its alot a of work with very little return.
Although if you want cool/uniqueness points, I say go for it.
Bashr52
Bashr52 is offline
PostPosted: Mon Jan 26, 2009 7:35 pm    Post subject: Re: warm air intakes Reply with quote
You definitely know this is a high performance part as they come in a variety of colors (Red, Blue, Green, Yellow, Silver, Natural Metal Clear, Lime Green, Orange or Gold).
Nice Laughing
