Shorter Manifolds for Weber 40 IDF Carb?
thefladge
thefladge is offline
PostPosted: Thu Feb 26, 2009 5:24 pm    Post subject: Shorter Manifolds for Weber 40 IDF Carb? Reply with quote
Hey everyone.
I'm wondering if anyone knows of some short manifolds for Webers that will clear a Doghouse shroud. Why? The rear bumper cage for my Baja passes VERY close over the tops of my air cleaners. It makes it difficult to sync the carbs with the bumper installed.
I've seen really short ones for Type 3 engines, but I don't know if they would work on my Type 1 engine.
1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate.
Teeroy Premium Member
Teeroy is offline
PostPosted: Thu Feb 26, 2009 5:28 pm    Post subject: Shorter Manifolds for Weber 40 IDF Carb? Reply with quote
The type 3 intakes should be fine, you will need longer down links for your linkage though
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
Type 5 Joe
Banned
Type 5 Joe is offline
PostPosted: Thu Feb 26, 2009 5:29 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=742616
thefladge
PostPosted: Thu Feb 26, 2009 5:35 pm    Post subject: Reply with quote
Yikes! Berg prices!
Viande
Viande is offline
PostPosted: Thu Feb 26, 2009 6:10 pm    Post subject: Reply with quote
See there ya go again recommending a quality part. These guys want their parts made by a 3 dollar a day Chinese worker. They want cheap at any cost.
Bobby
New Items In Stock, NOS & OEM Seals,Parts and Terminals
My Feedback Here
The bitter taste of poor quality lingers long after the joy of the cheap price fades away.
thefladge
PostPosted: Thu Feb 26, 2009 6:26 pm    Post subject: Reply with quote
As you can see, I do have numerous Gene Berg parts on my engine. $150 seems a bit steep for a pair manifolds in my opinion.
Type 5 Joe
Banned
PostPosted: Thu Feb 26, 2009 6:32 pm    Post subject: Reply with quote
I have a used pair of the GB 580's ported to 45mm good condition for $110.00 shipped.
- Joe
thefladge
PostPosted: Thu Feb 26, 2009 6:56 pm    Post subject: Reply with quote
- Joe
I've got 40 IDFs.
Type 5 Joe
Banned
PostPosted: Thu Feb 26, 2009 7:02 pm    Post subject: Reply with quote
There are alot of folks running 48mm manifolds with 36's and 40's.
That is what you get with almost anybody else selling manifolds... Including the Type III style.
Some have said it actually helps with the effects of reversion in the intake system.
DarthWeber
DarthWeber is offline
PostPosted: Thu Feb 26, 2009 7:58 pm    Post subject: Reply with quote
X2! Rolling Eyes
Scott Novak
Scott Novak is offline
PostPosted: Thu Feb 26, 2009 8:05 pm    Post subject: Reply with quote
With Berg IDF intake manifolds there is very little clearance between the fuel enrichment block off plate and the fan shroud. You may or may not need to manipulate the fan shroud with a hammer to fit. You may also need to offset the air cleaners to clear the fan shroud. The fit will vary depending on the angle of the intake manifold seating surface on the heads.
Berg IDF intake manifold do have actual 40 mm diameter inlets to mate with the carbs.
Scott Novak
1procrastinator
1procrastinator is offline
PostPosted: Thu Feb 26, 2009 8:22 pm    Post subject: Shorter manifolds for weber 40 IDF carbs? Reply with quote
Might be easier to modify the rear bumper cage for more clearance.
Type 5 Joe
Banned
PostPosted: Thu Feb 26, 2009 8:24 pm    Post subject: Reply with quote
- And the ability to run a thermostat.....
pdub
pdub is offline
PostPosted: Thu Feb 26, 2009 8:50 pm    Post subject: Reply with quote
I have the exact same problem on my baja. I'm going to buy 2 3/4" filter elements next time instead of the 3 1/4" like we both currently have.
Scott Novak
PostPosted: Thu Feb 26, 2009 9:07 pm    Post subject: Reply with quote
The Berg intake manifolds sit somewhere between 1" and 1.5" lower than most other intake manifolds. You can fit a 3-1/4" tall x 4-1/2" wide x 7" long K&N air filter inside a Beetle Sedan engine compartment and still close the lid.
Scott Novak
Ken Taber
Ken Taber is offline
PostPosted: Fri Feb 27, 2009 11:23 am    Post subject: type 3 manifolds on type 1 Reply with quote
You will be plesently supprised how good the type 3 manifolds work one a type 1 with doghouse. I use CB's . I am in the process of casting one like the type 3 but it will flow much better and you will be able to make the ports as big as you want.
Ken Taber
madmike
madmike is offline
PostPosted: Fri Feb 27, 2009 1:47 pm    Post subject: Reply with quote
like 1pro said , some quick release pins and you out maybe 20 bucks??
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
thefladge
PostPosted: Fri Feb 27, 2009 6:41 pm    Post subject: Re: type 3 manifolds on type 1 Reply with quote
Are these the ones?
http://www.cbperformance.com/catalog.asp?ProductID=532
3170 Manifold - Dual 36, 40, 44, & 45mm DRLA & IDF - Dual Port T-3
$69.95
