iowa vw Samba Member
Joined: November 08, 2006 Posts: 588 Location: Los Angeles, CA 90036
Posted: Fri Dec 11, 2020 10:24 pm Post subject: Re: Fog Light Fest |
First off, I love all of the ways you have found to install the fog lights.
In the front I wired the low watt filament into the blinkers to everyone can see me turning during the day and night, lol. The high filament is wired into the low beam of the head lights.
In the back I have the 3rd brake light with both filaments wired into the brakes. There is no way someone can miss my brake lights. Every now and then I see the people behind me putting up their hand trying to block the brightness of my brakes. I also wired in a reverse light so I can also see everything behind me.
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2009 Location: Texas
Posted: Sat Dec 12, 2020 8:46 am Post subject: Re: Fog Light Fest |
I love the placement of the front fog lights. Can you share a picture of the back of them and the brackets used? Thanks! _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Posted: Sat Dec 12, 2020 9:14 pm Post subject: Re: Fog Light Fest |
Quote: |
I love the placement of the front fog lights. Can you share a picture of the back of them and the brackets used? Thanks! |
Here are a couple of how I mounted and wired.
Posted: Sat Dec 12, 2020 9:38 pm Post subject: Re: Fog Light Fest |
Thank you! _________________ .
a.marscapone Samba Member
Joined: May 08, 2017 Posts: 107 Location: The Quiet Corner, CT
Posted: Sat Dec 26, 2020 7:56 am Post subject: Re: Fog Light Fest |
iowa vw wrote: |
Iowa VW I’ve been wanting to do something similar with my fog lights in the front. That is, wire them into my directionals and parking lights. Do your fog lights have dual filament bulbs? Any more details on how you wired them? Thank you, your car is absolutely beautiful! _________________ 73 Westy
67 Zenith Blue Beetle Sedan
73 Beetle Sedan
67 Lotus White Beetle Sedan - current |
vintage water Samba Member
Joined: September 17, 2020 Posts: 65 Location: CONCARNEAU
Posted: Mon Dec 28, 2020 7:48 am Post subject: Re: Fog Light Fest |
hi !
mine !
Posted: Sun Jan 10, 2021 9:32 pm Post subject: Re: Fog Light Fest |
Quote: |
Iowa VW I’ve been wanting to do something similar with my fog lights in the front. That is, wire them into my directionals and parking lights. Do your fog lights have dual filament bulbs? Any more details on how you wired them? Thank you, your car is absolutely beautiful! |
The front fog lights are dual filament, I got them from Air-cooled Accessories. I did a complete custom wiring and upgraded to 12v so if you're running stock better check the gauge wire is large enough for the bulbs. I ran a jumper wire from the blinkers to each bulb to 1 of the filaments. Then the low beam is connected to the other filament on the fog lights. Some day when I'm bored I might change it to power the 2nd filament with the parking lights so the fog lights are always on but I find with the low beam headlights and fog lamps on there is great lighting of the road and rarely use high beam.
https://www.aircooledaccessories.com/ |
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24171 Location: Southeast USA
Posted: Wed Jan 20, 2021 8:22 pm Post subject: Re: Fog Light Fest |
Since I'm not running a manual choke, I replaced the choke knob with an early wiper switch for the foglights. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
Posted: Sat Feb 20, 2021 12:55 pm Post subject: Re: Fog Light Fest |
iowa vw wrote: |
This is awesome, I am so on it... thank you! _________________ 73 Westy
73 Beetle Sedan
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1784 Location: Santa Rosa, Ca
Posted: Fri Mar 26, 2021 4:41 pm Post subject: Re: Fog Light Fest |
Installed some Fog Lamps today,still need to install a relay and wire in a HD switch. Any tips on how to properly wire in the switch and relay? Thanks
SparksLP Samba Member
Posted: Fri Mar 26, 2021 7:41 pm Post subject: Re: Fog Light Fest |
Anyone have pictures of foglights mounted without bumpers on a Bug? I assume a custom bracket is needed for that? _________________ Tom
1966 VW Beetle Sunroof Sedan |
Pez Samba Member
Joined: September 16, 2003 Posts: 583 Location: Texarkana
Posted: Sat Apr 17, 2021 6:23 am Post subject: Re: Fog Light Fest |
SparksLP wrote: |
Anyone have pictures of foglights mounted without bumpers on a Bug? I assume a custom bracket is needed for that? |
When I was younger I ran T-bar bumpers and had installed motorcycle turnsignal housings in them. Could use the same method with fog lamps?
Otherwise may go through the body work like this old rally car. Can't imagine how wrecked that hood was though
_________________ Always chasing Squirrel's. |
Posted: Sun Apr 18, 2021 7:28 am Post subject: Re: Fog Light Fest |
Pez wrote: |
I figured I'd have to modify a bumper mount or something, haven't seen anything aftermarket. I don't want to drill holes in my hood, lol. _________________ Tom
PuddleRainbow Samba Member
Joined: April 13, 2018 Posts: 288 Location: The Dirtiest Of Jersey
Posted: Mon Apr 19, 2021 6:34 am Post subject: Re: Fog Light Fest |
reedwesd Samba Member
Joined: August 28, 2004 Posts: 144 Location: G-Town KY
Posted: Sat Sep 11, 2021 5:31 am Post subject: Re: Fog Light Fest |
stale air Samba Member
Joined: August 23, 2007 Posts: 5157 Location: Senoia Ga, formally NorCal
Posted: Sat Sep 09, 2023 8:37 am Post subject: Re: Fog Light Fest |
_________________ WANTED: Henry Veale Santa Rosa plate frames
b-rem Samba Member
Joined: January 19, 2008 Posts: 28 Location: Toulouse , France
indianpeaksjoe Samba Member
Posted: Wed Oct 18, 2023 7:58 pm Post subject: Re: Fog Light Fest |
I added Hella valuefit lights to my 66 Baja.
They are controlled via an S-Pod attached to a radio blank.
Then I had a local river boat shop make a light bar for the front out of aluminum.
-Joe |
EverettB Administrator
Joined: April 11, 2000 Posts: 69838 Location: Phoenix Metro
racecougar Samba Member
Joined: July 31, 2023 Posts: 107 Location: Imperial, MO
Posted: Wed Oct 25, 2023 9:20 am Post subject: Re: Fog Light Fest |
I just placed my fog lights up on the new roof rack:
