PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Wed Jun 17, 2009 8:53 pm Post subject: Anyone Use An Adjustable Voltage Regulator? |
Does anyone know where to get an adjustable voltage regulator for the Bosch alternators as mentioned in this post?
http://www.thesamba.com/vw/forum/viewtopic.php?t=267379
If you use one, any problems with it?
Thanks! _________________ 89 Westy 2.1 Auto
tikiman71 Samba Member
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10365 Location: Orbiting San Diego
Posted: Wed Jun 17, 2009 9:28 pm Post subject: Re: Bosch Adjustable Voltage Regulator? |
They can be found on Ebay for $20 including shipping.
Search for "Bosch VW Voltage Regulator" and one of the ebay stores has them.
Mark
Posted: Wed Jun 17, 2009 9:53 pm Post subject: |
Thanks. The one from Dave Barton is a remote mounted unit. There is one that mounts on the alternator and has an adjustment screw.
Has anyone ever used one of these or similar units? _________________ 89 Westy 2.1 Auto
Posted: Wed Jun 17, 2009 10:02 pm Post subject: |
That looks like a good deal. A similar (if not the same) one is further down on the DB site for $32 without shipping. Thanks for the tip! _________________ 1987 Westfalia GL |
scottjk Samba Member
Joined: May 31, 2006 Posts: 485 Location: Salt Lake City, UT
Posted: Wed Jun 17, 2009 10:26 pm Post subject: Now I'm Wondering.... |
You guys have me wondering about my charging system. I purchased a rebuilt alternator a few years back. Never seems to fully top off my Optima Yellow Top.
Can someone run me through the tests I need to do to check my system? I also would like to figure out if there is a draw on the system with my key off.
Thanks
Scott |
Posted: Wed Jun 17, 2009 10:26 pm Post subject: |
Both the ebay item and the Dave Barton internal regulator have the Bosch part number 1-197-311-021 listed in their respective gargantuan cross reference parts list. I'm pretty sure either one would work fine... _________________ 1987 Westfalia GL |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Thu Jun 18, 2009 5:27 am Post subject: Re: Now I'm Wondering.... |
scottjk wrote: |
Can someone run me through the tests I need to do to check my system? I also would like to figure out if there is a draw on the system with my key off. |
Download this file. It is a good multimeter instruction manual and it has a step by step instructions to do the test.
http://www.westfalia.gomez-perales.com/Documents/Actron%20Multimeter.pdf _________________ -- 1987 Westfalia automatic (Captain Vino) |
Posted: Thu Jun 18, 2009 5:30 am Post subject: Link not working |
Nvmd, it worked with Firefox for some reason.
Scott |
Posted: Thu Jun 18, 2009 5:43 am Post subject: Re: Link not working |
scottjk wrote: |
Scott |
I just fixed the link. Sorry, my bad. It works now. _________________ -- 1987 Westfalia automatic (Captain Vino) |
Posted: Thu Jun 18, 2009 5:49 am Post subject: |
That should be the case, since the internal one from Dave and the one from Ebay are the same brand in the same boxes. -373A version
Mark
tikiman71 wrote: |
Both the ebay item and the Dave Barton internal regulator have the Bosch part number 1-197-311-021 listed in their respective gargantuan cross reference parts list. I'm pretty sure either one would work fine... |
Posted: Thu Jun 18, 2009 10:33 am Post subject: Re: Now I'm Wondering.... |
scottjk wrote: |
Thanks
Scott |
Take a look at this. Sounds like the same problem.
http://articles.mbz.org/electric/regulator/ _________________ 89 Westy 2.1 Auto |
Posted: Tue Jul 14, 2009 3:10 pm Post subject: |
**Update 7-14-09**
I ordered the adjustable voltage regulator from a vendor on Ebay and I installed it this weekend. Everything worked out great. It came set at 14.2 volts output and I adjusted it to 14.5 volts after I installed it. It took five minutes to install. Simply unscrew the old regulator from the back of the alternator put in the new one being careful with the spring loaded brushes. It has a small opening in the back with an adjustment screw.
Now with the engine running and the lights and heater on, I have 14.2 volts at my batteries. This will be enough to keep them topped of for peak performance. I previously had 13.7 volts at the batteries. This would be good for people who have AGM batteries which need a slightly higher charging voltage as mentioned in the previous post. I'll definitely keep this updated if I run into any problems.
Here's the link again.
http://cgi.ebay.com/ebaymotors/Voltage-Regulator-B...ccessories _________________ 89 Westy 2.1 Auto |
markz2004 Samba Member
Joined: November 13, 2007 Posts: 947 Location: Portland, OR
Posted: Sun Mar 04, 2012 9:57 pm Post subject: |
I recently installed an adjustable regulator as well. I adjusted it to get 14.1 at the battery bank. After a short test run the volts dropped. Presumably because the batteries no longer needed the juice.
What voltage should I target given a full battery? 14.2? If that is the case I should go back and readjust ..
Thanks
Mark _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
pablovent Samba Member
Posted: Sun May 27, 2012 8:15 pm Post subject: |
markz2004 wrote: |
Thanks
Mark |
Hi markz2004, you installed bosch adjustable regulator??....where buy this product??
regards. |
gl98115 Samba Member
Joined: April 22, 2011 Posts: 263 Location: Seattle, WA
Posted: Mon May 28, 2012 7:25 am Post subject: |
You have type4 bosch alternator installed? |
Cygnus Samba Member
Posted: Mon Jun 04, 2012 2:24 pm Post subject: |
Is that last listed one workable - (The Drdepner one)? The earlier ebay links don't work. The last one doesn't list a Bosch part number 1-197-311-021 in their table. Just wondering if anyone can verify compatibility.
Thanks,
-Brian _________________ '86 Syncro Timbertech Hightop "Cygnus" |
Posted: Mon Jun 04, 2012 2:50 pm Post subject: |
They sell various ones and the fine print shows the differences. For wbx 90 amp alternators I'm pretty sure you need 28mm, with NO resistor.
http://www.ebay.com/itm/Voltage-Regulator-Bosch-Au...35a363b271
Mark
bserret wrote: |
Thanks,
-Brian |
