Making a little more room
Alaric.H
Alaric.H is offline
PostPosted: Tue Aug 04, 2009 6:42 pm    Post subject: Making a little more room Reply with quote
I got tired of the drain hose under the sink aways getting in the way so I rerouted it so now I can put 2 shelves in.
markz2004
markz2004 is offline
PostPosted: Tue Aug 04, 2009 7:53 pm    Post subject: Reply with quote
interesting 90-degree angle from the sink. Where did you get it?
87 Westy, 250k GW 2.4 - 2.0 Wink, 16" wheels
madspaniard
madspaniard is offline
PostPosted: Tue Aug 04, 2009 10:08 pm    Post subject: Reply with quote
very nice Alaric, we need details, yeah, what is that 90 degree angle?
Sodo
Sodo is offline
PostPosted: Tue Aug 04, 2009 11:25 pm    Post subject: Reply with quote
Yes this is a great idea please more details!
....KTMs, GasGas, SPOT mtb
Alaric.H
Alaric.H is offline
PostPosted: Wed Aug 05, 2009 4:27 am    Post subject: Reply with quote
I am not so great at details after I do it I lose interest and go on to the next thing I was just cleaning the cabinet out and thought that hose it a pain and started driving to the plumbing store found a sink drain kit 2inch cut out but in the end you can use the stock 90 the new one is just a little shorter the plan was to find a really low profile drain to be able to use the rest of the drawer http://www.pyacht.com/scandvik-drains.htm
but even this is not low enough so I glued a 3/4 barb reducer to the 90 in the kit drilled a hole near the bottom and put a 90 at the hole to lower the line with a thru hull thingy I made and I cut a channel on the bottom of the floor to go lower but you can not see it. Wow my write ups suck sorry.
jackbombay
jackbombay is offline
PostPosted: Wed Aug 05, 2009 6:44 am    Post subject: Reply with quote
Nice mod to the drain line!
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies Smile
Samba ad here.
DIY artificial rain gutters (ARGs)
Alaric.H
Alaric.H is offline
PostPosted: Wed Aug 05, 2009 11:19 am    Post subject: Reply with quote
Phase 2
spitsnrovers
spitsnrovers is offline
PostPosted: Wed Aug 05, 2009 6:02 pm    Post subject: Reply with quote
wow Alaric - hope you have stronger than average hatch struts. Wink
but a neat out of the way hidey-hole.
'88 VW Westfalia
'75 Triumph Spitfire 1500
Alaric.H
Alaric.H is offline
PostPosted: Fri Sep 04, 2009 8:53 am    Post subject: Reply with quote
I found this quick release pop rivets to hold the hatch cover on and I have had no problems it takes about 45 seconds to accesses it.
The westy has the panel without the holes so you will need to find one from a 7 passenger.
Steelhead
Steelhead is offline
PostPosted: Fri Sep 04, 2009 9:41 am    Post subject: Reply with quote
clever.
'77 Bay Window / '89 Caratsburg (aka. the Stormtrooper)
stormforge
stormforge is offline
PostPosted: Fri Sep 04, 2009 11:03 am    Post subject: Reply with quote
Can you give us a source for those quick-release rivets? Do they fit nicely into the existing holes?
Cheers,
-Bill
'89 Syncro
Alaric.H
Alaric.H is offline
PostPosted: Fri Sep 04, 2009 12:17 pm    Post subject: Reply with quote
Cheers,
-Bill
'89 Syncro
facia retainers black
GM products A body 1983 on
794-0704 L.S.P products
I just nipped the tangs on a sander a little to be able to take them off faster. they fit perfect.
stormforge
PostPosted: Fri Sep 04, 2009 12:19 pm    Post subject: Reply with quote
Thanks Alaric! I need to totally replace that back panel and that will be perfect!
Cheers,
-Bill
'89 Syncro
faretheewell
faretheewell is offline
PostPosted: Mon Oct 05, 2009 6:42 am    Post subject: Reply with quote
does the upper part of the sink drain unscrew from the metal sink? I tried briefly and its stuck on pretty good. I wanted to ask the forum before herkin' on it and breaking something...(like i usually do.) Mad thanks
'84 2.3L Wolfsburg Westy - "Brown Sugar"
'72 1700 cc Baywindow 'Tatonka'
Dogpilot
Dogpilot is offline
PostPosted: Mon Oct 05, 2009 6:45 am    Post subject: Reply with quote
You can stick something like a pair of needle nose pliers into the X in the drain. This allows you to twist the top and the bottom. It can be stiff.
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
Alaric.H
Alaric.H is offline
PostPosted: Tue Dec 22, 2009 4:25 pm    Post subject: Reply with quote
To make a little more room I bought some new towels I tried them at home and they seem fine I can put 4 in the space of one.
http://www.rockcreek.com/aquis-adventure/microfiber-towel/?ref=RCO_googlebase
madspaniard
PostPosted: Tue Dec 22, 2009 5:43 pm    Post subject: Re: Making a little more room Reply with quote
Alaric,
yesterday I bought some tubing to this same thing, thanks for the idea
Alaric.H
Alaric.H is offline
PostPosted: Tue Dec 22, 2009 8:48 pm    Post subject: Reply with quote
Here is another way to save one spice bottle with 6 spices.
Alaric.H
Alaric.H is offline
PostPosted: Mon Jan 11, 2010 6:15 am    Post subject: Reply with quote
I found a socket set that can save room because the sockets are deep&shallow so That gets rid of a lot of sockets.
http://www.costco.com/Browse/Product.aspx?Prodid=1...1&s=1#
Alaric.H
Alaric.H is offline
PostPosted: Thu Feb 04, 2010 4:59 am    Post subject: Reply with quote
I have 4 spoons 4 forks 4 knives 12 all together I have cut that down a bit making more room in my drawer.
http://www.campfour.co.uk/1688/products/LightMyFire_Spork.aspx
