Gray cabinet building tips
J_Westy
J_Westy is offline
PostPosted: Mon Sep 14, 2009 5:59 pm    Post subject: Gray cabinet building tips Reply with quote
I'd like to build a closet something like this one behind the driver's seat in this picture for our '02 EVWK.
Does anyone have any good tips? Steve at eurocampers.com advised that the camper books say to build it in place which seems like a good idea.
So far I've seen this gray / grey laminate and T-molding from GoWesty.
The laminate is pretty $pendy which is unappealing. Anybody know a source for a cheaper T-molding?
I found this latch via this EVC'ers site showing his modifications: http://homepage.mac.com/msiminoff/PhotoAlbum38.html
Southco M1-82 (anybody know a source?)
I came across this iron-on melamine. Anybody have an idea about toughness/durability? The price is certainly better than GoWesty's laminate.
Thanks in advance for any ideas.
Jeff
izzydog
izzydog is offline
PostPosted: Mon Sep 14, 2009 8:54 pm    Post subject: Reply with quote
There was a thread recently about the color # for the Westy laminate. Someone had posted the exact matching color and gotten it from a countertop place. Search for "laminate" and see what comes up.
J_Westy
J_Westy is offline
PostPosted: Tue Sep 15, 2009 4:40 am    Post subject: Reply with quote
Thanks for the tip, but I'm not finding it... anybody have it bookmarked or something?
otiswesty
otiswesty is offline
PostPosted: Tue Sep 15, 2009 8:48 am    Post subject: Reply with quote
Pionite F39 SG204 N Mercury
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...;start=120
http://www.thesamba.com/vw/forum/viewtopic.php?p=3859027&highlight=#3859027
1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy
J_Westy
J_Westy is offline
PostPosted: Tue Sep 15, 2009 9:27 am    Post subject: Reply with quote
Thanks! Called around and you can get that Pionite brand in 3', 4', 5' widths and 8', 10', 12' lengths.
The dark grey stuff from Reimo looks like what I was wanting... I'll have to see if a colleague from Germany could get some for me, or maybe try Steve at eurocampers.com
Some of the handles look interesting too:
timiskander
timiskander is offline
PostPosted: Tue Sep 15, 2009 9:31 am    Post subject: Reply with quote
I don't know what prices you have for t molding, but www.t-molding.com has quite a selection. They come from video game land, but its still t-molding
cheers
/Tim
I didn’t do it. No one saw me do it. No one can prove anything. -- Bart Simpson
Sir Sam
Sir Sam is offline
PostPosted: Tue Sep 15, 2009 11:06 am    Post subject: Reply with quote
[quote="J_Westy"]
Awesome! That handle looks like a direct replacement for the handles we have.
I am down a couple and haven't found a replacement source for them yet.
'91 Carat Westy
87' Syncro + '87 Westy conversion coming soon
markz2004
markz2004 is offline
PostPosted: Tue Sep 15, 2009 11:28 am    Post subject: Reply with quote
Can you give us a link to your handle source?
thanks,
Mark
87 Westy, 250k GW 2.4 - 2.0 Wink, 16" wheels
J_Westy
J_Westy is offline
PostPosted: Tue Sep 15, 2009 11:52 am    Post subject: Reply with quote
thanks,
Mark
I pulled the pic from the reimo site:
http://www.reimo.com/en/D-accessories/DW-conversion_parts_bits/DWK-furniture_building_and_mounting/
-- page 3
I don't know of an official importer, but Steve at eurocampers will order anything from the catalog, but it could take awhile.
Jeff
Howesight
Howesight is offline
PostPosted: Tue Sep 15, 2009 12:32 pm    Post subject: Westfalia laminates Reply with quote
See my earlier post set out below regarding the greyish laminate used in the '87 to '91 Westfalias. I don't know what was used in the Eurovans, but I found this to be an exact match and it cost me only $79.00 CAD at a local plywood and laminate specialty store for a 4 x 8 foot sheet.
Good luck with your project!!
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...;start=100
J_Westy
J_Westy is offline
PostPosted: Tue Sep 15, 2009 12:43 pm    Post subject: Re: Westfalia laminates Reply with quote
Thanks!
I'm not bent on any exact match since I don't have any cabinetry in the EVWK (other than the bottom of the bed).
I need to find myself a sample of Formica 927-58 "Folkstone"
SyncroChrick
SyncroChrick is offline
PostPosted: Sat Dec 12, 2009 11:42 am    Post subject: Reply with quote
Has anyone bought some of this edge trim? Is it flexible enough?
http://www.reimo.com/r31/vc_reimo/bilder/firma16/artikel/popup/5210519_popup.jpg
RCB
RCB is offline
PostPosted: Sat Dec 12, 2009 2:21 pm    Post subject: Reply with quote
I might suggest going to a cabinet shop and looking at the sample display board that the PLam companies give them.
Hundreds and hundreds of samples to choose from and you can get a small pre-cut sample piece from the cabinet shop to compare to the color on the cabinets.
"T" molding is also another item the cabinet shop would have since the "T" molding can be used on the front of a shelf or the front edge of a cabinet or even the edge of a Westy Table.
Lumber yards for the do-it-yer-selfers would also have a decent selection as well.
Remember that to ship a sheet of PLam (plastic laminate) , it has to be rolled up for shipping.
While being shipped the PLam can split or crack and its a bitch to try and cut around the break or to try and repair the break.
Shipping can be expensive too.
Bypass any huge markup by GW and find some locally.
Some of the water based cements work quite well but the solvent based cements are a little better.
Microbusdeluxe Premium Member
Microbusdeluxe is offline
PostPosted: Sat Dec 12, 2009 2:31 pm    Post subject: Reply with quote
If you use a water based adhesive be sure it is fresh. If you use a solvent based one wear a respirator with the proper cartridge (NOT a dust mask!) Do not smoke, strike a match, set off a spark... I had a friend get some nasty burns on his face from a flash fire from laminate solvent.
Get a library book on kitchen cabinet building or laminating, Tauton Press (Fine Homebuilding/Fine Woodworking) has a number of excellent books, follow directions, use a j roller to set it, it's easier than dropping your fuel tank!
'69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig!
sc-surfer
sc-surfer is offline
PostPosted: Sat Dec 12, 2009 10:09 pm    Post subject: Reply with quote
I took a drawer front down to my local lumber yard and found an almost exact match. I think I paid about $40 for enough to cover the entire upper rear cabinet with enough extra for a couple of other projects. The GW stuff isn't some magic westy item...just regular laminate in a color match. As for the Reimo trim...I want to order some too...If anyone else wants to go in on an order to save shipping costs I'm in!
'89 Syncro Westy
Catalog of Vans at SDM 2010
Westfalia, Syncro & Tristar Reproduction decals here.
* * * Coming Soon: Washable seat covers for westy bench seat...keep the pets off the upholstery! * * *
RCB
RCB is offline
PostPosted: Sun Dec 13, 2009 9:30 am    Post subject: Reply with quote
Keep in mind that when installing the "T" molding it will be difficult to attach around the tight radius of the doors.
You will have to trim off the verticle part of the "T" to get it to follow the outside profile of the door....that will take some experimenting, so order up an extra legnth .
Also it will be a benefit to heat up the "T" molding with a heat gun or a hair drier to assist in installing it to the radius.
When routing the groove for the "T" molding, use a slotting bit.
Get one thats a bit shy of the thickness of the molding but DONT get one that cuts to thin otherwise when you tap the molding into the groove, the piece (the door...or table top) your attaching it to will split......thats not good.
If I was to do a job like this.....I would make a sacrificial door from scrap MDF or Plywood. Route the slot in the edge....cut,trim and heat up the "T" molding to fit the radius .....dry fit it.
Put a band clamp on it and let it set a day or so.
When you proceed with the "real deal" apply some glue into the radius slot to help secure the "T" molding.
surfdubaroo
surfdubaroo is offline
PostPosted: Sun Jan 06, 2019 6:42 am    Post subject: Re: Gray cabinet building tips Reply with quote
1/6/2019- found a formica supplier -
https://www.cabinetmakerwarehouse.com/catalog/folkstone-formica-laminate-4-x-8-sheets-mat-p14210/
Laughing
I just bought a sheet- will update of there is an issue.
View user's profile Send private message Send e-mail Visit poster's website Instagram Classifieds Feedback
pbrown
pbrown is offline
PostPosted: Sun Jan 06, 2019 1:31 pm    Post subject: Re: Gray cabinet building tips Reply with quote
Wow.. old thread.
Any of the big box stores like The Home Depot or Lowe’s Home Improvement will be able to source Formica or Wilsonart in any color or pattern. It is easy to work with and would probably work well as a cabinet laminate for custom built cabinets.
Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF
Sodo
Sodo is offline
PostPosted: Sun Jan 06, 2019 3:02 pm    Post subject: Re: Gray cabinet building tips Reply with quote
For the gray westfalia, the Formica color is "Folkstone" in matte finish.
Formica product Number 927-58.
I bought a 30"X96" sheet at HomeDepot for $40. 30x96 can yield up to 9 pcs for the Truckfridge TF49.
15x20 is about 1/2"x1/2" bigger than the TF49.
I don't know the TF65 size.
If anyone in the Seattle area needs a Truckfridge sheet -- send a PM.
....KTMs, GasGas, SPOT mtb
