FG1732 Samba Member
Posted: Wed Aug 01, 2012 7:59 pm Post subject: |
____________________________________________________________________________________________________________________________
Sequential shifter setup (as briefly mentioned on page 17) in a VW...
FG1732 Samba Member
Posted: Fri Aug 03, 2012 7:10 pm Post subject: |
FG1732 Samba Member
Posted: Sun Aug 19, 2012 2:40 pm Post subject: |
Bansheelos Samba Member
Posted: Fri Sep 28, 2012 7:09 am Post subject: |
Im wondering what people are running in the rear for these HP beast setups. I havent seen much talk about the fluid distribution to the rears. Are you guys running the stock T-piece that distributes the fluid to the rear? I dont have a splitty, I have a bay bus and I am swapping a vr6 into it. Been looking into some brake setups as far as the wagenswest Rear Porsche pattern disk kit w ebrake and for the front looking at the big front disk brake kit 'bustangs'. Im looking to upgrade the MC to a new dual circuit but im not sure about the distribution to the rear. I am used to watercooled vws that use a proprtioning valve in the rear. Not sure if the bigger brakes for the front and rear needs a beefier fluid distributor to the rear. |
67dubcab Samba Member
Joined: February 12, 2009 Posts: 214 Location: sebastopol C.A
Posted: Fri Sep 28, 2012 6:46 pm Post subject: |
I have run 944 front and rear disc brakes (the single piston style) with the stock hard lines with no issues, I upgraded to the D.O.T. steel braided for the flex lines.
My present set-up (untested) uses the Brembo four piston calipers which use more fluid and I ran all new lines same as stock dimensions and plumbed in a Tilton bias valve for fine balance adjustment, easy to do if you are running new lines and not expensive.
Stock tee also re-used. _________________ Porsche powered mid-engine double cab build
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...highlight= |
gumbajv Samba Member
Posted: Fri Sep 28, 2012 11:10 pm Post subject: |
A brake bias valve doesn't balance front /rear brakes. More info and explanation here: http://www.stoptech.com/technical-support/technical-white-papers/proportioning-valves
For front/back balance you would need a twin master cylinder set up with the adjustment knob, typically mounted in the cockpit. I built a twin master cylinder set for our 911 race car. Been thinking about building one for the bus. Should be easier since the m/c's would be mounted underneath where there is more room.
Here's a link to my disk brake conversion. http://there.dino.com/harold/bus0.php
I switched to a Boxster read disk when I modified the rear hub to a 911 bolt pattern. Take into account what wheel diameter you plan on using as this will affect the caliper choices. I had a slight interference problem with the 3 pc wheel bolts hitting the caliper. I used a thin spacer to move the wheel out. I still run the stock hard lines with s/s braided lines replacing the rubber lines. |
FG1732 Samba Member
turbolaz Samba Member
Posted: Tue Jan 15, 2013 3:12 pm Post subject: red9design |
hello,has anyone used the red9design suspension yet?
http://www.red9design.com/type2.htm _________________ shipping extra,paypal ok at 4% added to parts.
parts are sold as is. |
nynone4 Samba Member
Joined: August 09, 2004 Posts: 299 Location: Central Illinois
Posted: Tue Jan 15, 2013 4:35 pm Post subject: Re: red9design |
That looks very nice. Pricey though! I'd be interested in hearing some first-hand reviews of that setup as well. Wonder if they make a version using split window spindles? It'd be nice to be able to keep the disc brakes already on my truck. |
Sambafraser Samba Member
Joined: March 05, 2009 Posts: 248 Location: Hel Finland
Posted: Wed Jan 16, 2013 12:27 pm Post subject: |
They make bay and split versions. £2000 to you sir Most people seem to be happy with the adjustablity and ride. Others not so happy with the welds. here |
Thomas Pedigo Samba Member
Joined: July 03, 2010 Posts: 1052 Location: Nine Mile Falls/Sunset Bay,WA
Posted: Wed Jan 16, 2013 9:32 pm Post subject: |
I found myself to be more intrigued with the forklift. _________________ Defying conventional wisdom since 1970 |
AirBus Samba Member
Joined: February 04, 2008 Posts: 290 Location: Holland
Posted: Thu Jan 17, 2013 12:50 am Post subject: |
It's not a racer, but this upgrade on my split drives soo nice!!!
Last month I build this Porsche steering rack under my split, with the T25 steeringhouse and all OG posche parts. I will combine this with airride, thats why I used the center steeringrack. Or you can use a brakebooster, there is enough space behind the beam
I'm testing the setup now, and will check all parts next month. (and paint it..etc) It's also very nice that I have more ground clearance then a raised steering house
Totall stock lowered look _________________ VW T1 1964 - Mouse Grey - Pearl White
Bagged, Porsche steeringrack/brakes..IRS, T1 1915cc |
FG1732 Samba Member
Posted: Fri Mar 08, 2013 9:04 pm Post subject: |
DTA Samba Member
Posted: Mon Aug 05, 2013 6:18 pm Post subject: |
i have been searching for a while now with no luck. do any of you guys have the dimensions of the radiator these guys used or any for that matter that will work? im building my split bus subaru and this is the cleanest build i have found so far. thanks for any info. |
busfan Samba Member
Joined: April 11, 2008 Posts: 1 Location: South-africa
Posted: Fri Aug 23, 2013 5:02 am Post subject: South African water cooled |
This is my bus its a Fleetline , running a stroked wbx tubocharged motor with disc all round and a 4inch beam with straight axel and oe 15" Fuchs
356gt3r Samba Member
Joined: December 15, 2003 Posts: 22 Location: driving to Bogota
Posted: Sat Nov 30, 2013 9:42 am Post subject: |
#porschebus my contribution to the thread. 3.6L 993 varioram engine in 56 DD panel. driveline is late 80s 911 front and rear suspension. 16" fuchs. 915 5-speed gearbox. just completed its maiden voyage to bulli brigade 2013. |
Posted: Sat Nov 30, 2013 8:47 pm Post subject: |
356gt3r wrote: |
Now THAT looks like a ton of fun! |
nikke911 Samba Member
Posted: Mon Dec 09, 2013 11:06 am Post subject: |
Very similar build here-Porsche flat6,915-trans and rear suspension,Porsche brakes..This one is called "Leichtbau"(1045kgs with tank full of gas) |
slammed shady Samba Member
Joined: January 19, 2006 Posts: 257 Location: Wolfsburg, Germany
Posted: Fri Jan 03, 2014 9:55 pm Post subject: |
Wow!
Lots of new to me Porsche/bus builds.
I would like to see the build threads if you have them.
nynone4, I would like to see how you dealt with the manifold height. A Porsche powered panel would be my next choice for a fast delivery vehicle.
Great photo trackside nikke911, would like a link to your build also.
Here is a recent shot of the mid-engine double cab at a autocross event to get a baseline for chassis tuning.
Stephen _________________ Porsche powered mid-engine double cab build
