		mackaymanx  Samba Member
  Joined: October 12, 2006 Posts: 480 Location: Australia
		blankmange  Type 3 Darksider
  Joined: July 17, 2004 Posts: 11497 Location: Bloßer Stahl-preapocalyptic MidCoast
				 Posted: Thu Sep 17, 2009 6:45 pm    Post subject:  |
				cool -- what is the alternator from? _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
		JSMskater  Samba Grease Gorilla
  Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
				 Posted: Thu Sep 17, 2009 9:06 pm    Post subject:  |
				yeah that's pretty sweet, but it LOOKS to me like some kind of alternator mated to a  stock generator housing with a longer shaft...     cool either way! more details! _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
		Air_Cooled_Nut  Samba Member
  Joined: March 27, 2004 Posts: 3069 Location: Portland, Oregon
				 Posted: Thu Sep 17, 2009 9:45 pm    Post subject:  |
	  | blankmange wrote: |
	  |  cool -- what is the alternator from? |
Diahatsu 3 Cyl Diesel.  Link is at the top of OP's thread.
Looks nice...tell 68AutoBug he needs to go to my site and look at the instructions I made...and the date   _________________ Toby  http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
				 Posted: Fri Sep 18, 2009 12:08 am    Post subject:  |
	  | Air_Cooled_Nut wrote: |
	  | blankmange wrote: |
Looks nice...tell 68AutoBug he needs to go to my site and look at the instructions I made...and the date   |
and then he later says something about a type 1 alternator... doesn't look like any type 1 alt I've ever seen
I can't wait to finish my conversion... I'm pretty happy with it so far... _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
		rovingmind  Samba Member
  Joined: August 27, 2009 Posts: 71 Location: Toledo Oh
				 Posted: Fri Sep 18, 2009 8:09 am    Post subject:  |
				| actually he sat it beside "type 1 generator converted to alternator" as a reference |
				 Posted: Fri Sep 18, 2009 8:48 am    Post subject:  |
	  | rovingmind wrote: |
exactly. that doesnt look like any type 1 anything I've ever seen. _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
		dirtsandwich  Samba Member
  Joined: April 25, 2008 Posts: 625 Location: SW Oregon
				 Posted: Fri Sep 18, 2009 11:42 pm    Post subject: Re: Aussie style alternator for a type 3 |
	  | mackaymanx wrote: |
	  |  Here is something I have been working on. This is my type 3 alternator conversion. |
Wow, as far as the DIY alternator conversions that looks as close to a bolt on solution as I've seen.  Nice find indeed.  Same diameter?  55 amp?  Part number? _________________ 71 Squareback
77 Bus |
				 Posted: Sat Oct 03, 2009 12:16 am    Post subject:  |
				More to come
				 Posted: Sat Oct 03, 2009 12:39 am    Post subject:  |
				Ok here is my step by step of how to do it.
Start with a type 1 (or type 3) generator.
Strip it down. You will need the bearing housing from the fan end, this is the fixed end (the brush end is the floating end of the shaft). Also the pulley end of the amature shaft.
Cut the armature end off the shaft and remove the commutator, I have shown the two different types of shafts I found in the type 1 generators.
This is what you keep plus the two 6mm screws that hold the the generator together.
				 Posted: Sat Oct 03, 2009 2:52 am    Post subject:  |
				You need to build up this area of the housing, enough to leave you with 106 to 107 mm once machined back. The type 3 housing will need more as they are undercut more in this area.
As the type 1 generators are undercut at each end you need to trim the pulley end back so the mounting suface aligns properly with the type 3 fan housing. Copy the type 3 housing profile onto the pulley end of the housing and rough out the other end.
Pulley end
Alt end
Next we need some tabs on the side so it will bolt together. The first two I did I just built this up with weld but this way is far quicker.
Now we need to duplicate the front housing of the donor alternator into the VW housing. This is a type 3 housing. Use the 6mm screws to hold the front bearing housing on. Bend and weld them into the field coil holes in the housing.
Drill out the cooling hole in the housing(Yes a hole saw would be a lot easier).
		Russ Wolfe  Samba Member
  Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
				 Posted: Sat Oct 03, 2009 6:51 am    Post subject:  |
				When you install this conversion on a T-3, do you have to modify the cooling tin going to the 3/4 cylinders? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK.  Ima poop. |
				 Posted: Sat Oct 03, 2009 7:03 am    Post subject:  |
				| No mod to cooling tin. This is a straight bolt in, only mod is wiring. |
				 Posted: Sat Oct 03, 2009 8:19 pm    Post subject:  |
				Here is the field coil installed and the screws(original and modified). The diameter of the coil is 100mm, this gives you a housing wall thickness of about 2.5 mm with the VW housing being around 105 mm. There is a very similar NipponDenso alternator which has a 103 mm coil but I thought that a 1mm wall thickness was insufficient.
		notchboy  Samba Member
  Joined: April 27, 2002 Posts: 22677 Location: Escondido CA
				 Posted: Sat Oct 03, 2009 8:22 pm    Post subject:  |
	  | mackaymanx wrote: |
Um, thats some realy cool shit right there   _________________
	  | t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
				 Posted: Sat Oct 03, 2009 9:24 pm    Post subject:  |
				Here are the two different types of shafts stubs with the spacer sleeves installed. I won't give exact measurements here as is will just get too complicated. Accuracy and attention to detail is a must with this step. Clean up you stubs carefully and keep any runout to a minimum. A good check is to measure the shaft protrusion at the rear housing before you strip down your donor alternator and compare this as you calculate your sleeve lenght(make sure the pulley is on and tight when you measure this). I found around 23mm for these alternators.
Shaft together with end cover installed. Note tin plate to seal the type 1 end cover. Second roll pin not installed yet as I was still checking shaft lenght.
				 Posted: Sat Oct 03, 2009 9:53 pm    Post subject:  |
				Once you are happy with everything and have it together it's time for a quick bench test. I ran this at 2200 rpm and got 20 amps at 14.2 volts. I'm sure they will put out more but that is all I ran it up to.
		1500king  Samba Member
  Joined: January 05, 2007 Posts: 212 Location: Adelaide, Australia
				 Posted: Sun Oct 04, 2009 6:37 am    Post subject:  |
				| save yourself the trouble and pull one from an SP2. |
				 Posted: Sun Oct 04, 2009 6:40 am    Post subject:  |
	  | 1500king wrote: |
If you can find me the compleet set up from an SP2 Ill take it mate. Trade you some nice trinkets too if you want. _________________
	  | t3kg wrote: |
1964 1500 S
				 Posted: Sun Oct 04, 2009 7:56 am    Post subject:  |
				SP2 alternator was only 30 amps. Might as well stay with the generator.
Mack's conversion is 60 amps, if I read the tag right. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
