LED tail lights for 56-61
Chip Premium Member
Chip is offline
PostPosted: Mon Oct 05, 2009 12:40 pm    Post subject: LED tail lights for 56-61 Reply with quote
If there were LED tail lights available for snowflake style lights, would anyone be interested in them? They could be done in 6 or 12 volt. Would wire in to your original wiring, all you have to add is one ground wire. I'm currently testing a 12 volt setup. They specifically highlight the snowflake, as a running light. And when the brake or signal is applied, they light the rest of the assembly. Two types of LEDs are used, to make sure that it is visible from all angles. The fit is place of the filter piece. So far they seem to work great. I'll get picks up soon.
Chip
OvalWindowBucket
OvalWindowBucket is offline
PostPosted: Mon Oct 05, 2009 1:46 pm    Post subject: Reply with quote
I would be interested. I work at a PCB shop and that was on my list of things to do is make myself a set with etched PCBs.
toxic56
toxic56 is offline
PostPosted: Mon Oct 05, 2009 2:21 pm    Post subject: Reply with quote
Count me in. I would love to plug and play some of these.
OvalTeenAZ
OvalTeenAZ is offline
PostPosted: Mon Oct 05, 2009 2:39 pm    Post subject: Reply with quote
I would buy one set now, and depending on price maybe a couple others for projects waiting to get done up. Cool
Chip Premium Member
Chip is offline
PostPosted: Mon Oct 05, 2009 3:26 pm    Post subject: Reply with quote
I would love to do them on a PCB, but I'd need a HUGE commitment # in order to make it cost effective with the place I've looked into. I am currently designing a PCB for both versions(6v, 12v). But for now, I am just making them on a generic board. They are pretty labor intensive, so the price will most likely be right around $100 for a pair. they have 49 LEDs each and are nice and bright.
Chip
AlteWagen
Troll
AlteWagen is offline
PostPosted: Mon Oct 05, 2009 3:43 pm    Post subject: Reply with quote
Why commit when you can do it yourself?
http://www.thesamba.com/vw/forum/viewtopic.php?t=240612&highlight=led+brake+lights
OvalWindowBucket
PostPosted: Mon Oct 05, 2009 4:19 pm    Post subject: Reply with quote
Chip
If you send me board fabrication information (board size, 1 or 2 layer, surface finish i.e: hot air solder level, immersion gold, etc) I can get you a quote just to see where we come in at no gerbers required to quote something this simple. We cant compete with China but we have lower rates for prototype low quantity runs. Shameless self plug here:
http://www.sprigcircuits.com
Also etching PCBs yourself is always an option.
Chip Premium Member
Chip is offline
PostPosted: Mon Oct 05, 2009 4:27 pm    Post subject: Reply with quote
Its true, that you can do it yourself. There are a lot of different styles doable. Not everyone is a DIYer. I don't need a commitment to build them. I was simply saying that with a commitment, a nice PCB could be built. I'm fine with the DIY thing. PCB makes the work much prettier, and efficient to build. Thus cheaper. The ones that I built replace the incandescent bulb completely. Mine provide all functions that VW intended out of that assembly. Park, stop, and turn signal. I originally built some like the 13 LED array, mine had 25, but fit in the same dimples inside the snowflake pattern, they just continued all the way across the light as well, with the same spacing. I found that these pretty much destroyed the beauty of the snowflake, by not passing any light through it. You might as well run an aftermarket transparent red lens. I redid my array to also include another 24 LEDs that sit directly behind the snowflake. These utilize the geometric design and shoot the light in every direction, so no matter what angle you are at, you can see that the light in definitely on. Those 24 LEDs also make up the park light circuit. So the snowflake is lit the whole time the lights are on, and the whole light it lit when the turn/brake set are activated.
AlteWagen
Troll
PostPosted: Mon Oct 05, 2009 4:37 pm    Post subject: Reply with quote
A non DIY VW owner??? Shocked
The end is near my friends
Chip Premium Member
Chip is offline
PostPosted: Mon Oct 05, 2009 4:55 pm    Post subject: Reply with quote
Lots of guys are fearless when it comes to mechanical things, some are great with body working tools, others like a needle and thread. There are very few that are good at them all. Electrical stuff is just another one of those niches. Not everybody wants to(and some just shouldn't) mess with it. I'm just trying to cater to those individuals.
OvalTeenAZ
PostPosted: Mon Oct 05, 2009 5:01 pm    Post subject: Reply with quote
the fear I have of making my own. If some thing is messed up, If you get sodder somewhere it shouldnt, Thats $50 shot to hell.
Hellaslow
Hellaslow is offline
PostPosted: Mon Oct 05, 2009 8:23 pm    Post subject: Reply with quote
aren't the tail light bulbs 1157s? 12v
if so you can buy direct plugin LED lights go for about 20bux
I ♣ Baby Seals
click to see local Tampa events: http://www.thesamba.com/vw/forum/viewtopic.php?t=427873
56 vacho
40yo fat chick
www.tamparacing.com
<--- non proper vw owner
Bart Dunn
Samba Consiglieri
Bart Dunn is offline
PostPosted: Tue Oct 06, 2009 6:19 am    Post subject: Reply with quote
Where are those sold, and does anyone make a 6v version?
Not enough car seats fit into my:
'58 Beetle convertible
'58 Beetle sedan
GLHTurbo
GLHTurbo is offline
PostPosted: Tue Oct 06, 2009 7:13 am    Post subject: Reply with quote
id be interested in something.... my reflector housings are shot anyways. I like the technostalgic ones with the rapid brakes....
http://www.cool-leds.com/beetle.html
Maybe there board section will fit, and we just need to trim that aluminum backing plate (or make a new one).
Chip Premium Member
Chip is offline
PostPosted: Tue Oct 06, 2009 11:18 am    Post subject: Reply with quote
mine don't do the rapid fire thing. Though they do light quicker than a standard incandescent. Mine fits inside of the reflector housing. You still need to use that part, but it is used just to crimp the unit together into a cartridge.
Bob Loblaw
Bob Loblaw is offline
PostPosted: Tue Oct 06, 2009 11:57 am    Post subject: Reply with quote
You get what you pay for. Those LED 1157's are gonna lose a lot of their brightness passing through the snowflake. They'll just be a little red dot in there.
I'd be down with a coupla sets of those custom built ones. 1 set 6V (for the '57) and 1 set 12V (for the '59)
sent from a phone using poor grammar and spelling
Hellaslow
PostPosted: Tue Oct 06, 2009 12:09 pm    Post subject: Reply with quote
your right! you get what you pay for... and for 20 dollars you get a great led light... i've ran these 1157s in my taillights on my toyota 4x4 for years... they are bright and water/mud proof... and no you don't get "just the red dot"
I ♣ Baby Seals
56 vacho
40yo fat chick
www.tamparacing.com
Hellaslow
PostPosted: Tue Oct 06, 2009 12:10 pm    Post subject: Reply with quote
click on the google search and type in 1157 LED
I ♣ Baby Seals
56 vacho
40yo fat chick
www.tamparacing.com
Snort
Snort is offline
PostPosted: Tue Oct 06, 2009 1:47 pm    Post subject: Reply with quote
Here is a source for 6V:
http://www.highspeedmotors.com/Webled.html
Chip Premium Member
Chip is offline
PostPosted: Wed Oct 07, 2009 5:20 pm    Post subject: Reply with quote
I'm getting ready to build a prototype of my 6v. When it is done, I'll post up a photo. The actual array will look identical to the 12v.
Page 1 of 9
