Denzel eng. build up
Mr. Okrasa Premium Member
Original Old Speed
Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Mr. Okrasa is offline
PostPosted: Tue Nov 10, 2009 8:22 am    Post subject: Denzel eng. build up Reply with quote
After waiting several months for SCAT to have their forged chromoly "Superlite" crankshafts made-up,
I finally have the bottom end and ready to start assembling my Denzel bottom end..... Cheers!
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint Wink
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
grueni
grueni is offline
PostPosted: Tue Nov 10, 2009 8:53 am    Post subject: Reply with quote
wow..high end in material and also in money Sad
whats the plan for the engine in cc and all the stuff?
that will become exciting
beautiful
Original Old Speed
PostPosted: Tue Nov 10, 2009 9:01 am    Post subject: Reply with quote
beautiful
Dont want to divulge too much information at the moment. Im building two of these at the same time
and the owner of one does NOT want any info. given out on his Denzel engine build. Cheers!
VW www.Okrasa.com
grueni
grueni is offline
PostPosted: Tue Nov 10, 2009 9:30 am    Post subject: Reply with quote
but if one is yours Wink nene kist kidding. it's more than enough to see that rarity build up
have fun with it!
sled
sled is offline
PostPosted: Tue Nov 10, 2009 12:22 pm    Post subject: Reply with quote
oh man, one of my favorite engines. Are those DCM-2's?
looking forward to updates.
drive your split.
TomSimon
TomSimon is offline
PostPosted: Tue Nov 10, 2009 1:26 pm    Post subject: Reply with quote
This will be a fun build to watch... there's not many Denzel heads around to be had, that pair looks real clean
Teeroy Premium Member
Teeroy is offline
PostPosted: Tue Nov 10, 2009 2:00 pm    Post subject: Denzel eng. build up Reply with quote
What strokes is Scat offering? Are they 36hp VW mains or 356 Porsche?
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Tue Nov 10, 2009 5:38 pm    Post subject: Reply with quote
Hello-
They offer a 74mm stroke with 55mm mains (356 SC/912). You can, however, have a crank custom ground. Wink
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
Original Old Speed
PostPosted: Tue Nov 10, 2009 5:46 pm    Post subject: Reply with quote
gimmesomeshelter wrote:
Hello-
Paul
Paul is right! I have (3) that SCAT "made" with 50mm mains and (2) that have 55mm mains.
I got a small discount for buying (5) SCAT "Superlite" crankshafts at once...... Cheers! Cool
VW www.Okrasa.com
gimmesomeshelter
PostPosted: Tue Nov 10, 2009 6:28 pm    Post subject: Reply with quote
Hello-
While I understand that installing a 55mm crank into a 36HP case has its challenges, it also has its rewards. Stiffness (torsional rigidity) is proportional to the 4th power of the diameter. All other things being equal, a 55mm crank is 46% stiffer than a 50mm crank. Not bad for a 10% increase in diameter.
Paul
Richard Feynman
TomSimon
TomSimon is offline
PostPosted: Wed Nov 11, 2009 3:22 pm    Post subject: Reply with quote
Hello-
a 55mm crank is 46% stiffer than a 50mm crank. Not bad for a 10% increase in diameter...
unfortunately that's not the entire story... torsional rigitity is one part of the equation. There is also bending where the cheeks meet the main journal, and cheek meets the rod journal. The larger the rod journals and main journals and less the stroke, the stronger the crank. This overlap, often refered to as 'lap' in crank grinders parlance, is a big deal in 3-main bearing cranks like a VW. Who's to say which one matters most, or if we should care at relatively low power levels Neutral
IMO if a guy has a choice, the bigger the diameter the better, to the point in which you now weaken the case but alignboring it to accomodate those larger main bearings Wink then there is the problem of paying $400 for a set of Porsche main bearings Rolling Eyes
Original Old Speed
PostPosted: Wed Nov 11, 2009 4:42 pm    Post subject: Reply with quote
Hello-
Granted! I agree with Tom. These "little" engines that are being built for the street will never or hardly ever see RPM blasts of over 5500 rpms. The lifter/cam/valve spring design in the 25hp/36hp engine was never intended to go beyond 5500 rpm's safely so unless you do something with those "weak links" first, then I would worry about what size the crank journals are.....In my 35+ years of building these early engines, I have never had a crankshaft break either stock, stroked or billet. If you are experiencing broken crankshafts then something else is wrong?!?! These engines are NOT producing the HP that the drag racers are laying down at the strip.
Another note: When you machine the magnesium case for the larger 55mm main bearings, you are weakening the block. Remember, the S-90/SC
and 912 Porsche engines all use ALUMINUM blocks which were designed to use the larger 55mm main bearings. Cheers! Mr. Okrasa Cool
VW www.Okrasa.com
gimmesomeshelter
PostPosted: Wed Nov 11, 2009 10:11 pm    Post subject: Reply with quote
Mr. O'
Is there a common point(s) of failure for these engines?
Paul
Richard Feynman
Jake Raby
Jake Raby is offline
PostPosted: Wed Nov 11, 2009 10:51 pm    Post subject: Reply with quote
If you aren't breaking parts you aren't making enough power.
I have a 3 piece 36HP crankshaft on my trophy shelf.
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
Original Old Speed
PostPosted: Wed Nov 11, 2009 11:57 pm    Post subject: Reply with quote
Yeah!........I know. Boo hoo!
VW www.Okrasa.com
sled
sled is offline
PostPosted: Wed Nov 25, 2009 11:18 am    Post subject: Reply with quote
Any updates? Very Happy
drive your split.
Original Old Speed
PostPosted: Wed Nov 25, 2009 11:45 am    Post subject: Reply with quote
nope..... #Sleep
VW www.Okrasa.com
