Autostick vs Manual cam plug?
connella08
connella08 is offline
PostPosted: Thu Dec 03, 2009 1:23 pm    Post subject: Autostick vs Manual cam plug? Reply with quote
there is a little circular plug on the back of the case directly behind the flywheel that's about the size of a quarter. my "how to rebuild your aircooled engine" book states that if you have an autostick transmission that this plug must be facing inward toward the cam, but if you have a manual it needs to be facing outward away from the cam. whats the difference?
i am in the process of converting my autostick to a manual, so do i have to crack the case open to turn this little plug around? if you need pics let me know, im pulling my autostick tranny off later tonight so i will try to get some pics then if necessary.
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Thu Dec 03, 2009 1:25 pm    Post subject: Reply with quote
I think it was a flexplate interference thing.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Thu Dec 03, 2009 1:28 pm    Post subject: Re: Autostick vs Manual cam plug? Reply with quote
No you don't need to. Like Miniman82 posted. It's the other way around. An autostick flex plate can rub a hole in the cam plug if it's in the "manual trans/normal" flywheel type configuration. You will not have any issues.
connella08
PostPosted: Thu Dec 03, 2009 3:29 pm    Post subject: Reply with quote
great, thanks guys. i wasnt looking forward to cracking my case open again if there were going to be any problems.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Dec 03, 2009 3:32 pm    Post subject: Reply with quote
Mine's in and I don't have a autostick.. never a problem.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
connella08
PostPosted: Thu Dec 03, 2009 3:53 pm    Post subject: Reply with quote
glenn, thats the same way i have it, thanks for the picture verification. i just wasnt sure if that was done for any other reason being internal or external. time to start the tranny swap!
didget69
didget69 is offline
PostPosted: Fri Dec 04, 2009 9:44 pm    Post subject: Reply with quote
IIRC, you should be able to install it one direction that will work on either a manual or Auto Stick application?
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
Mr. 010
Glenn is offline
PostPosted: Fri Dec 04, 2009 9:46 pm    Post subject: Reply with quote
bnc
Yes... with the plug in it will work with both.
So you can convert a autostick to a manual but not a manual to a autostick.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
connella08
PostPosted: Fri Dec 04, 2009 9:50 pm    Post subject: Reply with quote
Glenn wrote:
bnc
unless you tear down the case and turn the cam plug around.
Mr. 010
Glenn is offline
connella08 wrote:
Glenn wrote:
bnc
But who would want to Wink
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
connella08
PostPosted: Fri Dec 04, 2009 10:31 pm    Post subject: Reply with quote
Glenn wrote:
connella08 wrote:
Glenn wrote:
bnc
lol thats the whole reason i started this thread. i WAS going to if i HAD to...thankfully i dont.
