FrankRam Samba Member
Joined: June 22, 2007 Posts: 140 Location: Chesterfield, MO
Posted: Sun Dec 06, 2009 5:12 pm Post subject: Back up speedometer switch help for reverse light |
Anyone have any experience with the Back up/ Reverse Switches that fit behind the speedometers? I just installed one on my '57 oval's 6 volt system and I have achieved 100% negative function thus far. The switch is a Hella NOS 71 /21 6 . One wire attaches to the ignition terminal (3rd from left facing the trunk) and the other runs to the light. I have the light grounded to the bracket bolt. The contacts are good. Tried 2 different bulbs. Tried reversing wires from the switch. The speedometer works so I know its on straight and the switch is not stripped. I assume on the light itself the ground wire is toward the outside and the hot wire attaches closest to the bulb. All new 16 gauge wire.
I am out of ideas. Anyone experience this? Thanks for hopefully some enlightenment. |
Sunroof53 Samba Member
Posted: Sun Dec 06, 2009 5:53 pm Post subject: |
Ideally you need a volt meter to check the voltage at each stage .Check for voltage at the fuse board ,move to the live side of the switch .You could jack the car and get a friend to turn the wheel as though you are reversing .Check for voltage on the other side of the switch .if there is no voltage then the switch is faulty if there is move your tester to the lamp and check again.if you have voltage on both sides of the switch then double check your lamp and wiring.
Personally i would run a live to the lamp and see if it lights up first.especially if you dont have a meter. |
Posted: Sun Dec 06, 2009 6:32 pm Post subject: |
| That is an excellent idea to jack the car and spin while checking voltage. I'll find me a meter tomorrow and hope the switch is good. Awesome. Thanks. |
Nessy Samba Member
Joined: September 28, 2004 Posts: 424 Location: Wales,UK
Posted: Mon Dec 07, 2009 2:24 am Post subject: Re: Back up speedometer switch help for reverse light |
| FrankRam wrote: |
One thing springs to mind here, don't expect instant power through the switch to the light when reverse is selected; the vehicle often needs to move a few feet (and so the speedo cable does a few revolutions) before everything works as it should with this type of switch.....
 _________________ 1972 1302LS Convertible RHD |
passoa55  Samba Member
Posted: Mon Dec 07, 2009 3:04 pm Post subject: Re: Back up speedometer switch help for reverse light |
| Nessy wrote: |
| FrankRam wrote: |
X2
I have them NOS boxed!  _________________ 1950 Hebmuller #458
1953 original paint oval ragtop
1955 lowlight lizard green
1955 original paint oval
1956 1600 super V-sunroof Porsche
1958 lowlight ghia black
1963 firetruckred 23 window
1967 SO42 westy
1969 original paint Westy
1970 one owner 1300L bug |
Suboval Samba Member
Posted: Tue Dec 08, 2009 9:07 am Post subject: |
Most times the contacts inside are corroded and that can be easily fixed. Gently lift the Hella sticker. Under it is a screw that holds the switch together. Remove the screw to get to the contacts and clean them - a pencil eraser works fine. Put a dab of grease on the contacts/sliding portion to prevent corrossion and to keep everything sliding smoothly. Reassemble the switch. You can use an ohmmeter to test the switch.
If the center post (the male one that goes into the speedo is broken) - just replace it. The bar stock can be found at Lowe's/Home Depot. File the sides to get the correct fit into the speedo. Drill thru the female and remove the rest of the broken male end. Cut the bar stock to fit, but leave a little extra. Mix up some epoxy, and slide the bar stock in thru the female side and epoxy it into place.
The speedo hot lead is connected off of the fuse box. Just make sure it is connected to one that the ignition key turns on and off or you might find yourself with a dead battery if the you backup and park. _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
Posted: Sun Dec 13, 2009 6:35 pm Post subject: |
I haven't jacked up left front tire, spun backwards and checked for current yet, as I don't really want to use stock jack in channel. I need to go to a garage and use a real lifter. Dumb question - Can I take the screw out, under the sticker, and clean the contacts without removing the switch out from the speedometer? It was tough getting it in there as I was barely able to pull back the cable far enough and I dont want to break anything.
Thanks
First, do no harm. |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9416 Location: Northwood, NH USA
Posted: Sun Dec 13, 2009 7:39 pm Post subject: |
| FrankRam wrote: |
Thanks
You could also pop the center cap off the front left brake drum and attache a cordelss drill to the squared able end to test. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Sun Dec 13, 2009 8:08 pm Post subject: |
| I would need what kind of 'bit' for that manuever I wonder? |
Posted: Sun Dec 13, 2009 9:06 pm Post subject: |
| FrankRam wrote: |
Just chuck the drill onto the cable end, it'll spin it enough for a quick test. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Mon Dec 14, 2009 7:52 am Post subject: |
| FrankRam wrote: |
Thanks
Sorry, but no. The switch needs to be removed. _________________ It all works on paper.
Posted: Mon Dec 14, 2009 10:39 am Post subject: |
| Gotcha. Best to do it right. Thanks for the huge tip! |
Posted: Mon Dec 14, 2009 3:48 pm Post subject: |
| Suboval wrote: |
The speedo hot lead is connected off of the fuse box. Just make sure it is connected to one that the ignition key turns on and off or you might find yourself with a dead battery if the you backup and park. |
The fact that the speedometer is currently working with the switch installed does mean that the center post piece is just fine, correct? |
Posted: Wed Dec 16, 2009 7:36 am Post subject: |
| FrankRam wrote: |
Yes. _________________ It all works on paper.
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 1017 Location: Lanark County, Ontario, Canada
Posted: Wed Dec 16, 2009 4:28 pm Post subject: |
I remember having a problem with one of these switches....the car would roll backwards a fair distance (too far!) before it would switch on the backup light. Cleaning the internal contacts didn't fix it for me; instead I had to make a finicky tension adjustment by bending the sliding metal ring that has the two contacts on its ends. This decreased it's diameter slightly and gave it a better grip after re-installation. It's hard to describe, but when the ring is too loose, it's like a slipping clutch, and there may not be enough force to positively close the contacts, or to at least close them promptly and keep them closed. If it is working properly, it shouldn't take several revolutions to close the switch.
IMO, the little accessory plunger switch (on a bracket placed near the shift rod coupling under the back seat) was a better design. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
Posted: Thu Dec 17, 2009 10:17 am Post subject: |
| I am so stoked thanks to you guys! 100% function as of now. The old SWF back-up light illuminates the whole garage at night. Turns out, the best fuse to hook up to was the 2nd from the left when facing from front of car, not the 3rd (of 4) as indicated from the speedo-switch instructions. Basically, it's any terminal that has power when ignition is turned on. I know that's sooo basic for most everyone, but when your a newbie like me, it's a revelation. A simple circuit-tester from Ace Hardware for $3.99 led me to this discovery. I'll try to do a picture in the next coupla daze. Kowabunga and "eep opp ork ah ah". |
Posted: Thu Dec 17, 2009 11:06 am Post subject: |
| One further note: With ignition on, both sides of the reverse switch tested hot without spinning the tire backwards. I believe this occurred because the car was last backed into place. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Thu Dec 17, 2009 11:51 am Post subject: |
| FrankRam wrote: |
And this is why you need to use a lead that is hot with ignition
And on mine I had to do what Zwitterkafer did, make the ring diameter smaller. |
Posted: Thu Dec 17, 2009 4:59 pm Post subject: |
All done ...
