VdanielW Samba Member
Posted: Tue Dec 15, 2009 11:00 am Post subject: engle w100 cam card |
| Anyone know the intake closing for an engle w100 cam. I did a search, but no one has posted a 100 card. |
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Tue Dec 15, 2009 11:14 am Post subject: Re: engle w100 cam card |
| VdanielW wrote: |
_________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
Posted: Tue Dec 15, 2009 11:15 am Post subject: Re: engle w100 cam card |
| turboblue wrote: |
| VdanielW wrote: |
ots03 Samba Member
Joined: March 21, 2007 Posts: 199 Location: argentina
Posted: Wed Dec 16, 2009 5:26 pm Post subject: |
| whats the pourpose of this card ? |
Posted: Wed Dec 16, 2009 7:15 pm Post subject: |
| I was running some dynamic compression #'s on a 1600 and 1776 with this cam and need the int.closing time. |
joescoolcustoms Samba Member
Posted: Wed Dec 16, 2009 11:50 pm Post subject: |
| ots03 wrote: |
To identify exactly what the part is. The information can be used in calculations for static compression and to provide the information to a engine builder so they can check and determine if the part is installed correctly. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
white/red_68 Samba Member
Joined: October 13, 2008 Posts: 207 Location: Kissimmee
Posted: Sat Nov 20, 2010 3:47 pm Post subject: |
| It is any big diference between a stock cam and a w100? |
modok Samba Member
Joined: October 30, 2009 Posts: 27733 Location: Colorado Springs
Posted: Sat Nov 20, 2010 3:53 pm Post subject: |
Oh yeah, the 100 has a lot more duration
the stock cam is 215/220 degrees at .050" lift, It has negative overlap! |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Sat Nov 20, 2010 4:04 pm Post subject: |
| white/red_68 wrote: |
Dept. of Useless Trivia: The CB Cheater cam fills the gap between stock and W100 nicely. In case you were wondering. _________________
| Mitey62 wrote: |
| Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
| RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum.  |
Posted: Wed Nov 24, 2010 4:15 pm Post subject: |
| Ok, thanks for the info and heads up...happy thanksgiving!!! |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42873 Location: at the beach
Posted: Wed Nov 24, 2010 4:53 pm Post subject: |
page 27 http://www.englecams.com/downloads/2010_engle_catalog.pdf
lobe center is 108 duration at .050 is 236 / 236 . Advertised duration is 276 / 276
just print something like this and fill it in with the numbers for your cam.
_________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
