Change from 4 bolt to wide 5 .
olered54
olered54 is offline
PostPosted: Wed Dec 30, 2009 3:17 pm    Post subject: Change from 4 bolt to wide 5 . Reply with quote
I am wanting to change my'70 standard to accept wide 5 wheels. Can I just get wide 5 drums for the rear and disc brake rotors for the front? I have a pair of CB Performance drop spindles that I want to install also.
Do drop spindles require special rotors?
Thanks
Tim
vwracerdave
vwracerdave is offline
PostPosted: Wed Dec 30, 2009 3:55 pm    Post subject: Reply with quote
Search in the Off-Road forum. 4 to 5 conversion has been done 10,000 times.
Slow6t5
Slow6t5 is offline
PostPosted: Wed Dec 30, 2009 5:22 pm    Post subject: Reply with quote
Or even easier, buy an old bug.
Cheap, Fast, Reliable; pick two!
View user's profile Send private message Twitter Instagram Classifieds Feedback
BaxterGG
BaxterGG is offline
PostPosted: Wed Dec 30, 2009 10:21 pm    Post subject: Reply with quote
Front drums are a straight swap with '66-'67 drums as they were ball joint and wide 5.
For the rear, the wide 5 drum is thinner so you'll need to swap out all brake components (pads, springs, clips) with early model except you can keep your same wheel cylinders. Then because of the thinner drum you'll need to buy spacers (most vdub shops will have them or CIP1 online) to go in between the axle nut and the drum. Your done Smile
Also for the rear, I think (please someone correct me if I'm wrong) you can use VW Thing rear drums as a straight swap because they're the same width as the 4-Lug...?
Greg
'57 Beetle
'75 Bay Window Westfalia
‘81 Vanagon Westfalia
johnR
johnR is offline
PostPosted: Thu Dec 31, 2009 3:00 am    Post subject: Reply with quote
From this thread (good one with pics too)
http://www.thesamba.com/vw/forum/viewtopic.php?t=244042&start=0
... the Thing rear drums are a straight swap (same shoes, backing plates, etc.) *BUT* will increase track width -- that is push the rear wheels out-- an additional 7/8" each side.
westcoast-paul
westcoast-paul is offline
PostPosted: Thu Dec 31, 2009 9:58 am    Post subject: Reply with quote
all true, but to add to this - you can cut off 12-15mm from the 4 lug drum nipple to use as a spacer. it's even splined. works great!
- Paul
didget69
didget69 is offline
PostPosted: Thu Dec 31, 2009 1:07 pm    Post subject: Reply with quote
Or you can buy a ready-made spacer -
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13-22-5281-7
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
jakz
jakz is offline
PostPosted: Tue May 10, 2016 8:48 pm    Post subject: Re: Change from 4 bolt to wide 5 . Reply with quote
old post but im trying to convert the rear of my 82bug to wide 5 and wanted to ask if anyone has used this type of spacers, they seem to solve all the clearance issues with the late pads and could be a direct install http://www.justkampers.com/4-stud-beetle-to-wide-5-drum-spacer-kit.html
best regards!
jake
EVfun Premium Member
EVfun is offline
PostPosted: Tue May 10, 2016 9:26 pm    Post subject: Re: Change from 4 bolt to wide 5 . Reply with quote
You would have to measure and make sure it will get the wider pads in the narrow drum but most of the narrow drums have a little over 40mm of inside width. You will need new or freshly turned drums without ridges from 30mm pads. You will want to also check the lug bolt clearance as you will be running the shoes quite close to the inside face of the drum.
I will point out that if you choose to swap to older backing plates for 30mm shoes you will have to replace the wheel cylinders too. The step that rests against the backing plate is machined in a different location. With 30mm brakes there are 2 styles, '58-'64 and '65-'67. The backing plates, shoes, adjusters, and wheel cylinders are different for each style.
Some places sell adapter drums already made to fit the late brakes and give the wide 5 pattern. Another option is to use VW Thing drums, but they increase the track width around 20mm per side.
Wildthings wrote:
