I wanna be laminated - Best Cabinet Laminate FAQ
BUSBOSS
BUSBOSS is offline
PostPosted: Fri Feb 12, 2010 12:38 am    Post subject: I wanna be laminated - Best Cabinet Laminate FAQ Reply with quote
I'm wondering if anyone who has relaminated their cabinets can tell me how many 4X8 sheets I will need to do all of the cabinets and the closet in a 76 Westy. I do not need to include the wall, hatch or door panels in this estimate.
I searched unsuccessfully for the answer.
Thanks in advance!
All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible
(sold - but not forgotten)
Drewbacca
Drewbacca is offline
PostPosted: Fri Feb 12, 2010 1:02 am    Post subject: Reply with quote
I'd like to know the same thing actually, except including the wall, hatch, and door panels. That laminate is not cheap...
-Drewbacca, previously known as Jimthegman.
'77 Westy - "Hot Donna"
fatwood1
fatwood1 is offline
PostPosted: Fri Feb 12, 2010 9:00 am    Post subject: Reply with quote
I have not done a re-lam on these parts, but I have owned a cabinet laminating shop for many years. Here is a link to a free cut list program. Just put in the size pieces you need, remember to go at least 1" bigger than actual panel. Then put in the 4 x 8 material. The program will then make a diagram showing you how to maximize material yield. Once the program gives you the diagram, make sure all pieces have the grain running the direction you want them to be. If any are wrong, you can go back and edit the pieces and then get a new layout.
http://www.delphiforfun.org/Programs/CutList.htm
patayres
patayres is offline
PostPosted: Fri Feb 12, 2010 9:59 am    Post subject: Reply with quote
I am of no help with the cabinets, but 1 4x8' sheet did my rear hatch panel, the driver side wall, the sliding door panel, dash table, and I've got some pieces left over.
1975 Westfalia Helsinki - 1800 EFI w/ Pertronix
1965 Singlecab - 1600dp
yuthi'so'coro
Andre4
Andre4 is offline
PostPosted: Fri Feb 12, 2010 10:25 am    Post subject: Reply with quote
If you're going woodgrain you need to use more than you'd expect because you want the grain running vertically not horizontally and not a combination of the two. I needed three sheets to do my complete interior but I did screw up a few pieces. This included making pieces for the sliding door, rear hatch, wall next to the stove cabinet and the inside of the opening stove cabinet lid. I'd guess that you could get away with 2 sheets if you don't do the wall and sliding door panels.
Andre
Krautski
Krautski is offline
PostPosted: Fri Feb 12, 2010 4:52 pm    Post subject: Reply with quote
Time to break out the tape measure.
From there you can figure yields out quite easily
BUS FOR SALE
I stopped reading after volksaru and busaru
VWMIKE76
VWMIKE76 is offline
PostPosted: Fri Feb 12, 2010 5:43 pm    Post subject: Reply with quote
the laminate isn't to expensive if you know someone in the industry! about 40 a sheet, so for about 120 you can have all new interior panels!
Mike
77 westy Mac n cheese aka "Mac"
71 crew cab "Damien" sold and missed lots!
78 westy "Doc". in very good hands of a fellow samba member!
79 hardtop landmark "Shaggy II"
Andre4
Andre4 is offline
PostPosted: Fri Feb 12, 2010 6:03 pm    Post subject: Reply with quote
Dang... I paid close to that per sheet!
Andre
VWMIKE76
VWMIKE76 is offline
PostPosted: Fri Feb 12, 2010 7:09 pm    Post subject: Reply with quote
ouch!!!!!!!!!!!
Mike
Joe S.
Joe S. is offline
PostPosted: Fri Feb 12, 2010 7:45 pm    Post subject: Reply with quote
i just relaminated my 69. used 1 4x12 for cabinets and 1 4x8 for sink top and table
dcketh
dcketh is offline
PostPosted: Sat Feb 13, 2010 9:23 am    Post subject: Reply with quote
I haven't done it yet, but below is how I think I can get all the wood grain pieces for my '71 out of a single 5' x 12' sheet. I realize yours is a different year and a different layout, but perhaps it will help. I bought Wilsonart laminate at home depot, 5' x 12' for $144. Of course you will need a second piece of something else to do tables/countertops.
~ Dan ~
'71 Westy
'74 Thing
BUSBOSS
BUSBOSS is offline
PostPosted: Tue Feb 16, 2010 12:05 am    Post subject: Reply with quote
Thanks fatwood! I will begin the layout and report back!
1976 Westfalia
BUSBOSS
BUSBOSS is offline
PostPosted: Thu Jul 15, 2010 5:50 pm    Post subject: Reply with quote
I finally started the prep work for laminating the interior.
All of the old laminate has been removed. Gaps and cracks have been filled with wood filler. A few mores passes with the belt sander and finishing sander and I should be ready to begin cutting and applying the laminate.
I purchased three 4X8 panels of a laminate product by Nevamar in Blossom Cherry (Hi Luster). The product code is WC5681N.
I'll update this thread with my progress.
1976 Westfalia
RatCamper
RatCamper is offline
PostPosted: Thu Jul 15, 2010 5:55 pm    Post subject: Reply with quote
A lot of print shops have large form laminators. maybe you could go through arms first Wink
I am interested to see how (re) laminating works.
What is the laminating stuff?
On an aside, a while back I bought a flat pack tallboy. the packing material was the paper stuff for the woodgrain laminated option. I never knew it was done like that!
notchboy
notchboy is offline
PostPosted: Thu Jul 15, 2010 6:04 pm    Post subject: Reply with quote
Wow you are not F-ing around Exclamation
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Desertbusman
Desertbusman is offline
PostPosted: Fri Jul 16, 2010 1:02 am    Post subject: Reply with quote
Awesome program. I'm finished with my interior but sure could have used it. Not just for all the wood panels but for the vinyl for all the upholstery and the fabric for the curtains.
71 Superbug
71 Westy
patayres
patayres is offline
PostPosted: Fri Jul 16, 2010 8:50 am    Post subject: Reply with quote
Busboss, your attention to detail is once again to be admired! Can't wait to see the finished product Cool
yuthi'so'coro
BUSBOSS
BUSBOSS is offline
PostPosted: Sun Sep 19, 2010 6:46 pm    Post subject: Reply with quote
Okay, it's been about two months and I'm nearly finished. Here ya go!
I still have to install the sink, plumbing etc.. and then I'll post pics of that last cabinet.
Winter will bring work on the engine compartment, gas tank, and engine rebuild.
1976 Westfalia
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Sep 19, 2010 6:52 pm    Post subject: Reply with quote
Very red, but looks good. Nice work.
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
Westfabulous
Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Westfabulous is offline
PostPosted: Sun Sep 19, 2010 6:58 pm    Post subject: Reply with quote
Sweetness! I love people who pay attention to detail. Nice work indeed. How close is that to the OEM color, and is that what you were going for? Either way, looks great. Keep up the good work.
Page 1 of 7
