scratchs68 Samba Member
Joined: May 28, 2009 Posts: 359 Location: hamilton, new jersey
Posted: Fri Mar 12, 2010 4:02 pm Post subject: Painting Cylinder housing? |
Is it ok to paint the housing on the clinders with high temp paint? I'm trying to make them look nice and nothing else is working. I've tried blasting, also stuff to turn rust into a flat black finish(didn't come out black) thanks |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79983 Location: Sneaking up behind you
Posted: Fri Mar 12, 2010 4:27 pm Post subject: |
Unless you're laying under the engine, you won't see them when the sheetmetal is on. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
MrUnix Samba Member
Joined: March 04, 2009 Posts: 346 Location: N. Central Florida
Posted: Fri Mar 12, 2010 4:30 pm Post subject: |
You can paint them, however lots of people suggest you leave them as is to facilitate heat transfer. Many high-temp paints will act as insulation, and under no circumstance use a ceramic based paint! Like glen said.. nobody will see them anyway! |
Randy in Maine Samba Member
Posted: Fri Mar 12, 2010 6:22 pm Post subject: |
I like to give them a dusting of BBQ black paint. Keeps them from rusting adn retaining even more heat. |
Anthony Samba Member
Posted: Fri Mar 12, 2010 6:35 pm Post subject: |
Randy in Maine wrote: |
Yes, that aluminum rust can be quite a problem |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Fri Mar 12, 2010 6:47 pm Post subject: |
Anthony wrote: |
Randy is refering to the cylinders.... Unless you've really upgraded you do not have aluminum cylinders...
To the OP, I took your post as you are wanting to paint the cylinder tins( "housing on the clinders")? You can prime and paint with normal paint, or an engine paint. _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
candymustang65 Banned
Joined: January 11, 2010 Posts: 1674 Location: APPLE VALLEY
Posted: Fri Mar 12, 2010 7:18 pm Post subject: |
Do not paint cylinder's them selves with any thing but Black Primer non VHT type paint .
Cylinders should be lightly coated with non VHT type Flatt black Primer paint .
Krylon flatt black primer only !
or nothin at all .
But lightly coating the cylinder's them selves with Flatt black primer has been proven to reduce temp's and increase heat dissipitation .
This very same thing applie's to brake Drumm's !
Brake drumm's should be lightly coated with flatt black Primer .
No VHT type paint << Means Barby or Gloss , Semi Gloss , even sealing flatt black containg VHT ( Vinyl some thin or another ) Vinyl Hydrachloride Tethracylclene) < joke Last one is Anti Biotic ?
But the Viny seal's heat in .
Actually smoke brakes like Semi truck if drumm's are painted with VHT type paint.
All it takes is 4 Big Guy's and a down hill mountain Rd be lookin for a Run away truck ramp !
Just so you know .
Cylinder Tinn < I dont care what you paint engine tinn with .
How ever realize that the use of Flatt black Primer of the non VHT type can be used in several area's of the engine to help dissipitate heat faster .
Example : Oil plate , Pump Plate , Crank Pulley bolt , Stripped Valve covers , Push rod tube's , Cyl. stud's , Cyl Deflector tinn , Case it self , etc.
Sean |
Posted: Fri Mar 12, 2010 8:16 pm Post subject: |
Yes I was thinking bout the cylinders. Better to have a dusting of paint on them than 1/2" of rust.
I guess I don't speak jersey.  |
zeroman Samba Member
Joined: February 05, 2010 Posts: 891 Location: Cane field
Posted: Sat Mar 13, 2010 1:18 am Post subject: |
Thing is.. if we're talking regular "metal wood plastic" krylon. It'll just burn off. Pretty darn instantly. Most paint does. I spend a lot of time down at the local NAPA paint store and more time sanding and painting.. haven't run into much that will stick to something that hot for long.. especially if you are concerned with insulating it. Which .. in all the air cooled engines i've ever worked on.. most not being VWs .. and granted.. most aluminum jugs.. none have had any coating.
If I was going to try to make my engine pretty... I might try something like one of those "rust transformers" or something like a jasco prep-n-prime. Or naval jelly followed by rust. I recently used "wire brush".
I have heard around the "water cooler" about this theory of painting things black to "suck heat out" because black is an absorber of IR as much as visible light. I'm far from sold on the idea. Even if it did something.. painting a tiny layer of black on a big chunk of iron...????
But.. have seen it on one of those sunday morning red-neck Powerblock tv shows on Spiketv, and hear the F-body guys all talking about it. Think they mentioned "ti-tech".. but whenever I look up this theory.. I find it only in forums and people trying to sell me something. |
Posted: Sat Mar 13, 2010 8:10 am Post subject: |
Nah no primer to rust .
I dont traffic in Urban Legend's !
It's not a frikin theory on Cyl. jugg's runnin cooler and reduceing head temp's when painted with Flatt black primer .
This is a proven procedure used by most/ all the shop's in So Cal. last 25 year's !
As far as Cylinder's go ?
Theoretical part of my post would involve the Valve Covers/ tinn < Ive never putt it too the test .
On this you need to just take my word that it is my personal experience Pullin Baker Grade on the edge of Death Valley Ca. 25 miles to the top .
That I say it make's a noticeable difference .
But Ive only been buildin Bugg's and Runnin the Eastern Mojave for the last week or so ?
Sean |
Posted: Sat Mar 13, 2010 11:31 am Post subject: |
zeroman wrote: |
Thing is.. if we're talking regular "metal wood plastic" krylon. It'll just burn off. Pretty darn instantly. Most paint does. I spend a lot of time down at the local NAPA paint store and more time sanding and painting.. haven't run into much that will stick to something that hot for long.. . |
a standard paint works well on the engine tins, they don't get hot... a standard paint works well on the ouside of the cylinders too... got sets many years old with lots of miles that are still painted... the cylinders don't run nearly as warm as most folks think... _________________
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6543 Location: Northern Illinois
Posted: Sat Mar 13, 2010 8:35 pm Post subject: |
Just a light dusting on the cylinder fins. I use BBQ black or black primer whatever I have on hand. _________________ Midwest Autosavers, Inc. Crystal Lake, IL |
greggholmes Samba Member
Joined: December 10, 2003 Posts: 265 Location: Camano Island, Wa.
bluebus86 Banned
Posted: Sat Oct 30, 2010 10:09 am Post subject: |
soemone had a site on the internet several years ago that showed an engineering student report on the effects of paint on VW cylinders. I cant find that report right now (please post it if anyone remebers it)
basicaly the student enginner took Vw cylnders and added thermocouples to measure temps, filled them with heated water in a controlled enviroment (controlled air flow) and studied the temp drop.
the worst offenders where dirty rusty oiled up cylnders and ones with thick paint. the ones with a thin flat black paint did the best for heat transfer
it was a very good well thought out experiment and the report was very nice with photos.
the result, is in flat black in a thin layer helps cool, even better than a newly cleaned bare cylinder |
Posted: Sun Oct 31, 2010 8:30 am Post subject: |
Krylon flat black primer !!!
Or you can mix your own in reference to the post your wanting .
Ifn memory serves me its a witche's brew of Laquer and John Deere Black Basically Primer .
But really !
Just easier to flat black Krylon primer .
But think this post has this Url look back thru the post and click on the Url's .
Sean |
