Fresh air box on 1972 Super Beetle... I'm confused.
nbuscemi
nbuscemi is offline
PostPosted: Sun Mar 14, 2010 8:21 pm    Post subject: Fresh air box on 1972 Super Beetle... I'm confused. Reply with quote
I recently purchased a 1972 Super, and while most of the car is intact, there are a few things don't seem right. I always thought the 72 SB had a fan driven fresh air box under the hood, instead on my car I find just a vent box with a drain... no fan. Was this swapped, or did some of these not have a blower... also, where can I find new fresh air boxes as mine is wrecked, fan driven or not.
Thanks,
-Nick-
19super73
Hardcore Stock Nazi
19super73 is offline
PostPosted: Sun Mar 14, 2010 8:23 pm    Post subject: Reply with quote
There should have been a fan driven air box. Do you have the dash switch still? I had a few kicking around at one time but I think I sold them. Easily found in the classifieds though.
http://www.thesamba.com/vw/classifieds/detail.php?id=903502
http://www.thesamba.com/vw/classifieds/detail.php?id=707258
http://www.thesamba.com/vw/classifieds/detail.php?id=863993
1970 Campmobile [url=https://www.vw-mplate.com/mplate-47260.png]Click to view image[/URL]
1970 Fastback 1600 TL
1971 Doka [url=https://www.vw-mplate.com/mplate-14845.png]Click to view image[/URL]
1973 Super Beetle
1973 Westfalia [url=https://www.vw-mplate.com/mplate-31892.png]Click to view image[/URL]
1974 412 Variant
1975 La Grande Bug
1984 Vanagon
nbuscemi
nbuscemi is offline
PostPosted: Tue Mar 16, 2010 7:13 pm    Post subject: Reply with quote
Dash was in pretty bad shape, alot of things missing. I didn't see a fresh air swtich. No fan, no nothing, just a small vent box that attached to a drain leading under the car. I've been jipped!
-Nick-
19super73
Hardcore Stock Nazi
PostPosted: Tue Mar 16, 2010 8:06 pm    Post subject: Reply with quote
Post some pics.
1973 Super Beetle
1974 412 Variant
1975 La Grande Bug
1984 Vanagon
lytnbug
lytnbug is offline
PostPosted: Wed Mar 17, 2010 5:47 am    Post subject: Reply with quote
Didn't the 71 & 72 Supers use the standard's type airbox, since the curved window 73s and later had the whole dash makeover, including the fan in the airbox?
19super73
Hardcore Stock Nazi
PostPosted: Wed Mar 17, 2010 8:11 am    Post subject: Reply with quote
From what I understand they had the same box but Supers came with a fan assembly in them. I had a few kicking around, sold one or two and may have another.
I suppose that the next question would be to ask if Nick is 100% positive he has a Super. I find it odd that a PO would swap out the proper fan box but then again, PO's do weird shit all the time. Could be that the fan quit at one point and instead of just leaving it, the set up was swapped out to a non-fan box and the switch removed.
Pics help either way.
1973 Super Beetle
1974 412 Variant
1975 La Grande Bug
1984 Vanagon
lytnbug
lytnbug is offline
PostPosted: Wed Mar 17, 2010 8:16 am    Post subject: Reply with quote
Yup. You are right. The 3rd classified link above shows the wires and you can see the white squirrel wheel inside.
Nick, guess you have the McPherson struts and all?
19super73
Hardcore Stock Nazi
PostPosted: Wed Mar 17, 2010 9:47 am    Post subject: Reply with quote
Yes, and $35 for a working one is not a bad price. The last one I sold was working and it went for $50 to Brazil. I'm sure switches can be found as well.
http://www.thesamba.com/vw/classifieds/detail.php?id=890008
I found only one. The round fan switch is correct for '73+, the other is '71-'72 Supers. I do believe that by '75 the Standards (just not the 110's), started to get fresh air fans.
1973 Super Beetle
1974 412 Variant
1975 La Grande Bug
1984 Vanagon
tele68
tele68 is offline
PostPosted: Wed Mar 17, 2010 1:16 pm    Post subject: Reply with quote
I just replaced the fan and box on my '72 Super. The OG fan was seized from age and rust, common...the switch was also melted as was the brush carrier inside the motor. I found a switch and used fan box with a working motor on Samba for $40 for both, keep looking. You also need the correct matching ducts and six air hoses, to set the whole thing up, see this diagram:
the ducts are available from lots of ebay and samba vendors, but they are a bitch to install, you need to take out the glove box on the pass side due to the wiper arm. Do your radio and any other dash control stuff first like the headlight switch, etc, because once you get the fan box in and working with the ducts and hoses, you won't want to take it out, IMHO. The fan switch is located next to the brake warning light above the radio in a recessed bezel if you have a 71-72 SB. There are also a great pair of online videos showing how to rebuild the box and fan motor, search this forum for links on them, appeared awhile back. If you get one, guarateed the rubber shock mounts for the fan housing are rotted out, but nearly identical ones can be bought from any industrial supply like McMaster-Carr, etc...you need them for vibration when the fan is on high...BTW Mid America sells the hoses as a set...JT
'72 Super Beetle
Central Jersey Volkswagen Society
Johnny Martin
Johnny Martin is offline
PostPosted: Fri Dec 23, 2011 11:31 pm    Post subject: Reply with quote
hey tele can you post a link to the vids you were talking about??
1971 SUPER BEETLE
AE489501 carb Solex 30 pict-2 with dist 0 231 137 021
113 905 205 M
mrbigmax
mrbigmax is offline
PostPosted: Sat Dec 24, 2011 12:14 am    Post subject: Reply with quote
I don't know if Tele can, But I can help.
http://vimeo.com/377760
http://vimeo.com/1072065
Chris Vellat
Chris Vellat is offline
PostPosted: Sat Dec 24, 2011 1:16 am    Post subject: Reply with quote
I've rebuilt a couple of the late style fresh air fans from both my `77's Std. Beetles, and one earlier Super unit...They don't have many parts in common. One late unit had a bad resistor for the slow-speed circuit and I had to modify one from the local RadioShack to fit...it was slightly greater value than stock, so it now runs a little slower, but it's better than nothing.
mondshine
mondshine is offline
PostPosted: Sat Dec 24, 2011 7:12 am    Post subject: Reply with quote
Those videos referred to by mrbigmax are great.
The 1302 fresh air box is completely different from the unit (without the fan) on standard Beetles.
It looks like this:
Good luck, Mondshine
Willhelm
Willhelm is offline
PostPosted: Sat Dec 24, 2011 7:22 am    Post subject: Reply with quote
(a used one I bought and refurbished)
Sequim
Sequim is offline
PostPosted: Sat Dec 24, 2011 8:40 am    Post subject: Reply with quote
You can buy the special 71+72 two speed switch at Wolfberg West. Their is a motor take apart and relube video on thesamba that works if your motor is squealing. I did that and it is simple. You can also buy the special rubber insulators for the fan (inside the box) at McMaster Carr page 1363. Lube the control cables well. If the dash and inside hood control vents are missing they are available new for inside the car, and used for the ones in the hood area. The insulator connector for the duct inside the hood is available from Mid America. I have this working perfectly in a 72 super beetle and adjust the cold air intake knobs as desired to ensure warm air yet enough fresh air and defrost for the windshield. Hook it up as it was intended and you will be very happy with the results.
algernon72
algernon72 is offline
PostPosted: Sun Nov 04, 2012 8:16 pm    Post subject: Reply with quote
Any one find # 7 ( rubber moter mount) or #12 ( rubber flap ) from the picture above? I think I have checked every supplier and I cant find it
Sat for 14 yrs, in garage. Now its time to bring it back. Front suspension, steering, bearings, and brakes, carpet, headliner seats Done! Turn around in the garage. CVs, bearings, disk breaks, Turn around again, fuel tank, and brake fluid container. Drained and filled transaxle,, set valves, new fuel pump and it started! Yahoo!! Two cups of rust blew out the muffler.HA! Pertronix SVDA and a Rebuilt 34-3 from Tim I'm on the road!
Willhelm
Willhelm is offline
PostPosted: Tue Nov 06, 2012 4:22 am    Post subject: Reply with quote
i know in a couple of threads people have mentioned finding similar replacement rubber mounts from McMaster Carr.
http://www.mcmaster.com/#
Chris Vellat
PostPosted: Tue Nov 06, 2012 9:42 am    Post subject: Reply with quote
I believe the rubber-box type mounts (#12) are from the later models w/squirrel cage fan (of which I've rebuilt one and parted-out another)...the earlier ones (#11) use a rubber-studded mount - similar to a Rabbit radiator mount. Here are the 'replacement' early style mounts (1/4"-20) I got from McMastercarr:
The flap (#7) would be a source a good used one or make one.
SmithLAFD
SmithLAFD is offline
PostPosted: Sun Jan 27, 2013 3:09 am    Post subject: How to find a fresh air box for '71 beetle Reply with quote
First post so bear with me, but does anyone have any leads on how to track down a fresh air box for a 71 beetle? Looked on the usual suppliers but all I can seem to find is the connections for it (hoses etc) Does anyone make any aftermarket one or I am stuck asking around and junkyard diving (fingers crossed)
slagathor
slagathor is offline
PostPosted: Sun Jan 27, 2013 5:15 am    Post subject: Re: How to find a fresh air box for '71 beetle Reply with quote
since they are not made anymore, the classifieds are your best bet. i took my fresh air box off my 73 standard last night to take apart and clean 40 years of dirt out of it.
