Whats the difference between these two steering wheels?
Sooty Sooty
Sooty Sooty is offline
PostPosted: Mon Apr 05, 2010 11:18 am    Post subject: Whats the difference between these two steering wheels? Reply with quote
Is it the size of the spline hole?
http://www.thesamba.com/vw/classifieds/detail.php?id=891312
http://www.thesamba.com/vw/classifieds/detail.php?id=894071
Why is one not for a split?
I have a near mint one on my 53 Oval that I don't want.
How can I guage what price to sell it for and will it fit a split if it's on my 53 Oval? Cheers.
This is mine.....
cheers.
33woodie
33woodie is offline
PostPosted: Mon Apr 05, 2010 11:53 am    Post subject: Reply with quote
I think the hole size is the same but the splines are different (coarse vs. fine). I would guess that yours should be the same as a split.
Regards,
Jim
‘64 VW sedan Bahama Blue
'70 Porsche 914-6 Tangerine
Bruce
Bruce is offline
PostPosted: Mon Apr 05, 2010 11:55 am    Post subject: Reply with quote
Since both of those steering wheels have later 3x3 part numbers, neither of them are for splits. They both have fine splines. A split wheel would have coarse splines.
usariemen
usariemen is offline
PostPosted: Mon Apr 05, 2010 12:45 pm    Post subject: Reply with quote
Both could be installed in a split. Technically. The later fine splines work with the earlier steering shafts. But both are no split parts and your 1953 one isn´t either. A split ones outer ring where you grab it has a kind of "thumb rail" like the batwing ones have. They where not that round.
At least in mine.
Master of my domain!
Sooty Sooty
PostPosted: Mon Apr 05, 2010 1:22 pm    Post subject: Reply with quote
So now i'm confused! Is it just from an early bug then? Like a 60?
I don't want to advertise as the wrong thing!
usariemen
PostPosted: Mon Apr 05, 2010 1:35 pm    Post subject: Reply with quote
I am not sure when they changed the design for the ring but I would had expected that a 1953 still had the earlier style.
Looking at the pic, you have an export model anyway.
So your three spoke was added somewhen later. Maybe its late 50s or even 60s.
Sooty Sooty
PostPosted: Mon Apr 05, 2010 1:37 pm    Post subject: Reply with quote
Yeh, I have the OG Batwing, but as the horn push was missing I put the 3 spoke one on for the UK MOT.
I want to put the OG Batwing back on and sell the 3 spoke!
My Bug is a Sept 53 RHD Deluxe.
usariemen
PostPosted: Mon Apr 05, 2010 1:43 pm    Post subject: Reply with quote
Well, so then pull it of and take a look at the number and the splines.
That will tell you more.
33woodie
33woodie is offline
PostPosted: Mon Apr 05, 2010 1:46 pm    Post subject: Reply with quote
Jake,
I think usariemen makes a good point. You need to take your 3-spoke off and see if it is coarse or fine splines. I have never tried to put a fine spline wheel over a coarse spline shaft but I have done the opposite, (coarse spline wheel over a fine spline shaft on my '56 and it does not fit).
If yours is coarse spline it appears that it will not fit fine splines shafts and would only work on early cars.
regards,
Jim
usariemen
PostPosted: Mon Apr 05, 2010 1:49 pm    Post subject: Reply with quote
As I said, fine spline ones can be put into early cars.
So this one could be late.
Sooty Sooty
PostPosted: Mon Apr 05, 2010 2:05 pm    Post subject: Reply with quote
Cheers guys, will look tomorrow. Many thanks.
RareAir
RareAir is offline
PostPosted: Mon Apr 05, 2010 6:05 pm    Post subject: Reply with quote
There are no Pre '59 "fine spline" steering shafts. "Fine" spline shafts were introduced on the 1960 model. Do you have a 1960-later shaft on your '56?
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
RareAir
RareAir is offline
PostPosted: Mon Apr 05, 2010 6:08 pm    Post subject: Reply with quote
At least in mine.
Agreed. Look at the photo below, that is a 1949-55 wheel. See how the outside grip has a dished profile. These wheels will have a 24-tooth "coarse" splined hub
1956-later standard wheels have a rounded profile. These wheels will have a 48-tooth "fine" splined hub
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
bally
bally is offline
PostPosted: Mon Apr 05, 2010 7:14 pm    Post subject: Reply with quote
Does he mean it's not for split screen vans rather than split bugs (he goes on to say it's for bugs or Fridolins)?
I sold mine for £150 GBP - it is a later standard model wheel. It has since been professionally restored and last I saw it was for sale for £450 - I don't know if it sold though. $550 for NOS would therefore look like a bargain. $1500 maybe slightly overpriced. Maybe yours would be £300 if in original unrestored condition?
Just my thoughts.
Dave
56TIMOTEO
56TIMOTEO is offline
PostPosted: Mon Apr 05, 2010 10:17 pm    Post subject: Reply with quote
Look for turn signal canceling ring (or screw holes for it)!
33woodie
33woodie is offline
PostPosted: Tue Apr 06, 2010 8:09 am    Post subject: Reply with quote
I think I'm confused. Didn't you just say in your next post, 3 minutes later that 49-55 had a 24 tooth hub and that '56 and later had a 48 tooth "fine spline hub"?
regards,
Jim
Dubbers Toy Box
Dubbers Toy Box is offline
PostPosted: Tue Apr 06, 2010 11:05 am    Post subject: Reply with quote
regards,
Jim
i will clarify
the steering shafts were all coarse spline up through 59
but starting in mid 1956 they changed to the fine spline hub in the steering wheel so there would be more adjustment.
so as someone mentioned earlier, you can put a fine spline wheel on a coarse spline shaft. but not the other way around.
WE ARE CURRENTLY MOVING. Please Text, Call or Email to contact us. 714-622-4956
Dubber's Toy box
714-900-DUBS
714-622-4956
www.DubbersToyBox.com
Follow us on Facebook at http://www.facebook.com/DubbersToyBox
Twitter at http://twitter.com/dubberstoybox
33woodie
33woodie is offline
PostPosted: Tue Apr 06, 2010 11:16 am    Post subject: Reply with quote
Thanks for the clarification Sad
regards,
Jim
drscope
drscope is offline
PostPosted: Tue Apr 06, 2010 11:49 am    Post subject: Reply with quote
I think the real difference between these 2 wheels is $950.
Sooty Sooty
PostPosted: Tue Apr 06, 2010 12:14 pm    Post subject: Reply with quote
Guess so! Ha.
I will take the wheel off and take lots of pics. Many thanks all.
Still a tad confused though!
