Front Suspension Stiffener from CSP
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Tue May 11, 2010 7:34 am    Post subject: Front Suspension Stiffener from CSP Reply with quote
Hello-
Has anyone tried one of these?
http://www.vwparts.net/CSP498001111A.html
They look like a good idea (assuming that you don't break off the mounting bolts while extracting them.) Wink
Thanks,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
74 Thing
74 Thing is offline
PostPosted: Tue May 11, 2010 7:44 am    Post subject: Reply with quote
Those look like parts that originally came on Thing beams. Basically they attact to the ends of the beam and tie it in to the pan to make it more rigid for off roading.
Chad1376
Chad1376 is offline
PostPosted: Tue May 11, 2010 8:21 am    Post subject: Reply with quote
Here's the Thing brace - the bottom looks similar, but the CSP brace doesn't connect to the upper beam.
The Thing pan has a reinforced area where the brace attaches to the pan. I'm curious how the CSP is supposed to attach. It seems like it would help strengthen the beam from fore-aft movement, but I don't see how it would provide much benefit in keeping the beam from twisting along the tunnel axis.
My never ending 1302 Autocross Project:
http://www.shoptalkforums.com/viewtopic.php?f=51&a...02b8f83f22
pupjoint
pupjoint is offline
PostPosted: Tue May 11, 2010 10:22 am    Post subject: Reply with quote
the CSP bars are 99% exact copies of what was fitted as OEM to Bugs exported to Japan and Thailand , a few more countries that I am not sure.
in my part of the world, we have been using these bars for close to 20 years now since we get them from abandoned cars.
the only part that is different is the squarish rectangle plate that acts as a washer.
this is how they look like on my 66
this is a Japan spec car, came factory fitted with these bars, see the washers
i do not know the exact reason why VW originally fitted these though , maybe some sort of safety compliance?
pupjoint
pupjoint is offline
PostPosted: Tue May 11, 2010 10:25 am    Post subject: Reply with quote
some other pics
john7
john7 is offline
PostPosted: Tue May 11, 2010 10:27 am    Post subject: Reply with quote
bugpack has sold something similar for years for baja bugs. but they are really easy to make too and for way less $
Jesus Saves
Slot Mag King!
I accept Paypal, CASH, GOLD, SILVER, COINS, GUNS & money orders.
pupjoint
pupjoint is offline
PostPosted: Tue May 11, 2010 10:29 am    Post subject: Reply with quote
i have seen those and those feel really crappy. the OEM ones are really heavy and huge. I believe the CSP ones should be the same.
marekv8
marekv8 is offline
PostPosted: Wed May 12, 2010 6:42 am    Post subject: Reply with quote
I assume that the CSP pieces won't work with a slightly narrowed (2") beam?
pupjoint
pupjoint is offline
PostPosted: Wed May 12, 2010 6:57 am    Post subject: Reply with quote
it should since it is a direct copy.
i am using the originals and i have a 4 inch narrowed beam and caster shims.
vwtaiwan
vwtaiwan is offline
PostPosted: Thu May 13, 2010 6:14 am    Post subject: Reply with quote
For 2"~3" narrow beams, you need to redrill the grease fitting.
pupjoint
pupjoint is offline
PostPosted: Fri May 14, 2010 1:43 am    Post subject: Reply with quote
yup forget bout that . My grease nipple was redrilled
spook
spook is offline
PostPosted: Fri May 14, 2010 3:57 am    Post subject: Reply with quote
we make our own
same idea at least.
www.airkooledkustoms.com
SBS US #10
feedback on the shop : http://tinyurl.com/yc7jgkl
Welcome to he darkside, its lower here.
View user's profile Send private message Visit poster's website Facebook Twitter Classifieds Feedback
marzano
marzano is offline
PostPosted: Mon Mar 07, 2011 5:47 pm    Post subject: Reply with quote
Adjustable Brazilian braces.
source: http://www.fastcommerce.com.br/sistema/listaprodut...a-de-1976-
[]s
Dum
65 brazilian bug - Fusca 65
Resto pix: http://www.flickr.com/ricardomarzano
http://www.forumfuscabrasil.com
Casting Timmy
Casting Timmy is offline
PostPosted: Sat Mar 21, 2015 6:40 pm    Post subject: Reply with quote
Very neat.... do these make a good difference?
Howard 111
Howard 111 is offline
PostPosted: Sat Mar 21, 2015 7:36 pm    Post subject: Reply with quote
This is an OLD post, but it doesn't matter.
I run a turbo/FI street '73 Ghia. It was built just for straight line speed. I run no sway bars in the front. A 4' narrowed beam but KYB gas shocks all around, and a rear sway bar. The gas tank is a 10 gallon tank moved to the rear. It runs surprising well in corners. Smile
1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270
