Sawsalesman Samba Member
Joined: May 27, 2009 Posts: 796 Location: Ashland, NH
Posted: Mon May 17, 2010 10:18 am Post subject: ? about Bentley Stop Plate Adjustment Picture |
| In section 6, Page 11 of the Bentley manual there is a picture of the stop plate adjustment noted in Figure 3-18. My question is it says to have the transmission engaged into 2nd gear and then it looks like you have to push the stop plate towards the drivers door which would put the gear shift lever up against the area where 3rd and 4th would be. The problem is probably more with the picture. Is the view they are showing as if you were in the seat looking down or if you were facing the gear shift from the windshield side of the shifter? |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17745 Location: San Diego, California
Posted: Mon May 17, 2010 10:20 am Post subject: |
DBM, you out there bro? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42921 Location: at the beach in Northern Wokistan
Posted: Mon May 17, 2010 11:00 am Post subject: |
seems strange to me too but that instruction comes up over and over. I spent 2 hours last night trying to get mine to feel right. Colin speaks in one thread about trying to get the side to side in the middle of the travel, and the book shows 90 degrees. Well, on mine the side to side is only about .080 side to side so there isn't a lot to work with. And when it is in reverse there is so much slop in the shifter it is always wanting to pop out - not the actual gear but the shifter. Maybe someone who has done this successfully can take photos. Even BusDaddy had to change his answer on one thread when someone asked which way the plate went. I too would really like so guidance here. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Posted: Mon May 17, 2010 11:12 am Post subject: |
| What I don't understand is that based on the picture, how are you supposed to shift into 3rd and 4th if the gear shift lever is up against the stop plate based on the picture in the Bentley? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53181 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon May 17, 2010 11:19 am Post subject: |
OK... I'll wade in
Fig. 3-18 is a view from the rear, the position the shifter is depicted in is the 1-2 location. Remember it pivots at the top of the spring so moving the lever to the right would move the lower flange on the lever to the left away from the reverse lockout ramp (arrow). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon May 17, 2010 11:26 am Post subject: |
Oh crap, that makes sense now. Forgot about where it actually pivots! ARGH!
By the way, got the bus on the road this weekend. Only drove it for about 3 miles but it sure was fun. Went up through the gears pretty well but downshifting was non-existent. Hoping a clutch pedal adjustment and then a stop plate adjustment may help with this problem. |
Posted: Mon May 17, 2010 11:31 am Post subject: |
Good to hear! Keep poking at the stop plate, move it little to one side and make a note of the direction you moved it, then test drive it, worse? better? if it's worse go the other way. A couple MM at the plate = a couple inches at the knob, a little tap can make a big difference. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon May 17, 2010 11:32 am Post subject: |
| Sounds good. I'm going to mess with it tonight when I get home from work. |
RocketRod Samba Member
Joined: July 19, 2007 Posts: 641 Location: Colorado Springs, CO
Posted: Mon May 17, 2010 12:18 pm Post subject: |
I take a common large screwdriver and a 13mm socket on an extension and drive, stop, adjust, drive. I know how frustrating it is for it to shift but not downshift. That was just after replacing the transmission nosecone parts and all bushings. _________________ Why Yes it is a Magic bus!
Common Sense isn't so common. |
Posted: Mon May 17, 2010 12:32 pm Post subject: |
Have you checked the forward bushing on the shift rod for condition? You have to drop the splash pan and look up just under the gear shift. It makes a big difference as well as the condition of the shift coupler. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Mon May 17, 2010 12:37 pm Post subject: |
| I will check it out. |
Desertbusman Samba Member
Posted: Mon May 17, 2010 1:16 pm Post subject: |
Glad you have it up and running and BD's info helped. Bentley is correct (again) and real straightforward. I think you added your own thinking into Bentley's instructions making it more complex and confusing. It didn't say anything about 3rd and 4th, you did. It said 1. get the trans into second and with the shifter loose 2. position the bottom portion of the shift lever straight vertical. Then 3. move the stop plate left into contact. Then 4. lock it down. It's alway worked for me and never had to do any more side to side adjustment. People that don't refer to Bentley usually ignor the vertical part and possibly get in trouble.
As far as the fore and aft adjustment it seems like it has worked well no matter where it's at but I adjust it for convenience and away from the brake handle. And I use the wonderful little $5 quick shift kit.
But you quys just got me in trouble. Went out to look at the lever neutral position in the fore and aft direction and it flopped around all over. Then remembered the engine and trans are sitting on the ground right now .
Yes, that little front bushing needs to be in good shape. _________________ 71 Superbug
71 Westy |
SGKent  Samba Member
Posted: Mon May 17, 2010 3:37 pm Post subject: |
my 1-2 and 3-4 shift fine. Reverse has to go down, over and back to engage. But when reverse is engaged if I tap the shifter just a tad the shifter will pop out from under the lockout. There is just a tiny bit of rotation to the shifter that encourages this to happen. All new bushings are new and so is the donut in the nosecone. Any ideas what I am doing wrong or where to look for the problem? I don't recall my 1971 doing this. I had to push it forwards before the shifter would pop back up. _________________
George Carlin:
aopisa Samba Member
Posted: Mon May 17, 2010 3:53 pm Post subject: |
| Desertbusman wrote: |
Yes, that little front bushing needs to be in good shape. |
Spent the day with Colin on Saturday going over my bus. My shifter had a lot of play and rattle. We (Colin) removed the shifter and loosened the pin at the bottom of the shift lever that was stuck, greased it up really well. It took quite a few tries to get the lever back into position and the pin back into the slot. Then we pretty much followed the directions as stated above.
I'm not so sure how critical that 90 adjustment is. We just put it into 2nd gear and pushed on the right side of the stop plate snug with a large screw driver. Shifts great, goes into reverse well and no more rattle. The only thing is that the PO had installed a cheap after market stop plate that was pretty chewed up, but I did not have a replacement. My front bushing was fine. _________________ 1977 Westy 2.0L FI
Leap into the boundless and make it your home! ---Chuang-Tzu
Please let me know if you do not receive this message... |
Posted: Mon May 17, 2010 4:00 pm Post subject: |
| SGKent wrote: |
| my 1-2 and 3-4 shift fine. Reverse has to go down, over and back to engage. But when reverse is engaged if I tap the shifter just a tad the shifter will pop out from under the lockout. There is just a tiny bit of rotation to the shifter that encourages this to happen. All new bushings are new and so is the donut in the nosecone. Any ideas what I am doing wrong or where to look for the problem? I don't recall my 1971 doing this. I had to push it forwards before the shifter would pop back up. |
Sure you don't have the stop plate on upside down? (I'm not sure if that could cause that but the way the back of the ramp is shaped it might). Better check a few sources on the correct orientation, I'm doubting myself now Gotta think upside down and mirror image. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
pkrboo Samba Member
Joined: October 09, 2009 Posts: 512 Location: Lincolnshire, UK
Posted: Mon May 17, 2010 6:29 pm Post subject: |
I am still trying to get mine right. I took it to a shop and they said the ball is worn and I should get a new gearshifter.
Also need to do the rear coupler and will take pics of the ball. _________________ 1979 Sage Green Westfalia P22 |
Posted: Mon May 17, 2010 6:40 pm Post subject: |
| pkrboo wrote: |
Also need to do the rear coupler and will take pics of the ball. |
I wouldn't trust the shop because in my experience I've never seen that before. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
pkrboo Samba Member
Posted: Mon May 17, 2010 6:46 pm Post subject: |
I hate say but I agree. I need to check what he did to the timing as well. He said it was way out and had re done it. However he did t fill me with confidence. At least it isn't running rich now tho. _________________ 1979 Sage Green Westfalia P22 |
Posted: Mon May 17, 2010 8:31 pm Post subject: |
| SGKent wrote: |
| someone asked which way the plate went. I too would really like so guidance here. |
Robert B. has the excellent drawing in fig. 3-18. Remember it is looking forward (the only way you can really look at it) just like the photo above it. Be sure and remember which way it goes so that you can remind me if I forget in the future. A friend was all excited about his $100 Berg used shifter he found. Problem was it didn't work. We turned the shift plate around to fix it. He had put the R ramp on the left side. _________________ 71 Superbug
71 Westy |
SGKent  Samba Member
Posted: Mon May 17, 2010 8:53 pm Post subject: |
facing forward the tall long ramp is on the right like photos. The pin in the ball is free to move in but the peens hold it from popping out. The top piece is reasonably centered with the stop plate pushed all the way towards the driver. The stop plate is genuine nos with tabs, I took the used one out because I thought that might be it. When the bus is put in reverse with the motor off, I hear the selector in back drop into reverse gear. I can at that time flip the shifter like you were whacking a fly on the desk with your finger and it will pop into neutral altough the selector is still in R. I know there is something wrong somewhere. I spoke with Richard Long about it being in the trans and he said no. As long as the selector puts it into R then it is in R. The looseness is in the shifter or adjustment. Al the bushings along the way are new and everything tight. There was a little wear under the driver where the bushing had fallen out on the po but everyone said that wasn't bad enough to cause problems. WTF am I doing wrong?
George Carlin:
