D Clymer Samba Member
Joined: December 22, 2005 Posts: 2987 Location: Issaquah, WA
Posted: Thu Jul 15, 2010 8:44 pm Post subject: Power Window Regulator: Pimax Italian. The only option? |
Hi everyone,
I need to replace the power window regulator on a friend's Vanagon. Is Pimax Italian through Van-Cafe the only option at this point, or do you know of any vendors still selling the genuine VW article?
Any feedback on the Pimax Italian unit? I've installed one of these on an Audi Coupe GT and it didn't fit very well so I'm kind of leary.
David |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4268 Location: Redwood City, California
Posted: Thu Jul 15, 2010 8:55 pm Post subject: Regulator non factory |
You will have the same experience. They work and are actually a better design ,but just not fully engineered to work properly.
I feel you are better off time and dollar wise to repair what you have. Lots of talk here on the Samba ,one of the listee's did a great job on documenting the whole procedure.
if you do decide to replace it with something else ,let me know I will buy all of the old parts from you .
Good luck.
Stacy |
tchristney Samba Member
Joined: September 07, 2010 Posts: 3 Location: Victoria, BC
Posted: Tue Sep 07, 2010 11:23 pm Post subject: save your money |
I bought one of these when the cable in my factory regulator broke. First off, it goes in the upper half of the door, right where the factory installed speaker goes. So if you want one of these, you'll either have to do without a door speaker or patch the existing hole and cut a new one in the bottom half of the door. Bleh. Secondly, the electrical connections are different, so you'll have to desolder the connector from the actuator switch that connected to your old motor's connector and solder theirs in it's place, making sure that you get the polarity correct (unless you don't mind the window switch reversed.)
Lastly, and probably the worst, is that after I got the thing installed and was trying to determine the polarity of that connector so I could wire it up correctly, I discovered that applying 12V to the motor was not enough to actuate the regulator! I can hear the motor trying to move it, but the thing just won't make it go, without even having the window connected yet. I'm going to take it out and see if I can make it move outside of the door (in case I've inadvertently kinked something getting it in the extremely awkward location - much worse than the stock part for those that have schlepped out that thing).
If I get it working I'll make sure to post back here but even then I'm on the prowl for one from the VW graveyard about 40 minutes away because I'm not so keen on living without one speaker. If that fails I'll buy some cable and try to repair my old one, but with three crimps on it that will be a PITA as well I suspect. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12381 Location: Santa Cruz, CA
Posted: Wed Sep 08, 2010 11:06 pm Post subject: |
No luck at the wreckers. My next clever idea is to utilize my pilot friend to try and contact an airplane mechanic to build me a new cable. Word is that those fellows have all manner of tools for building custom cabling. Failing that I'll try a marine shop as they should also have the necessary tools. I'm crossing my fingers...
For the record, the local VW dealer reports that the power window regulator has been discontinued so the OEM part is no longer available new. Calling around to various shops with VW expertise elicited laughter. |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Thu Sep 09, 2010 7:03 am Post subject: |
Have you checked out Interstate Auto Parts yet. They have two yards in Southern California. Diane just might have what you need.
The phone number for the shop in Lake Elsinore is (951) 471-5080 and the San Marcos phone number is (760) 736-8515.
Blair and Sons in Phoenix Arizona also has parts for Vanagons and their phone number is (602) 243-1238.
Derik at Way Out Salvage might be another option and their phone number is (479) 665-4126. |
Californio Samba Member
Posted: Thu Sep 09, 2010 9:26 am Post subject: |
| There's a place in NY that rebuilds these for a bit over $100, easily googleable. |
akyrie Samba Member
Joined: March 24, 2010 Posts: 519 Location: Driftless, Wisco
Posted: Thu Sep 09, 2010 3:27 pm Post subject: I know is a rebuild, but.... |
egermanparts.com has most everything original vw rebuilt for around 100 bones. here is the link.
I have ordered parts from here before, and everything has worked well...I have been happy so far is what I am saying. good luck.
http://sd.worldpac.com/arch/egermanparts/part.jsp?...ssion=null |
DLJ Samba Member
Joined: August 05, 2008 Posts: 562 Location: North California
Posted: Thu Sep 09, 2010 3:35 pm Post subject: window regulator |
| I have them. contact me for price info. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7287 Location: Honolulu,Hawaii and France
Posted: Thu Sep 09, 2010 3:36 pm Post subject: |
Put a manual regulator with a heavy duty Spal kit:the best thing,and it's though  |
Posted: Thu Sep 09, 2010 5:58 pm Post subject: |
| Hey this worldpac place has front heater cores! I thought they were NLA all over the place except for small runs here and there! Anybody buy one? |
Posted: Sat Sep 11, 2010 11:54 pm Post subject: |
Thanks for all the advice. My first choice will still be to try to get a new cable built for less than $100 + shipping. We'll see how that pans out. In the meantime I need to warn anyone else off buying the Pimax part (even more than I already have done).
I did manage to get the unit to actuate the window so it clearly has enough power (it is a bit slow - but the stock units aren't exactly super sonic either). The problem is the fit. I thought that the motor going right in the speaker well was bad. But even worse IMO is that the guide for the linear gear that replaces the cable mechanism found in the VW part is right in the way of the double rocker switch that operates the window motors! Seriously.
Here is the location of the motor showing how it takes up the space for the speaker [1]. Also shown is where the guide intercepts the location for the window controls [2]. It is really quite astounding to me that they could get the part this wrong and still try to sell it. I guess they just couldn't figure out how to route the guide around the heater channels in the door. But still, their design should never have made it onto the market IMO.
r39o Samba Polizei
Posted: Sat Sep 24, 2011 10:39 am Post subject: |
Reviving another thread from the dead.
I have one of these after market regulators.
My window does not seem to go all the way up
AND
it does NOT go all the way down (hurts my arm.)
How do you adjust these things?????? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
16CVs Samba Member
Posted: Sat Sep 24, 2011 1:38 pm Post subject: Regulator |
| Californio wrote: |
Those guys have a great website and lots of claims ,but have never returned a single E mail ,with regards to a Vanagon Regulator ..
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Posted: Sat Sep 24, 2011 1:59 pm Post subject: |
As usual,I wrote things that seem to not interest anybody.....
Spal kit deluxe on ebay with manual regulator.Though and goes fast.
Easy breezy.
http://www.ebay.com/sch/i.html?_from=R40&_trks...Categories for those who already have switches,the kit is cheaper without these
I've put a couple pics on my Westy thread,I just did the right side 2 weeks ago and improved both doors mounting of the regulator.
Just need 2 spacers to be made and longer screws:
grinding: the 2 M6 holes drilled were the first test,no need.You don't even need the place between the cables,I didn't remove it,but time gave me reason:it's good as is.
Teflon spacers cut in half on the stone wheel:
Pic from speaker spot on regulator to soon receive spacers and M6 bolts.You see why I grinded the teflon spacers.
Motor goes on stock location hole,so no interference with anyhting.(bottom from of the door,by the step) _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12172 Location: Port Manteau
Posted: Sat Sep 24, 2011 2:58 pm Post subject: |
Hey dude, any more pics of the SPAL install? I really like their products, and would love to replace my ailing original PW regulators with something newer and less trouble prone. _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
Posted: Sat Sep 24, 2011 3:08 pm Post subject: |
Hi Casey!
http://www.thesamba.com/vw/forum/viewtopic.php?p=5325265&highlight=spal#5325265
I "forgot" to take pictures of the motor installed last time I removed the panels,it was getting dark,I was in a rush of fixing driver's door and mount the passenger door system.But I used the brackets provided (only 3 needed) and bolted that on stock holes in the door,no drilling.
I just cut the connector from the old VW motor and soldered it on the Spal wires shortened (they are many feet long!!).Golden.
Bye
(I still didn't receive the last package,they're slow at USPS,that's 10 days later than what they told you ),I'll send you the link for the project build,I got stacks of parts to assemble,I'm ready after hours and hours of hunting parts and informations for it.All the way to Japan Hahaha!
I also did the ALH head gasket yesterday afternoon,looking goooood!
Have a cool week end  _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Sat Sep 24, 2011 4:54 pm Post subject: |
Thanks for the info!
I just checked, and it looks like your package is arriving today...which is really really late. Sorry for all the waiting. I just know that this is gonna end up as one of the coolest little minis running around the island. _________________ Casey--
'89 Bluestar ALH
NEAT, no ICE. |
r39o Samba Polizei
Posted: Sat Sep 24, 2011 10:08 pm Post subject: |
| ALIKA T3 wrote: |
As usual,I wrote things that seem to not interest anybody..... |
A few pictures and description as you finally did would have piqued interest.
My BIG question is:
Does it then fit flush so the stock electric window door panel fits with out modification?????? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Sun Sep 25, 2011 1:09 am Post subject: |
| r39o wrote: |
| ALIKA T3 wrote: |
My BIG question is:
Does it then fit flush so the stock electric window door panel fits with out modification?????? |
If you do the spacer trick like shown on the pics,yes it will.You'll have to do it anyway,since there is a beam running inside the door that doesn't help very much for routing the cables to the crank. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
