How much does a fully built type 1 engine weigh?
Quickstraw
Quickstraw is offline
PostPosted: Wed Aug 18, 2010 5:16 pm    Post subject: How much does a fully built type 1 engine weigh? Reply with quote
Random question. Looking for the weight on a fully built type 1 engine.
I did a search and could not find the answer.
donmurray
donmurray is offline
PostPosted: Wed Aug 18, 2010 5:55 pm    Post subject: Reply with quote
I looked it up 3 months back, but didn't record. Think it was about 260 lbs.
74 Ghia, with 2110 engine
exciter
exciter is offline
PostPosted: Wed Aug 18, 2010 8:00 pm    Post subject: Reply with quote
I thought i read somewhere a 1500 cc singleport weighs 198#
smkn_vw
smkn_vw is offline
PostPosted: Wed Aug 18, 2010 8:37 pm    Post subject: Reply with quote
Probably depends what you're looking for. Stock or modified, aluminum or magnesium case, deep sump, IDA's vs Solex, oil/no oil all will add up and change the weight.
didget69
didget69 is offline
PostPosted: Wed Aug 18, 2010 8:46 pm    Post subject: Reply with quote
Figure on dressed COMPLETE engine with heater boxes, all tin, clutch components at @ 260 lbs.
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
nsracing
nsracing is offline
PostPosted: Sat Aug 21, 2010 10:48 pm    Post subject: Reply with quote
a longblock on a small pallet was 350 lbs or so. Sucker is NOT light. Don't try to lift a longblock by yourself. Save your back. Once you slip a disk, no going back. Laughing
LeviMan2001
Samba Post Whore
LeviMan2001 is offline
PostPosted: Sat Aug 21, 2010 11:09 pm    Post subject: Reply with quote
Two people can lift a longblock relatively easily. That's how much it weighs in my mind Laughing
http://www.thesamba.com/vw/forum/viewtopic.php?t=366056 - My '73 Super Build. 2332cc, 16" Fuchs
Quickstraw
PostPosted: Fri Aug 27, 2010 12:15 pm    Post subject: Reply with quote
Thanks!
nextgen
nextgen is offline
PostPosted: Fri Aug 27, 2010 12:57 pm    Post subject: Reply with quote
I am sure it weights much more then a henweigh !!!!!!!
email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs
grueni
grueni is offline
PostPosted: Fri Aug 27, 2010 1:10 pm    Post subject: Reply with quote
http://www.gw-autoteile.de/Service/Kaefer10.htm
its german, but everybody can read it
motorengewicht...
1960 1584cc turbocharged, 35,5/32 (11,117s 1/4mile )
Hippie
Samba Tinner
Hippie is offline
PostPosted: Fri Aug 27, 2010 2:23 pm    Post subject: Reply with quote
That's for sure. Almost as much as a piecost weighs!
vwinnovator
vwinnovator is offline
PostPosted: Fri Aug 27, 2010 6:00 pm    Post subject: Reply with quote
[quote="nsracing"]a longblock on a small pallet was 350 lbs or so. quote]
must of been a 200+ lb. pallet Shocked
I have no problem lifting longblocks w/ stroker cranks, flywheel, and sump off my bench. 125-150 lbs max.
vintageant
vintageant is offline
PostPosted: Sat Apr 19, 2014 10:02 am    Post subject: Reply with quote
1600 cc: engine weight, dry 115 kg x 2.205 = 254 lbs
stealth67vw
stealth67vw is offline
PostPosted: Sat Apr 19, 2014 12:37 pm    Post subject: Reply with quote
X2
John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2050lbs with driver
7.76 @ 89.55mph 1/8 mile
12.27 @ 109.56 mph 1/4 mile
https://youtube.com/shorts/GmifEu5QvnA?si=OIw8eM7QU3LMhtiz
https://www.tiktok.com/t/ZT68foYFS/
rockurob
rockurob is offline
PostPosted: Sat Apr 19, 2014 12:47 pm    Post subject: Reply with quote
INTERESTING SITE: Lots of engines with transmissions
with reference to source
VW flat-4 air cooled 215 with heater boxes; 180 stripped
**Kennedy Engineered Products adapter catalog**
(guess one has to use their imagination what stripped means)
(but did find shipping weight on one heater box at 25 lbs ... guess that
includes the shipping box with packing at Pierside Parts)
another reference:
VW flat-4 Type 1 250 lbs 1600cc dual port, stock flywheel,
clutch, doghouse oil cooler, Monza
muffler, Bosch alternator, twin
Solex/Kadron carbs with manifolds and
linkage, heater boxes, all sheet metal,
without oil
http://fixrambler.com/engineweightchart.txt
70's....Owner "Der Bug Shoppe" Okla. City
70 Baja Street Rod Project
https://www.thesamba.com/vw/gallery/pix/1644125.jpg
Drag Buggy project:
https://www.thesamba.com/vw/gallery/pix/1726674.jpg
61 Rag Project:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1188580
neil68
neil68 is offline
PostPosted: Sat Apr 19, 2014 12:55 pm    Post subject: Re: How much does a fully built type 1 engine weigh? Reply with quote
By fully built, I take it that you mean dual carbs, header, etc. Mine weighs 264 lb with IDA's and header/muffler.
Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
Cptn. Calzone
Cptn. Calzone is offline
PostPosted: Sun Apr 20, 2014 6:16 am    Post subject: weight Reply with quote
Fully dressed more than you wanna lift alone and more than you wanna pay to ship.Somehow the shipping is always more weight I think the Jabo who does the weigh in has his big size 15 steel toe boot on the scale
71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse
77charger
77charger is offline
PostPosted: Mon Apr 21, 2014 9:02 pm    Post subject: Reply with quote
my alm cased 2275 with 12 pound f/w,dual 44s,with tri mil header,ready to run with pressure plate,clutch disc,and oil was 259 pounds
Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine
