Rear Axle Epic Fail
blyhigh
blyhigh is offline
PostPosted: Sat Sep 18, 2010 3:52 pm    Post subject: Rear Axle Epic Fail Reply with quote
Can anybody explain this? Bought an '89 Syncro Westy 4 years ago. Drove it from the west coast to the east coast. By the time I arrived the left rear axle was clanking. Outside CV joint was dry as a bone. Had the axle replaced. Drove it from the east coast to the west coast. In Idaho the left rear axle began to clank. Same thing: outside CV joint was dry as a bone. Over the last four years the left rear axle via the inside or outside CV joint has failed six (6) times. Yes, six. I've replaced with Empi. I've replaced with Lobro. I've replaced with rebuilds. I've had four different garages replace the axle (twice by gowesty) or boots and it always fails - once with only 2000 miles on it. I do not go off road. These are highway miles with a 2.4 gowesty engine and a solid shaft with decoupler. At this late date I've come to the conclusion that there's gotta be something with the van that's causing the problem. But what? Any of yous got any ideas? Thanks.
Max
'89 Syncro Westy (with a bad axletude)
otiswesty
otiswesty is offline
PostPosted: Sat Sep 18, 2010 4:07 pm    Post subject: Reply with quote
Is your van lifted?
Lifting springs or spacers will change the angle at the CV and increase wear and failure frequency.
If your van is lifted, you can go back to stock springs or replace the CV joints with the 930 Porsche style that have a greater tolerance for the increased angles.
1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy
syncrodoka
syncrodoka is offline
PostPosted: Sat Sep 18, 2010 4:14 pm    Post subject: Reply with quote
I've had that happen many times with the boots they are just junk.
Put more grease than they provide in the kit and use a rockford 339-22 boot.
http://www.thesamba.com/vw/forum/viewtopic.php?t=243777&highlight=rockford
Alaric.H
Alaric.H is offline
PostPosted: Sat Sep 18, 2010 5:19 pm    Post subject: Reply with quote
I have seen worse.
syncrodoka
PostPosted: Sat Sep 18, 2010 6:25 pm    Post subject: Reply with quote
Yeah, he is horrid Shocked
Laughing Laughing Laughing
Classicvibe
Classicvibe is offline
PostPosted: Sat Sep 18, 2010 8:36 pm    Post subject: Reply with quote
So just to clarify, are you saying that every fail has had a completely dry boot on either the inside our outside, but only on one side of the van?
You could just take some initial measurements on the height of the van at each wheel. You could go these easy route and look for a larger high quality boot. I think the 930 upgrade is such a no-brainer though. It would be nice to know that would for sure be the fix before jumping in.
Hmm, thinking...
On a mission, the destination is just an excuse.
Syncro Solstice 2022...see you there!
1986.5 Wolfsburg Syncro Westfalia Poptop Weekender Transporter
euromog
euromog is offline
PostPosted: Sat Sep 18, 2010 10:39 pm    Post subject: Reply with quote
I bet if you installed a new viscous coupler and drove in all wheel drive all the time your problem would go away. You have added more HP and cut the distribution of that HP by half. I am seeing rear CV failures more and more on Syncro's with a decoupler. The 930 CV's will hold up better but you will still have to repack them every 10k OR 15k miles. If Peloquin ever gets his VC replacement diff it will make things even better.
Alaric.H
Alaric.H is offline
PostPosted: Sun Sep 19, 2010 4:49 am    Post subject: Reply with quote
Excuse me but what is a VC replacement diff?
blyhigh
blyhigh is offline
PostPosted: Sun Sep 19, 2010 9:38 am    Post subject: Reply with quote
yes. van is lifted. didn't think of that. and, yes, it's always on the left rear, either inside or outside boot is dried out or torn as in the picture. when you say 930 upgrade are you talking about the whole deal: axle, stub axle, boots, etc? or just the upgraded boot?
IdahoDoug
IdahoDoug is offline
PostPosted: Sun Sep 19, 2010 9:57 am    Post subject: Reply with quote
If it's lifted, not only to you have a steeper running angle in terms of CV wear and boot wear, but when I look at my rear suspension (stock) it appears that a lift would also lengthen the axle. That means the boot is also stretched more than usual in the installation - again adding to the stress of the boot. These two changes taken together could make a difference in boot life.
Then, another thought occurred that may explain why the left one. When driving on the road, the crown (slope for water runoff) leans vehicles to the right. On the Van, that would extend the left suspension, making the boot stretch even more while doing the opposite on the right boot - helping that side last longer.
So, I'd be interested in a precise measurement. Perhaps you could find a way to have the small end of the boot mount on the axle closer to the joint to reduce the stretching effect. May require machining off the lip on the axle shaft for this purpose, or epoxying on a lip in closer.
Anyhow just an observation due to the suspension geometry. I'm assuming your lift is a normal suspension lift. Perhaps this issue is why the Syncro lift is a body lift, leaving the engine/trans down at the normal level to avoid changing the axle running angles.
DougM
Jon_slider
Jon_slider is offline
PostPosted: Sun Sep 19, 2010 10:07 am    Post subject: Reply with quote
youre seriously jinxed
dry as a bone explains it.. as to why its going dry.. bad boot like syncrodoka said?
so are you saying you Never engage the solid shaft on pavement, or do you?
and are you saying your axles break with rear wheel drive only?
Or do you drive like other (unnamed) people who break stuff in their drivetrain?
interesting observation John, nice to see you posting here
any chance the CV failures are associated with folks who have solid shafts?
or, do the people who break stuff have motors with more torque than a subaru 2.2?
for example, the OP has a 160 ft lb motor, similar to a subie 2.5...
or is the breakage associated with lifted vans, regardless of what kind of motor or whether they have a solid shaft, or whether they have a decoupler..?
curiouser and curiouser
most of the people I know who break axles, do it by engaging a solid shaft after getting stuck offroad (I know a couple people engage solid shafts on pavement for wind stability, and get away with it... risky business),
I also hear of broken axles/CV's/ring and pinions from folks running a motor with more than 200ft lbs of torque, like the SVX, 1.8T or some chipped TDi's..
Some of those SVX vans are not lifted, and do not have solid shafts nor decouplers.. I think the drivers just like to punch the gas.. (hard to resist when youve got it)
fwiw, my syncro westy is lifted with syncro.org springs, to 18.5" fender to axle height, 27" tires, and has never broken an axle.. it has a 2.2 subie, a viscous coupling, and no decoupler
Alaric.H
Alaric.H is offline
PostPosted: Sun Sep 19, 2010 10:10 am    Post subject: Reply with quote
You could try takeing the little clamp off the end of the boot.
euromog
euromog is offline
PostPosted: Sun Sep 19, 2010 10:14 am    Post subject: Reply with quote
A differential with gears that would compensate for the difference in rotation of the rear axle versus the front axle. Land Rover Discovery for example is also all wheel drive and uses a differential in the transfer case. On the Disco it is also lockable for true 4WD. The differential that Peloquin has been working on would also be lockable.
When the decouplers first became available most Syncro owners still had stock WBX and were not lifting their vans more than a 19.5" ride hieght which is actually a stock specification. Now they are going above 20" and installing engines that have at least 50% more torque and horsepower. The trend is also to accessorize the Westy's with more equipment and they are becoming extremely heavy. Expecting the CV joints that were originally designed to handle 50HP in much lighter Bay window bus to handle the above is a bit ridiculous.
That is why when I built my SyncroMog ten years ago installing 930 CV joints and stronger axles front and rear was the first thing I did. I still have not broken an axle or CV joint but I do repack the rear CV's almost annually.
IdahoDoug
PostPosted: Sun Sep 19, 2010 10:38 am    Post subject: Reply with quote
Any time you're replacing a 'soft' connection (VC, open diff) with a 'hard' one (solid shaft/decoupler, locker) you're adding a lot of stress to the axles/CVs. I don't think I'm telling anyone anything new with this statement, but I suspect not many understand how MUCH stress.
Here's something few will know that communicates this well. When you do a burnout with a vehicle or are stuck offroad and a spinning tire suddenly hooks up on a rock, the axle shaft is literally twisted - sometimes as much as a full revolution. It rebounds because it's made to do that. Now I realize Vanagons aren't doing burnouts but it serves to make the point that there are a lot of stresses going on some may underestimate. And these axles twist and rebound under duress all the time. So, lots of force even with an anemic stock engine and the axles were matched to the expected forces.
Back to the solid connections. The engineers that built the Syncro undoubtedly tested the system in numerous destructive testing scenarios and measured the force spikes, choosing the metallurgy and other things to ensure reliability. The VC allows some shock forces to be absorbed gently and indeed the heat generated to activate the VC is literally energy absorbed and turned into heat. Remove this and you can generate force spikes in the axles and driveshafts far higher than VW envisioned. Do that enough times and the CV joints have pitted surfaces and metal dust in the grease around the balls. Change the angle of the CV so it's experiencing radial forces (trying to straighten itself each time a ball scrapes across the cage surface) and the joint is wearing itself perhaps at 3 times the normal rate. Add a more powerful engine. Now you've got a paste of metallic grease in the wear areas, much more heat (which shortens boot life, too), more power and higher force spikes. Under these circumstances, the only way to have acceptable component life would be very aggressive grease repacking and using premium synthetic greases. In the absence of this aggressive servicing, the expected outcome would be shortened component life - perhaps dramatically.
So, some random thoughts on drivetrain modifications.
Classicvibe
PostPosted: Sun Sep 19, 2010 2:01 pm    Post subject: Reply with quote
That is all nice analysis Doug. I am thinking on your random thoughts now, mainly deconstructing your 'run-off' scenario for the left rears...interesting! Could the height difference be just enough to allow for that fail? Hmmmm...
blyhigh
blyhigh is offline
PostPosted: Sun Sep 19, 2010 8:35 pm    Post subject: Reply with quote
I haven't actually broken an axle - or anything for that matter. I rarely engage the solid shaft, just check to make sure that it's working now and again. What seems to fail are the boots which in turn kill the joints themselves. Lot of interesting info here, but I'm wondering if I can get away with the larger 100mm boots or is this a question of installing the whole 930 axle set up left and right. Will that do the trick? Thanks for the help, btw. Can always count on The Samba.
otiswesty
PostPosted: Sun Sep 19, 2010 9:51 pm    Post subject: Reply with quote
I had the impression in your initial post that you were having CV joint failure, with a dry boot noted. It would seem that a higher quality boot with annual service of the CV with grease repacking would be the key for you. That assumes that your boot is losing all the grease and as such is the cause of premature CV joint failure.
Hard to say exactly what is going on. Maybe the lift is contributing, but I would start with the better boots and grease, recheck in 12 months, and go from there.
Just a regular guy
IdahoDoug
PostPosted: Sun Sep 19, 2010 9:54 pm    Post subject: Reply with quote
By complete coincidence, I was repacking an axle this evening and noticed that the inner CV has a startling amount of designed in play so the shaft can essentially elongate with suspension movement. So, it could certainly be rough on boots if you're lifted and the shaft's elongated and stretching them in everyday operation. I put the Lo.. something boots on and they were pretty inelastic but everyone seems to rate them OK for durability. I could easily see where if you have a similar boot or this stiff material is typical Vanagon fare that they would not take that long.
DougM
Bassyaks
Bassyaks is offline
PostPosted: Thu Aug 13, 2015 2:22 pm    Post subject: Reply with quote
This is a little off topic but, if an rear axle fails, will the fronts still function with a straight shaft?
Can the van limp home?
mrshrimp
mrshrimp is offline
PostPosted: Thu Aug 13, 2015 3:05 pm    Post subject: Reply with quote
Only if you engage the rear locker. Other wise, coupled and in all wheel drive with a solid shaft, all the power will go to removed (or Busted) axle. Speaking from experience. Once removed the the rear passenger axle after it failed. And drove home 150 miles three legged coupled, with rear locker engaged, and solid shaft. Just dont turn sharp with the rear locker on!
...another reason why I like the decoupler w/solid shaft and rear locker combo. But I guess you could do the same with a VC and rear locker?
