Odd transmission hesitation
obnoxiousblue
obnoxiousblue is offline
PostPosted: Fri Oct 22, 2010 5:17 pm    Post subject: Odd transmission hesitation Reply with quote
Hey guys, just replaced the transmission on my 1977 2.0FI type 4 powered baywindow. Got a new transmission from Rancho, and installed it, along with a new clutch, pressure plate, and throw out bearing this passed weekend.
After getting it in and taking it around on a few local miles, I find a 'skipping' or 'hesitating' feeling when I hit the roughly 60MPH mark. It feels rather like a tapping of the brakes, or as if I were depressing the clutch pedal while in gear. Now, Im not certain that its a transmission related hesitation. I checked everything on the outside, and from what I can tell its all good. I did find that the axle bolts to the transmission were left a bit loose but I tightend them all down, and still have the skipping feeling. I looked around my engine bay, and dont see any loose hoses, or wires.
Does anyone have an idea I should look into.
Also, does anyone have a vacuum diagram for my engine?
Thanks guys!
Mike
Mike
1964 Beetle
2001 Eurovan Camper
Westfabulous
Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Westfabulous is offline
PostPosted: Fri Oct 22, 2010 6:07 pm    Post subject: Reply with quote
Check your timing, points, cap and rotor. What you describe is exactly what I experienced with my 1991 Passat. After a long witch hunt, I found that it was the timing. Once set properly, the surging / skipping was gone.
"I will gladly pay you Tuesday for a hamburger today."
dubstar
dubstar is offline
PostPosted: Sat Oct 23, 2010 10:28 am    Post subject: Reply with quote
so...why did you delete the samba post?
1963 Type II Kombi
1977 Type I Fuel Injection
http://instagram.com/john_aka_dubstar/
http://web.stagram.com/n/john_aka_dubstar/
"you could transport really tall things too, like a giraffe"
obnoxiousblue
PostPosted: Sat Oct 23, 2010 3:00 pm    Post subject: Reply with quote
Delete what samba post john?
Mike
1964 Beetle
2001 Eurovan Camper
dubstar
dubstar is offline
PostPosted: Sat Oct 23, 2010 5:17 pm    Post subject: Reply with quote
oops...I thought this was das volks Confused
1963 Type II Kombi
