Rear Main Seal
cannonfodder4j
cannonfodder4j is offline
PostPosted: Mon Nov 22, 2010 4:37 pm    Post subject: Rear Main Seal Reply with quote
Hey everyone! i recently bought a 1985 VW Vanagon which had a pretty bad oil leak. I researched the leak and found that it was a busted rear main seal. I spent the last two days in the shop pulling the transmission and accessing the seal. It was busted so i replaced it. The problem is that when i put it all back together and started it up, the van was leaking stronger than ever. Does anyone have any suggestions? Im getting really desperate. Thanks
Cold Steel
Cold Steel is offline
PostPosted: Mon Nov 22, 2010 5:26 pm    Post subject: Reply with quote
try this to see if it helps.
http://www.thesamba.com/vw/forum/viewtopic.php?t=412077&highlight=
did you counter sink the seal?
91 Syncro
I am a samba thread just waiting to happen!
"Advanced Syncroist"
peasant
peasant is offline
PostPosted: Mon Nov 22, 2010 11:05 pm    Post subject: Reply with quote
Theres a good boston bob video tutorial of replacing the rear main seal. Havn't been able to find a good recent link though.
edit: people also say the Sabo seals are the best too.
89 wolfsberg weekender carat
89 Westfalia
cannonfodder4j
PostPosted: Tue Nov 23, 2010 6:29 am    Post subject: Reply with quote
I had another mechanic check my work and he used the old seal to hammer it in flush so i really dont know what else i could do. I couldnt find the Boston Bob link either
Wildthings
Wildthings is offline
PostPosted: Tue Nov 23, 2010 8:47 am    Post subject: Reply with quote
You are going to have to pull the engine again no matter what. What brand of seal did you use? You can put a thin smear of grease on the flywheel sealing surface and then slide the flywheel into place to see where the new seal rides.
?Waldo?
?Waldo? is offline
PostPosted: Tue Nov 23, 2010 8:50 am    Post subject: Reply with quote
Check the galley plugs.
I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site.
cannonfodder4j
PostPosted: Tue Nov 23, 2010 10:02 am    Post subject: Reply with quote
I think the seal was an OEM im not sure though the guy who sold the van to me gave the seal as well.
joemac
joemac is offline
PostPosted: Tue Nov 23, 2010 10:55 am    Post subject: Reply with quote
Uh... if it's the seal behind the flywheel, and the flywheel faces the front of the vehicle, shouldn't it be referred to as the "front main seal"?
tencentlife
tencentlife is offline
PostPosted: Tue Nov 23, 2010 11:26 am    Post subject: Reply with quote
Please let's not get into THAT silly discussion again.
You can pop new seals in and out 'til they cart you off, but if your flywheel has a deep groove on the seal hub it will still leak, repositioning the seal at a different depth will not help, instead that will trash the new seal even quicker. If the groove is deep enough to catch your fingernail in, it is too far gone and you should find a new FW or replacement in better condition, but grooves shallower than that can be improved.
The FW can be set up in a lathe or other device to turn it steadily (I have done them by hand bolted to a crankshaft and that laid in V-blocks, but made an adapter for my lathe) and the groove abraded out and polished by using successively finer grades of abrasive paper or cloth (emery is preferred for steel), lubricate generously with WD40 or something light. Start with a 40-grit, work up to 1200 or 2000. Take your time and get it to as smooth a finish as possible. Extra points for doing a final polish with a cotton buff and suitable polishing compound.
Lube the new seal lip and the FW hub with medium oil or grease. Be sure to install a fresh o-ring, oiled, in the FW hub. Deburr the nose of the crank so the o-ring goes on smoothly, and smear oil on it. If you observe these procedures you can get a leak-free main seal, in my experience anything short of these steps means you will be doing the job over.
Experience is death to doctrine.
cannonfodder4j
PostPosted: Tue Nov 23, 2010 12:38 pm    Post subject: Reply with quote
thanks for the info ill definitely have a look when i work on it on sunday. I'm just waiting for a replacement seal to arrive. I suddenly am unsure whether or not greased the seal. Would it have mad a big difference?
?Waldo?
?Waldo? is offline
PostPosted: Tue Nov 23, 2010 12:46 pm    Post subject: Reply with quote
Is that a sumpimus or a mumpsimus? If the point to words is to communicate, then why nitpick when you know what someone is talking about? It is colloquially acceptable to call the flywheel seal the rear main...
If one of the galley plugs is leaking, then no amount of care installing the seal/flywheel will cure it. This is coming from someone who R+R'd a transmission four times in order to cure the leak...
joemac
joemac is offline
PostPosted: Tue Nov 23, 2010 1:27 pm    Post subject: Reply with quote
Hey, I was simply making an observation.
Check that stupid cam plug for leakage. I say stupid because there was nothing wrong with the steel plug that was used for decades.
Another point: the farther out the seal is placed in the crankcase, the tighter it seals against the bell of the flywheel hub. Setting the seal farther into the case allows for leakage even if a perfectly good flywheel is used.
Yet another point: how much crankshaft end play is there? Too much will hammer the seal, and more importantly, the thrust bearing.
EvilDNA
EvilDNA is offline
PostPosted: Tue Nov 23, 2010 11:51 pm    Post subject: Reply with quote
Finally. I managed to post the Boston Bob video I dug up from an old backup. WMV, Picasa and Mac DO NOT PLAY WELL TOGETHER! After the conversion and upload, etc. the video is worse than the original but nonetheless . . .
http://picasaweb.google.com/vwvanagons/BostonBobFlywheelVideo#
1990 4 Speed Orly Blue Multivan
cannonfodder4j
PostPosted: Wed Nov 24, 2010 8:06 am    Post subject: Reply with quote
woah thanks so much that videos really incredible. thanks a lot!!! Very Happy
joemac
joemac is offline
PostPosted: Wed Nov 24, 2010 9:17 am    Post subject: Reply with quote
There is so much wrong with that video, I don't know where to start.
You don't drive a needle pilot bearing in with a hammer. Nor do you drive a flywheel seal in with a hammer. Any knowledgeable technician owns and uses bushing/bearing installers. That's what they're designed for.
I guarantee that after that engine has developed oil pressure, the crankshaft end play will have diminished by .0015", due to the coating of oil that forms between the shims/thrust. Any time you measure and adjust something that deals with flowing lubricant, you must compensate by simulating the conditions of operation. When rebuilding transmissions, you simulate running conditions when adjusting the gear package by actually pouring gear oil over the gears while cranking the mainshaft, which SIMULATES RUNNING CONDITIONS. Likewise, you want the shims/ thrust coated with engine oil to SIMULATE RUNNING CONDITIONS.
And to me, it is NOT perfectly acceptable to call the front main seal by anything other than its correct name. Don't point to a bolt and call it a nut. Yeah, I may know what you mean, but if that's the only criteria, let's just go back to pointing and grunting. Evil or Very Mad
Wildthings
PostPosted: Wed Nov 24, 2010 9:31 am    Post subject: Reply with quote
It is perfectly acceptable to call a rear main seal by its correct name, REAR MAIN SEAL. This has been standard engine terminology for a hundred years. The naming convention doesn't change because the engine is installed backwards or sideways in the vehicle. Have you ever heard the crank seal on a transverse engine called the left main seal or right main seal. No likely.
Best to call the rear main seal on a backwards mounted VW or Porsch engine the flywheel seal though as it causes less confusion.
sanchius Premium Member
sanchius is offline
PostPosted: Wed Nov 24, 2010 9:42 am    Post subject: Re: Rear Main Seal Reply with quote
I think I ran across a situation where the engine was just too worn out to fix a flywheel main seal leak without cracking the case and updating all the bearings. I tried replacing the seal 3 times & JBwelded all possible leak points before giving up and putting in a different used engine that I had. I used exactly the same seal replacement technique(as per the BB video) & the same flywheel in all cases and the original engine leaked every time and the replacement engine sealed fine the 1st try.
?Waldo?
?Waldo? is offline
PostPosted: Wed Nov 24, 2010 10:41 am    Post subject: Reply with quote
On a front-engined vehicle is the left main seal on the driver's or passenger's side?
Wildthings
PostPosted: Wed Nov 24, 2010 12:05 pm    Post subject: Reply with quote
Good question. Maybe we should just identify it as the driver's side seal or the passenger's side seal, this might create a problem for the bloody Brits though.
iltis74
iltis74 is offline
PostPosted: Wed Nov 24, 2010 1:38 pm    Post subject: Reply with quote
So is the guy in the jump seat looking out back through the windshield? I mean, the factory did orient him that way. Man this is funner than I thought. In the end of course you can call it whatever you want, don't bother me, I know what it is.
