Komissar Samba Member
Joined: May 18, 2008 Posts: 894 Location: Bucharest, Romania
Posted: Sat Dec 11, 2010 8:52 am Post subject: Stock air cleaner on weber ICT's - DIY. |
Hello,
Here is my for installing the stock aircleaner in a type 3 using Weber ICT (or clones of ICT's ) carbs.
I'll let the pictures speak for themselves.
Sorry for the awfull looking weld... it was done in a hurry, but it's sturdy enough.
The ideea is to use the castings on the ICT's body that on other variations were used for having a manual choke. Drill those mountings and insert two M6 screws as my picture shows.
The linkage i've made is a DIY cable linkage needed in order to install the air filter. I've used good quality bike handbrake cable and conduit, the wire was lubed up prior to install and i've made sure that the wires and the conduit were exactly the same lengths.
I've done a couple of runs with this setup and it seem to function well.
One thing though ... the accelerator pedal feels stiffer because of the cable linkage.
Sorry also for the dirty and "run down" look of the motor - it's been put together on an Eastern Europe budget
Uploaded with ImageShack.us
Uploaded with ImageShack.us _________________ 1965 Sunroof Beetle
1972 Type 3 Squareback
1978 Skoda 105S |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11497 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Sat Dec 11, 2010 10:06 am Post subject: |
why not use stock Solex's? _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Sat Dec 11, 2010 10:17 am Post subject: |
| blankmange wrote: |
| why not use stock Solex's? |
Because that would defeat the point of doing this mod. _________________
| zeen wrote: |
| Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
Posted: Sat Dec 11, 2010 10:21 am Post subject: |
That could be asked every time someone swapped Solex'es with ICT and still people do it...
In my particular case, the stock Solex carbs were busted, ( worn out) ,and after 3 weekes of fiddling with them , soakin in carb cleaner and so on, (while my car was either running rich, poofing black smoke, and yet beeing unable to run faster than 50kmh ) i got tired of that and replaced them.
A pair of "new" professional rebuild Solex carbs is out of my budget's reach.
Those carbs you see pictured there were less than 10 $ each. _________________ 1965 Sunroof Beetle
1978 Skoda 105S |
supaninja Samba Member
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25186 Location: Central Iowa
Posted: Sat Dec 11, 2010 12:28 pm Post subject: |
Just telling it like it is. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sat Dec 11, 2010 12:38 pm Post subject: |
| supaninja wrote: |
| blankmange wrote: |
Not all of us like stock.
Kudo's for running weber's and keeping the stock air cleaner, all the purist's now won't having the usual "your drawing in hot air from the engine compartment" reply...damn does that one get old. |
the stock Solex's can breathe just as freely as the ICT's, and require NO modifications for the stock oil breather... on the other hand, the first chunk of metal that falls from that welded-together bolt in the throat of that ICT has the potential to destroy the engine...
and if you don't understand how breathing in hot air effects an engine's performance vs breathing in cold air, you are really missing the point... _________________ póg mo thóin
Posted: Sat Dec 11, 2010 1:11 pm Post subject: |
A chunk of metal falling from that welded bolt is the last thing that can happen ...
The weld itself is solid. The big bolt facing upwards it's held by the airfilter itself. The two horizontal bolts are held in place by having their hex head through the tight hole and outside the carb. Even if the assembly unbolts itself, it cannot fall into the carb.
And yeah.. for a stock aplication I value the Solex carbs, however, I have explained above (a couple of posts above, that is ) why i made this choice.
And I've posted this pictures hoping to inspire others that might want to do this (maybe to a non-stock aplication such as bigger engine and bigger carbs). _________________ 1965 Sunroof Beetle
1978 Skoda 105S |
Posted: Sat Dec 11, 2010 1:50 pm Post subject: |
| blankmange wrote: |
| supaninja wrote: |
| blankmange wrote: |
and if you don't understand how breathing in hot air effects an engine's performance vs breathing in cold air, you are really missing the point... |
I think I understand how IATs affect power/detention just fine. I got somewhere a dyno sheet for my Honda, first pull 371whp, second pull 355, third pull 350whp. Power went down as IATs went up. Most of you guys are running stock motors, high IATs aren't going to make a huge difference. Good stock parts are getting harder and harder to find.
I like seeing some creativity, that's what's going to keep these cars on the road. _________________ http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/ |
ddesh Samba Member
Joined: February 20, 2005 Posts: 165 Location: NW AR.
Posted: Sat Dec 11, 2010 1:59 pm Post subject: |
| let me trow my two cents in and say the position of the cross bolt right over top of the venturi isnt helping your airflow .stock carbs do run well with big engines if they are set up right. |
Posted: Sat Dec 11, 2010 2:00 pm Post subject: |
| ddesh wrote: |
| let me trow my two cents in and say the position of the cross bolt right over top of the venturi isnt helping your airflow .stock-bodied carbs do run well with big engines if they are set up right. |
tweaked that just a bit for you, Danny... _________________ póg mo thóin
ddesh Samba Member
Posted: Sat Dec 11, 2010 2:01 pm Post subject: |
| thanks Dave |
vwfye Samba Member
Posted: Sat Dec 11, 2010 2:31 pm Post subject: |
ICTs can and will match all performance of a solex if set up correctly. also, $20 buck for a pair of carbs and time for the welding for a running car is a pretty cheap fix. some of us don't care about stock _________________ 64 No'back Speedster "Pearl"
LME "Little Giant Killer 3"
1974 Ghia "PUK" |
marchi Samba Member
Joined: August 10, 2005 Posts: 646 Location: Abilene, Texas
Posted: Sat Dec 11, 2010 3:13 pm Post subject: |
All that metters is the owners opinion, gives a twist when u look at it. Thinkin stock set-up but wait its not. Looks cool but could use a lil clean up/perfection, but thats what we do with old VW's _________________ I drive my VW or I walk
'70 Squareback
'21 Tiguan (daughters)
SOLD
'69 Fastback (Flamer) |
69sback Samba Member
Joined: March 06, 2010 Posts: 216 Location: Somewhere
Posted: Wed Apr 11, 2012 2:33 pm Post subject: |
| any think pulling hot air from the engine compartment will cause the engine to run cooler? I'm thinking about doing the same mod, solely for the purpose of cooling the engine... |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 5325 Location: Southern AB
Posted: Wed Apr 11, 2012 4:01 pm Post subject: |
one thing that comes to mind is ...how much air can you pull through the stock fresh air intake? I would say that would limit top end rpm since it is a small hole.
i have wondered why someone hasn't fabbed a thin/wide intake/ filter that spans the carbs (whichever flavor you like) and draws from both stock fresh air and from ahead of the transmission like the Cal-look cooling mod for beetles. it would just be bigger than the stock oil bath to flow more air.
must be those dark side cookies i had for lunch  _________________ 1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap |
