69rulz Samba Member
Joined: June 07, 2009 Posts: 867 Location: On a trip on my couch
Posted: Fri Dec 17, 2010 1:26 pm Post subject: 1973 ghia engine and a 68-71 bus generator will not fit |
today i found out the hard was that i have a 1973 karmann ghia engine and a 68-71 bus generator will not!!! fit right, it extends too far out and screws the belt up, just saying make sure! |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Fri Dec 17, 2010 1:31 pm Post subject: |
yes, it will fit if you have all the correct mounting parts. apparently you do not. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
69rulz Samba Member
Posted: Fri Dec 17, 2010 7:12 pm Post subject: |
the belts on yes, and ive been riding on it for months, but the belt sits at a weird angle and loses tension about every 2 months, what hardware do i need to fix this? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51173 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Dec 17, 2010 7:14 pm Post subject: |
If it's indeed a 38 amp generator you'll need the dished bus only backing plates and the bus only fan hub, likely the bus only pulley as well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
69rulz Samba Member
Posted: Fri Dec 17, 2010 7:17 pm Post subject: |
busdaddy wrote: |
If it's indeed a 38 amp generator you'll need the dished bus only backing plates and the bus only fan hub, likely the bus only pulley as well. |
damn, i knew i probably needed that dished backing plate, and i need a different fan as well? |
SGKent Samba Member
Posted: Fri Dec 17, 2010 8:11 pm Post subject: |
69rulz wrote: |
busdaddy wrote: |
does needed infer oh darn I tossed it? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Dec 17, 2010 8:20 pm Post subject: |
Same fan (27 or 32 mm depending if it's doghouse or not) 30 amp or 38 amp. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
69rulz Samba Member
Posted: Sat Dec 18, 2010 2:19 pm Post subject: |
SGKent wrote: |
69rulz wrote: |
busdaddy wrote: |
does needed infer oh darn I tossed it? |
no it infers i shoudve bought one a year ago when i saw one hahaha |
