RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Sun Sep 11, 2011 10:27 am Post subject: |
Crank trigger and Nissan conversions are all great and high tech......but nothing is as cool as real dual distributors.
As to precision timing.....
If you have a friend with a dual trace scope you can look at timing in real time relative to each other and adjust. Of course, every time you touch or replace the points you have to go thru it again but you have to anyway, right? The scope will let you observe the relative advance of each distributor also.
HaHa! Now that I posted that little tidbit I'm going to stop shopping for a used distributor machine and build a fixture to use MY scope! Just need a small DC drive motor......wait, or everyone will be building one.
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
Shadd Samba Member
Joined: January 18, 2007 Posts: 883 Location: Lancaster, Ohio
Posted: Sun Sep 11, 2011 9:29 pm Post subject: |
I have a dual trace scope and a sun distributor machine. I could do it for you. |
Shadd Samba Member
Posted: Sun Sep 11, 2011 9:36 pm Post subject: |
JeffL wrote: |
The Model T actually had 4 coils (sometimes called buzzers)... |
Its called a trembler. As an experiment I connected up a model T coil to my bug. Ran great. |
Posted: Sat Dec 10, 2011 9:29 am Post subject: |
Ninamashr, did you ever post the gear, shaft and bushing numbers? I have a customer who would kike one built and did not laugh at the ridiculous price (I thought) that I quoted. In reality, I had said that it wasn't practical from a time standpoint and the price reflects my estimated time. Anyway, why reinvent the wheel, right? I hope you're have success with the device as the design is pretty fundamental and sound appearing. Also hope you don't mind a bit of plagiarism...
Plagiarism is the sincerest form of flattery.....or something like that! hahaha
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Sat Dec 10, 2011 1:12 pm Post subject: |
RockCrusher-
Your other option is to puchase a dual distributor unit from Precison Matters, and recurve the distributors to suit your customer's motor.
http://www.precisionmatters.biz/twin-plug-ignition.php
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
GüteAndTite Early Convertible Güru
Joined: June 16, 2005 Posts: 2144 Location: Low So Cal
Posted: Sat Dec 10, 2011 1:46 pm Post subject: |
Could but that won't fit the customer's application....4 cylinder 911. _________________ [email protected] Please use email for all general inquiries.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76976 Location: Sneaking up behind you
Posted: Sat Dec 10, 2011 10:07 pm Post subject: |
RockCrusher wrote: |
Could but that won't fit the customer's application....4 cylinder 911. |
_________________ Glenn
Member #1009
#BlueSquare |
Ninamashr Samba Member
Joined: October 12, 2005 Posts: 1400 Location: City of Round Rock in the Great State of Texas
Posted: Mon Dec 12, 2011 8:53 am Post subject: |
Sorry guys for not replying but I've been really swamped lately...
LevTitan: I wanted to keep the rotation of the internal weights of the 019 the same as stock. It just didn't feel right to spin the weights in the opposite direction they were designed to go. The weights are offset and I did not want to have any problems. Maybe Glenn will chime in and let us know if there are any problems with the advance system spinning counter clockwise as opposed to clockwise.
Rockcrusher: I haven't posted the gear numbers etc yet because they can only be used if you want to make one exactly like mine. The gear size is dependent on the pitch diameter and center gear distance, so if you go with my style, "side winder style", I'll send ya the part#s. If you want to make one, "split style", center shaft turning 2 dists, you'll have to get 5 gears and daisy chain them. As a matter of fact I have 5 left over that I EDM'd from old oil pump gears that should work for that style. I also have the 2 pins I made for the intermediate gears you will need for the split style.
guteandtite: I might be able to make a kit with the aluminum housing, lid, and parts list but you will need somebody with a lathe to finish it for you. _________________ 1957 Karmann Kabriolet "Franky"
1957 Allstate trailer |
Posted: Mon Dec 12, 2011 6:23 pm Post subject: |
Thanks for the reply Ninamashr.
Yes I'm interested in the sidewinder and as I said....why reinvent the wheel?
You unit turned out so nicely and has a classic style. The split style won't fit the 911 4 banger. I've been itching to do this for myself as well so please do post the #'s or email me. I would very much appreciate it. And, hey kit style that just needs finishing is a good way for me as well. I can do it all but it wouldn't have the nice Bosche script in the side.
Glenn Mr. 010
Posted: Mon Dec 12, 2011 6:27 pm Post subject: |
Ninamashr wrote: |
LevTitan: I wanted to keep the rotation of the internal weights of the 019 the same as stock. It just didn't feel right to spin the weights in the opposite direction they were designed to go. The weights are offset and I did not want to have any problems. Maybe Glenn will chime in and let us know if there are any problems with the advance system spinning counter clockwise as opposed to clockwise. |
It absolutely would not work if spun CCW.
Member #1009
#BlueSquare |
volkaholic1 Samba Member
Posted: Wed Dec 14, 2011 10:42 am Post subject: |
I stumbled across this, truely some amazing work you have done. Very impressive. I see folks found my pics of my blue turbo ghia with twin plug heads running the 009 with a Datsun cap. I really enjoyed that car! I did a few versions over the years, but nothing compared to what you have done.
super crude homemade cap for 009, note the lower copper ring that the coil wire ran on. This actually worked, but was short lived due to wear on the copper ring. Also could only had room for points and could not adjust firing angle between the 2.
This was a real nice unit made by Jim Hassad back in the 70's. Belt driven with pressed in bearings. Worked real nice but eventually belt issues sidelined this one. 1915cc with turbo + this ran 120hp all day and would break loose 3rd gear on the highway!
same engine, but de-turboed, swapped to dual carbs and went the 009 with Datsun cap route. Worked great! then sold the car,,,
1776 twin plug using pertronix with dual ignitors. I never got to fully develop this and it got sidelined,,,
Keep up the great work! _________________ Volkaholic |
Posted: Wed Dec 14, 2011 10:57 am Post subject: |
volkaholic1 wrote: |
Keep up the great work! |
What need to be done to the Stock distributor to fit the datsun cap, extra points and datsun rotor? _________________ Official 58-60 "Early Big Window" Convertible Thread & Registry
http://www.thesamba.com/vw/forum/viewtopic.php?t=426481
F&S Saxomat Automatic Clutch System Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=462533
61-67 Delanair Air conditioning Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=457944&highlight=air+conditioning
PUNCTUATION CHANGES THE WORLD: "I need to help my uncle, Jack, off a horse" is way better than, "I need to help my uncle jack off a horse" |
Posted: Wed Dec 14, 2011 1:05 pm Post subject: |
I made an adapter plate to hold the cap and an adapter for the rotor. I got a drawing someplace. If I did it again, I would use a 3/8" plate instead of the thin plate I used.
sotexguy Samba Member
Joined: September 15, 2006 Posts: 10 Location: Lago Vista, TX
Posted: Tue Jan 24, 2012 6:41 pm Post subject: |
Yes this setup is very nice and Ninamasher is the man when it comes to perfect aftermarket early speed stuff. I cant wait for his next mods. _________________ Pan is finished!
Waiting on the body to be painted.
58 Bug (Schmutziger Abfall)(Dirty Trash)(Basura Guero)
58 Chevy Panel (The Sled)
01 Excursion (Big Gulp)
Down to only three Plus a cool new Rollback Trailer! |
sankyp Samba Member
Posted: Wed Sep 05, 2012 12:48 pm Post subject: @Ninamashr |
Excellent job brother. I will be attempting a similar setup for my carb Suzuki 800cc car. Only hurdle being the intake manifold which blocks a major pard of the head from where a plug can be inserted. It makes around 35ps power and runs about 9:1 compression ratio. So shaving the head is on cards.
I am confused about the twin coil setup though. Should they be connected in parallel or in series. The car has a 35AH battery and 35 amp alternator. Will it be sufficient to keep the coils charged if connected in parallel or shud I go with a series connection?
If connected in series, I am not sure where the LT wires from the condenser will be to the coil from
Plz help me here. Thank you. |
loor Samba Member
Joined: November 20, 2008 Posts: 79 Location: germany, southern
Posted: Mon Sep 10, 2012 2:17 am Post subject: |
what kind of cap and rotor did you use with that setup?
cheers |
Posted: Wed Sep 26, 2012 8:19 am Post subject: |
It is the Nissan twin plug cap / rotor from the Z22, I got part numbers somewhere, search on drivewire.com _________________ Volkaholic |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Thu Sep 27, 2012 3:38 pm Post subject: |
I notice your bottom engine has a thick aluminum plate. Is this by chance one of the dual ignition kits I sent out from Hawaii in the early 90s? _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
