Head Part number 311101375 & 113101375A
AirDirect
AirDirect is offline
PostPosted: Mon Feb 28, 2011 8:39 pm    Post subject: Head Part number 311101375 & 113101375A Reply with quote
Can someone tell me the difference between these part numbers?
311 101375
113 101375A
I had one of each on my engine.
Thanks
pow_rider17
pow_rider17 is offline
PostPosted: Mon Feb 28, 2011 8:44 pm    Post subject: Reply with quote
The first is a type 3 head, the second a type 1.
AirDirect
PostPosted: Mon Feb 28, 2011 10:17 pm    Post subject: Head Part number 311101375 & 113101375A Reply with quote
Can they be interchanged? Is one of each ok for a type 1 standard beetle?
pow_rider17
PostPosted: Wed Mar 02, 2011 2:27 pm    Post subject: Reply with quote
Yes you should be fine to run both as long as they are the same sized valves and the combustion chambers are the same cc's.
AirDirect
PostPosted: Thu Mar 03, 2011 11:20 pm    Post subject: Head Part number 311101375 & 113101375A Reply with quote
Thanks!
jeff denham
jeff denham is offline
PostPosted: Mon Mar 07, 2011 7:10 pm    Post subject: Reply with quote
the 311 has intake guide Bosses in the ports. were the 113s Dont. people have been known to miss match the two BIG REBUILD COMPANYS. one head has more intake port volmum than the other. . JD.
www.dprmachine.com
