Trebor75 Samba Member
Joined: March 12, 2011 Posts: 9 Location: 20k from amsterdam
Posted: Wed Apr 20, 2011 1:17 am Post subject: Side trim holes |
In my oval the side trim holes are welded up.
Does anyone have the measurements for the location of the holes?
So i can dril them back in.
Thanxs in advance |
GüteAndTite Early Convertible Güru
Joined: June 16, 2005 Posts: 2144 Location: Low So Cal
Sketchy_1 Samba Member
Joined: May 28, 2010 Posts: 273 Location: That two horse town
Posted: Wed Apr 20, 2011 8:13 pm Post subject: |
Mine is apart right now with all the trim off. Let me know what reference lines will work best for you and I will measure them out. _________________ 69' Karmann Ghia Convertible AWD Project (FB Build) (STF Build) |
Posted: Thu Apr 21, 2011 12:04 am Post subject: |
If you can measure them from the middle of the middle of the hole upwarts to the middle of the body line ,that would be great
Or from the body line to the top of the trim, but your trim is of so that wnat go for now.
Thanxs in advance again |
Posted: Thu Apr 21, 2011 9:53 am Post subject: |
okay give me a few days. I will photograph the body panels and superimpose the measurement lines over them. _________________ 69' Karmann Ghia Convertible AWD Project (FB Build) (STF Build) |
Posted: Thu Apr 21, 2011 1:45 pm Post subject: |
| Thanxs |
56TIMOTEO Samba Member
Posted: Thu Apr 21, 2011 6:51 pm Post subject: |
| I've been told to drill next to the welded hole, too hard to drill through the welded hole! |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17658 Location: Left coast, Canada
Posted: Thu Apr 21, 2011 10:15 pm Post subject: |
| 56TIMOTEO wrote: |
Even the worst piece of junk China drill will be harder than any weld. If you're having trouble drilling a weld, your drill is dull.
Drill the hole exactly where you want. Maybe drill it smaller at first, then double check the position. If it's off, you can use a file to increase the size and move the center at the same time. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Posted: Sun Apr 24, 2011 11:49 am Post subject: |
Here are the dimensions. I tried to use the easiest reference point to drill from. I used a tailors tape which allowed for flex. If I were to redrill these I would use a pinstripe tape to set the desired drop from the reference line (26mm to 28mm) then measure out from the given reference point. The points given are on center for a 8mm or 5/16" bit. Judging by the door measurements varying in a few mm, I would go 27mm across. What's one millimeter eh?. The door measurements were done from the hinge post -> rearward
For the door and rear quarter panel reference line I just used a permanent marker that rode in the groove created by the panel and measured from there. Let me know if you need anything else.
Posted: Mon Apr 25, 2011 2:50 pm Post subject: |
Verry big thanxs.
I'll go by the 27 mm.
Thanxs again |
Boom Samba Member
Joined: September 29, 2007 Posts: 1119 Location: Houston by God Texas
Posted: Mon Apr 25, 2011 3:44 pm Post subject: |
| Bruce wrote: |
| 56TIMOTEO wrote: |
Drill the hole exactly where you want. Maybe drill it smaller at first, then double check the position. If it's off, you can use a file to increase the size and move the center at the same time. |
I must have some weak ass drill bits then because everytime I have tried to drill thru a weld it was always harder. but then again I do use the mac bits I should have spent the extra money on the snap off ones _________________ Ovals are Overrated.....Click to view image
67 Chubby White Chic
Düg Büg
dLk |
Bruce Samba Member
Posted: Mon Apr 25, 2011 7:05 pm Post subject: |
Your weld will always be mild steel. Not hardenable by any heat treating process.
A HSS drill is high carbon steel with other alloying elements, then heat treated to be hard so it doesn't wear out.
I guarantee, any HSS drill will always be harder than any mild steel weld. If you are having trouble drilling, your drill is dull, or you're doing something else wrong. _________________
slalombuggy Samba Member
Posted: Thu Apr 28, 2011 2:32 pm Post subject: |
| Bruce wrote: |
I guarantee, any HSS drill will always be harder than any mild steel weld. If you are having trouble drilling, your drill is dull, or you're doing something else wrong. |
Or you're spinning the drill bit too fast and burning it up. Also, start with a small pilot hole and then drill the correct size hole. A step bit will give you a nice round hole in your sheetmetal panels.
brad |
