VolkzBitz Samba Member
Joined: April 30, 2009 Posts: 300 Location: Washington State USA
Posted: Thu Jul 07, 2011 11:55 am Post subject: |
Yes some carbs just will not run right, even though I check all check balls, passages etc and replace all gaskets diaphrams, renew every throttle shaft bushing whether its loose or not, and resurface mating surfaces.
Im in contact with BrokenBus, and he is returning the carb to me. I will check it, and replace if necessary. I will follow up with what I find, and hopefully solve this mystery.
Tim
VolkzBitz |
Brokenbus Samba Member
Posted: Thu Jul 07, 2011 12:32 pm Post subject: 30 pict 1 |
Yes, Everett that does make me feel better I knew I wasn't alone in this quest. Builder is standing by his product and this forum probably helps reinforce that good quality that is inherent somewhere in all of us. I will post again once shipped another 30 pict 1 that builder says he will test run first. |
Posted: Fri Jul 15, 2011 3:12 pm Post subject: |
Ok, I found the problem. After totally stripping it down and checking everything The throttle plate was a little worn, allowing air to leak past. I tried the carb on my 1600 dp Ghia, and it runs and idles great now. I will be returning the carb to "BrokenBus", and hope he can change his handle to "FixedBus", lol.
Thanks for all the input on this.
Tim
VolkzBitz.com |
Snoop Bob Samba Member
Posted: Fri Jul 15, 2011 5:24 pm Post subject: |
Tim, thanks for standing by your shit. Looking forward to the update from the OP. _________________
BarryL wrote: |
Put your lips onto the little tit with the hole in it inside and make a good seal. You can suck and blow but with a little resistance. It gets better after it's wet. |
EverettB wrote: |
I would be interested in knowing the sizes of the various shafts. |
Posted: Thu Jul 21, 2011 12:57 pm Post subject: 30 pict 1 |
Final update, hopefully. Reinstalled carb after receiving from rebuilder. After a little tweaking bus runs great idles well @ 875 RPM. Test drove several miles with no defects noted.
So back to original question. Pict 30-1 idle adjustment. What I have learned is this. 1, you can only adjust idle on this carb using the volume control screw on the left side of the carb in conjuction with the idle control screw on the choke cam. If you can't get the carb to idle properly in a short amount of time by simply adjusting these two then something else is wrong.
2, that "something else" needs expert hands on diagnosis IMHO. Hope this helps somebody else down the road. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14277 Location: Casa de Oro, California
Posted: Thu Jul 21, 2011 3:42 pm Post subject: Re: 30 pict 1 |
Brokenbus wrote: |
...in a short amount of time... |
After the manifold has warmed a little and the choke is fully open. All you said is true.
It's like a fairy tale with a happy ending but without unicorns. |
bensokim Samba Member
Posted: Wed Aug 10, 2011 7:34 am Post subject: Re: 30 pict 1 |
Brokenbus wrote: |
Point Noted on this adjustment... one last Question? does the Pilot/Idle jet = jet on right side of carburetor, by the generator need to be turned clockwise to the END? if not How many turns and which direction of the turns?
thanks guys _________________ A BMW asked a Volkswagen Beetle"why r ur eyes popping out of ur body"? the Volkswagen replies "let them put an engine in ur ass and see what happens to ur eyes" |
BarryL Samba Member
Posted: Wed Aug 10, 2011 7:46 am Post subject: Re: 30 pict 1 |
bensokim wrote: |
... does the Pilot/Idle jet = jet on right side of carburetor, by the generator need to be turned clockwise to the END? if not How many turns and which direction of the turns?... |
Yes. It's not adjustable but is supposed to seat there. Some people run them loose as a gypsy fix. |
Posted: Wed Aug 10, 2011 8:00 am Post subject: |
So i turn it clockwise to the END? _________________ A BMW asked a Volkswagen Beetle"why r ur eyes popping out of ur body"? the Volkswagen replies "let them put an engine in ur ass and see what happens to ur eyes" |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51173 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Aug 10, 2011 8:58 am Post subject: |
bensokim wrote: |
So i turn it clockwise to the END? |
Yes, but don't overtorque it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Aug 11, 2011 12:29 am Post subject: |
Thanks BarryL and big daddy' i have made those adjustments... i want you guys to listen to the engine run on below link and advise any corrections you feel i may need to rectify' its a 30 Pict 1 carb on a 1600 DP motor....
http://www.youtube.com/watch?v=gXBfJ_Txq2U
cheers _________________ A BMW asked a Volkswagen Beetle"why r ur eyes popping out of ur body"? the Volkswagen replies "let them put an engine in ur ass and see what happens to ur eyes" |
BarryL Samba Member
Posted: Thu Aug 11, 2011 6:27 pm Post subject: |
Can't watch those on my dial-up. Is there an audio file? |
Posted: Thu Aug 11, 2011 7:36 pm Post subject: |
2 things to start with.
1. connect the vacuum advance pipe from the carb to distributor, your getting air in through the carb.
2. get those flexible heater hoses on asap, you will over heat the engine, because the hot air is being recirculated |
Posted: Thu Aug 11, 2011 8:01 pm Post subject: 30 pict 1 0nly |
And painting over the fugly orange with something resembling the color black would help. |
Posted: Thu Aug 11, 2011 8:08 pm Post subject: 30 pict 1 0nly |
oh and 1 other little thing. You have no automatic choke guts. |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Thu Aug 11, 2011 8:09 pm Post subject: Re: 30 pict 1 (only) carb idle adjustment |
Teeroy wrote: |
Did you try richening the mixture? Make sure its timed right for the distributor you have (oldvolks chart has all specs) |
Link to this ? _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Thu Aug 18, 2011 1:10 am Post subject: Re: 30 pict 1 0nly |
Brokenbus wrote: |
Lol No one needs an automatic Choke in Africa. We are in the tropics and have plenty of HEAT on air
regarding the orange colour, well ill paint the shroud Black and leave the pulley orange'
will connect the air hoses to the heat exchangers and connect the vacuum link to the canister and upload another video file for updates...
Cheers guys _________________ A BMW asked a Volkswagen Beetle"why r ur eyes popping out of ur body"? the Volkswagen replies "let them put an engine in ur ass and see what happens to ur eyes" |
Posted: Thu Aug 18, 2011 8:18 am Post subject: 30 |
Well it's Africa Hot here in Texas several months out of the year and a choke is still needed because the VW motor operating temp is around 200 degrees F. Engine requires choking until that tempature is achieved so unless it's 200 degrees ambient temp where you live motor still won't idle correctly. But hey if it works for you great! |
