Maddog209 Samba Member
Joined: November 03, 2011 Posts: 291 Location: Central Valley, Ca.
Posted: Mon Nov 14, 2011 8:46 am Post subject: |
A true machinist and artist.....NICE work!! _________________ Current VW's= 2013 Tiguan, 1968 Bug |
AlteWagen Troll
Posted: Mon Nov 14, 2011 2:13 pm Post subject: |
Lidpainter wrote: |
M@mouth 37 wrote: |
You say that because in 20 years later this beetle are bad restore, with a bad parts.
No, you're restoration work is great. J'ai dit que parce que je ne pense pas que les 1958 châssis ont les trous circulaires dans les tours arrière de choc ou les "bump stops".
X2
the three ribs in the brake res. area also point to a late 59/60 car. Also L363 Artic white was also a 60 only color.
http://www.wolfsburgwest.com/colors/60l363.html
L’ATELIER RENARD Samba Member
Posted: Mon Nov 14, 2011 11:15 pm Post subject: |
The colors it's not originaly paint the original paint it's : Glacier bleu. |
AlteWagen Troll
Posted: Tue Nov 15, 2011 3:16 pm Post subject: |
M@mouth 37 wrote: |
Something is fishy on this car. I suspect a vin swap at some point in its life |
curtisvitoria Samba Member
Joined: August 30, 2011 Posts: 122 Location: British Columbia
Posted: Tue Nov 15, 2011 5:44 pm Post subject: |
Great Pics, and great work! |
Posted: Fri Nov 18, 2011 11:16 am Post subject: |
I continue the restoration of the frame :
Posted: Sat Feb 04, 2012 2:37 pm Post subject: |
Today passage to amaury to give a hand to him, of the blow cleaning of floor and presentation(display) of the chassis under the hull(shell) for future Clerk's Office of to work everything is nikel for the paper hat and the rest.
Posted: Thu Apr 05, 2012 12:48 pm Post subject: |
Here is floors are put, magnificently adjusted by amaury which(who) is now autonomous for the body. I would put detailed photos of the adjustments, the next ones(fellow men) work will be the support(medium) of limp to put back(to hand) of origin to put back(to hand) one Split accommodates...
A small indication of works that Amaury in begun(undertaken) on the beetle moreover it takes a lot of pleasure to realize this spot!!!
The frame before restoration(catering) one works of madman whom we realized with Amaury for arrived at this result(profit)!!!
[/list] |
Posted: Fri Apr 06, 2012 6:45 am Post subject: |
estolze Samba Member
Joined: March 29, 2010 Posts: 42 Location: LAKE HAVASU CITY,ARIZONA
Posted: Fri Apr 06, 2012 7:47 am Post subject: |
great work and thank you for letting us tag along . |
kyjr.buggy1 Samba Member
Joined: March 12, 2012 Posts: 8 Location: Louisville, KY.
Posted: Fri Apr 06, 2012 11:19 am Post subject: |
Wow, this is just awesome. Keep up the great work. |
Posted: Fri Apr 06, 2012 12:28 pm Post subject: |
Thank you for the compliments |
Posted: Sat Apr 07, 2012 4:08 am Post subject: |
Next Grinding the weld !!!
silvertonguedevil Samba Member
Joined: September 26, 2010 Posts: 1692 Location: Vale, OR
Posted: Sat Apr 07, 2012 6:17 am Post subject: |
Everything looks great but I was wondering why you didn't evenly space your spot welds on your pan halves. _________________ -Greg |
Posted: Sat Apr 07, 2012 8:53 am Post subject: |
because when i Drill the original weld point i used the sames drill for weld the new pan... but i Grinding the point weld |
Posted: Tue Apr 10, 2012 1:29 pm Post subject: |
Here is Amaury began the dismantling of the engine piston HS, Rolls HS he is soon going to check the AAC and the 36hp Crankshaft
!!! It is funny one 36hp we would say one miniature or about the watchmaker's shop swich(watch-making)
