indianpeaksjoe Samba Member
Posted: Tue Jan 30, 2024 7:35 am Post subject: Auxiliary Fuel Pump |
I was chatting with my buddy who mentioned he has a small 3 psi electric fuel pump in his baja in addition to the mechanical pump. Since his baja might sit for a month or so in the winter, he turns it on for a few minutes if he hasn't driven it in a while and turns it off once it gets going. Seems like an awesome idea.
Anyone else running a similar system?
Thanks!
-Joe _________________ Adventures in owning a 66 beetle |
joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Tue Jan 30, 2024 9:52 am Post subject: Re: Auxiliary Fuel Pump |
I do the same in my fibergass buggy. My electric pump sits up front inder the tank, and runs thru the stock mechanical pump. Only uze it when the buggy has sat for a while, and only to fill the carburetor bowl. You can tell when the carb is full, the sound changes. |
Dan_Lockwood Samba Member
Joined: October 03, 2023 Posts: 188 Location: Clare MI
On "some" auxiliary fuel pumps (when off), it's not easy to draw through them, as in sucking from the output side with another fuel pump. I'm sure his works okay for him, but my experience with them says it will be hit or miss as to whether they will free flow through them.
I took my mechanical pump off and am running an Edelbrock 2-3.5 psi pump and mine seems to NOT overpower the Weber floats. I would make sure your pump is limited to less than 4 psi. This is just my experience and I'm sure many others here with years of experience with the VW motors can be a lot more accurate with their advice.
A quick story about carbs and hot rods. My buddy had a 350 Chevy in his '32 coupe with dual Edelbrock 4bbl carbs. It ran fairly well down the road, but when we'd stop, the fumes were horrendous around the car at idle, burn your eyes almost. We tried to adjust the floats several times, but to no avail. Finally, he called Edelbrock, and they told him that anything over 4 psi would overpower the floats and cause flooding. He put a fuel pressure regulator on the car and his motor never ran better. AND no more nasty fumes.
So just be mindful as to what your carbs can handle before throwing an electric fuel pump at it.
Good luck!
Dan |
Posted: Tue Jan 30, 2024 2:11 pm Post subject: Re: Auxiliary Fuel Pump |
Thanks all, the weather is not bad enough for me to take on this project yet, more just something to google when I sit in meetings. I appreciate the info.
Posted: Tue Jan 30, 2024 2:49 pm Post subject: Re: Auxiliary Fuel Pump |
I use a Facet fuel pump. Looks like an upright rectangular box. As I remember, there are 2 models. A low pressure 2 1/2 to 4 lbs one, and a higher pressure one. You want the low pressure. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20386 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Jan 30, 2024 7:29 pm Post subject: Re: Auxiliary Fuel Pump |
Carter also makes a 4PSI rotary fuel pump....
https://carterengineered.com/electric-fuel-pump-p60430 _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Wed Jan 31, 2024 10:36 am Post subject: Re: Auxiliary Fuel Pump |
Ended up with the 2-3.5PSI Facet because the Edelbrock was in fact not in stock at my LPS.
Any chance for sharing a pic of where you mounted your pump JoeMama? If not, no worries at all.
Cheers,
Posted: Fri Feb 02, 2024 2:29 pm Post subject: Re: Auxiliary Fuel Pump |
Wont be near my buggy for a while, but its mounted to the body firewall. This way its out of the way of steering components. |
Posted: Thu Feb 08, 2024 6:54 am Post subject: Re: Auxiliary Fuel Pump |
Well I got the Facet model I linked above, but then I looked at the spec sheet which says it has a positive shut off valve. Meaning gas would not pull through if it is turned off. The local NAPA had this one, which allows for flow through. It came with a 5/16 connector and filter which I don't need... But it was worth it to support the local shop.
I'll get to it this weekend or next.
y2kbaja Samba Member
Joined: March 07, 2016 Posts: 93 Location: Sacramento
Posted: Thu Feb 08, 2024 3:19 pm Post subject: Re: Auxiliary Fuel Pump |
Both my cars (class 9 and buggy) run mechanical with a "primer" facet pump. Neither car run on the electric or both pumps, mechanical only.
The electric pump also makes it easier to pump gas out to put in the lawn mower. |
