Template for Plexiglass (Acrylic) Sliding Window Covers
indytriple
indytriple is offline
PostPosted: Sun Nov 13, 2011 5:08 pm    Post subject: Template for Plexiglass (Acrylic) Sliding Window Covers Reply with quote
A few months ago I stumbled onto a French site (maybe via The Samba?) that had templates and pictures for how to make plexiglass (acrylic) sliding window covers for a Vanagon Westy. The covers were to keep rain out while parked or camping while still allowing air to flow.
The site, is gone, but you can still access a Google cache of the original site, but alas, no images or pictures.
Did anyone out there happen to save the templates for this?
If you translate the cached site to English it gives the following details:
"This "window" is actually a piece of "Plexiglas" thin (14 "X 17") which the 4 corners are cut according to the following measures against it. Insert it into the top rail of the window ... it is gently curved to insert then into the bottom rail. Just turn the piece so that the cutout is the largest facing the front of the vehicle and the small, backward. Obviously, once the Plexiglas in place, we can close the window."
I liked the way that they had cut particular-sized curves out of the corners for a perfect fit. Someone definitely put some thought into it. I could start chopping up a 14X17 piece of plexiglass, but that stuff ain't cheap. I'd rather do it perfectly the first time with a template.
Anyone else see this or do this mod?
"See The Glass As Already Broken."
87 Vanagon Westy Auto Bostig
www.bluegrassbicyclecompany.com
foodeater
foodeater is offline
PostPosted: Sun Nov 13, 2011 6:01 pm    Post subject: Reply with quote
You could just use a piece of cardboard to make you template, then transfer that to your acrylic sheet.
89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP
indytriple
PostPosted: Sun Nov 13, 2011 7:57 pm    Post subject: Reply with quote
Good idea. That's what I plan on doing with some flexy card stock paper, but I figured I might as well at least ask before I reinvent the wheel.
I'll post the dimensions and shape here if I recreate it myself. Looked like a really useful mod for when you want the windows open but it's raining.
dubbified
dubbified is offline
PostPosted: Sun Nov 13, 2011 8:41 pm    Post subject: Re: Template for Plexiglass (Acrylic) Sliding Window Covers Reply with quote
This sounds interesting.. curious if someone has a picture.
indytriple
PostPosted: Sun Nov 13, 2011 8:44 pm    Post subject: Reply with quote
Keeping my fingers crossed for some pics.
ragnarhairybreeks
ragnarhairybreeks is offline
PostPosted: Tue Nov 15, 2011 6:27 pm    Post subject: Reply with quote
is this the kind of thing you are looking for? Made from a scrap bit of Lexan, 1/8" X 7 1/2" X 17 1/2". Corners on the forward edge cut out to approx. 1" radius. The dimensions were pretty well dictated by the size of the scrap bit I had on hand.
hope this helps
alistair
'86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com
indytriple
PostPosted: Tue Nov 15, 2011 7:50 pm    Post subject: Reply with quote
hope this helps
alistair
Yep, that's what I'm looking for. Thanks a bunch. The French one was larger 14X17 (probably to work with the window all of the way open), and I'm pretty sure that all four corners were cut out in a small radius to make the plexiglass overlap the window and window seal a bit to really keep water off as it rains or sheets down.
I went to Home Depot the other day, and I perused their plexiglass/acrylic supply. I may go back tomorrow and take a shot at this. As mentioned earlier, I'll post final measurements/pics/templates once I'm done.
ragnarhairybreeks
PostPosted: Tue Nov 15, 2011 7:55 pm    Post subject: Reply with quote
I'll cut out the other corners too, seems apparent once I looked again at the pics. A larger one would have been nice, but I only had a small bit of Lexan. BTW, Lexan is nice for this application, takes a heck of a lot of bending to break that stuff.
alistair
Perales
Perales is offline
PostPosted: Tue Nov 15, 2011 8:01 pm    Post subject: Reply with quote
And it's bullet proof Twisted Evil
-- 1987 Westfalia automatic (Captain Vino)
indytriple
PostPosted: Tue Dec 06, 2011 9:29 pm    Post subject: Reply with quote
I did this project, and I'm very happy with the result. We just ran a gravel road bicycle race in the Hoosier National forest, and it rained for two days straight. They worked like a charm. Never leaked even one drop despite heavy rain and high winds. I had them in when I was cooking on the stove and when we were running the Mr. Heater propane heater.
Here's my supply list:
-(2) Plaskolite Optix 18"x24" Acrylic Sheets (.093" Thickness)
-Acrylic Cutting Tool
-Dremel Tool w/Sanding Attachment
-A Yardstick and 2 C-Clamps
-A Table or Workbench
Total cost for the acrylic and the cutting tool (Home Depot) - $32.54
Yes, it's a little expensive, but it's worth every penny when you're camping in the rain and you need 'em.
I first cut the sheets down to 14"x17". I then measured 2 1/4" in from each corner and cut the corners off. I rounded off the corners and any rough edges with the Dremel tool. There are lots of good videos on cutting acrylic on the interwebs if you've never worked with the stuff before.
I'm storing them in between the bed cushions up top. It's out of the way, and they can't get scratched there. I leave then near the edge so that I can reach in between the cushions and get them with or without the top up.
kamzcab86
kamzcab86 is offline
PostPosted: Tue Dec 06, 2011 9:39 pm    Post subject: Reply with quote
Dangit! I need to stop clicking on these types of threads... thanks to all these neat ideas, my project list keeps growing instead of shrinking! Mad Laughing
indytriple wrote:
I first cut the sheets down to 14"x17". I then measured 2 1/4" in from each corner and cut the corners off. There are lots of good videos on cutting acrylic on the interwebs if you've never worked with the stuff before.
I don't know about HD, but Lowe's will cut acrylic sheets for you (maybe not the corners in this project, but they'll cut a larger piece into the square dimensions you need).
~Kamz Anxious
2016 Golf GTI S
vanis13
vanis13 is offline
PostPosted: Thu Dec 08, 2011 7:48 am    Post subject: Reply with quote
Lexan (and non-lexan to a point) cuts extremely easily with a table saw - push slow enough so it does not chip/push fast enough so you are cutting rather than melting. Jig saw/sawsall works OK too if you keep it from vibrating. The score/snap technique is sometimes difficult with Lexan. a torch cleans up / smooths the edges very well.
HD/Lowes do carry lexan if you want no hassle but it is relatively expensive.
To save several $ find a "plastic supply" in the yellow pages and check their scrap pile. Mine sells scraps at $2-$3/LB so a couple sheets like this are about $5
berkeleyjack
berkeleyjack is offline
PostPosted: Wed May 09, 2012 8:14 am    Post subject: Reply with quote
For folks out on the West Coast, you could go to TAP Plastic and get them to cut plastic to your specifications pretty cheap.
http://www.tapplastics.com/
I've worked with them before on some custom lighting projects, and they do work while you wait and are reasonably priced.
Lots of options for color, thickness, etc. Everything from opaque white/black to bright neon colors.
Or if you don't want to pay to have them cut it, they have good prices on uncut sheets of plastic as well.
All-grain homebrewer with a 1990 Vanagon Carat.
dubbified
PostPosted: Wed May 09, 2012 8:35 am    Post subject: Reply with quote
I dig this idea.
Rain comes to mind.. keeping it out with something this easy is a great idea!!!
highaltidude
highaltidude is offline
PostPosted: Mon Aug 18, 2014 1:55 pm    Post subject: Reply with quote
Camping in Colorado means afternoon thunder storms.....
I've got a rainfly for the pop-top....
But no way to vent the inside and stay dry.....
I followed the OP's instructions and now have two covers for my sliding windows.
Smile
Chuck
66 Double Cab
83 Vanagon Westfalia, Vanistan'd
