VWhead Samba Member
Joined: September 27, 2009 Posts: 337 Location: Pacific Grove,CA
Posted: Tue Jan 17, 2012 2:58 pm Post subject: Another 1.8T hits the road !! |
Just completed a 1.8T engine conversion into a 85' Vanagon and it's all California legal !
The motor was removed from a 02' VW GTI.
Here's some pics...
_________________ 81' Single Cab Syncro 1.8T GMW
88' 2wd Westy 1.8T GMW
www.gmwerks.com
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Tue Jan 17, 2012 3:03 pm Post subject: |
wow, nice.
doesnt even look like you modified the oil pan and clearance looks awesome. |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2987 Location: Issaquah, WA
Posted: Tue Jan 17, 2012 3:06 pm Post subject: |
Nice! Under the engine cover too! How much did you have to lower the transmission from stock?
I like the exhaust layout. Everything is in stock position - except much larger.
D |
insyncro Banned
Posted: Tue Jan 17, 2012 3:26 pm Post subject: |
Very clean install
andy syncro-nutz Samba Member
Joined: August 22, 2010 Posts: 539 Location: Upper Ottawa Valley
Posted: Tue Jan 17, 2012 4:49 pm Post subject: |
| insyncro wrote: |
Very clean install
X2 Real nice,
What is the ground clearance for the sump? |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12175 Location: Port Manteau
Posted: Tue Jan 17, 2012 5:11 pm Post subject: |
Sweetness! That's one of the cleanest and stealthiest raised engine lids I've seen. That engine totally belongs in there. _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
hans j Samba Member
Joined: May 06, 2006 Posts: 2744 Location: Salt Lake City UT
Posted: Tue Jan 17, 2012 5:36 pm Post subject: |
Looks great! Did you make those engine brackets/cradle bars? _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
VWhead Samba Member
Posted: Tue Jan 17, 2012 6:35 pm Post subject: |
Thanks everyone for your positive comments!
It's just too much fun building 1.8T breadbox's!
The oil pan is stock from the GTI donor vehicle and doesn't need any modification.
I wanted the engine lid spacer to be very simple,yet functional. The engine lid spacer is 1-1/4" tall and the trans is spaced down 1-1/2".
The exhaust system is all Tig welded with 304 stainless mandrel bent tubing and uses the donor cat. It sounds great!
Ground clearance on this 2wd is approximately 8" and that's with stock suspension and 27" tires. More clearance could be had with taller springs if needed.
I'm using our newly redesigned engine carrier system,it's similar to what VW did with the Diesel Vanagon engines,but it mounts upright at 15 degrees. _________________ 81' Single Cab Syncro 1.8T GMW
www.gmwerks.com
Posted: Tue Jan 17, 2012 6:43 pm Post subject: |
And great 200th post on here too! Well done  |
insyncro Banned
Posted: Tue Jan 17, 2012 7:41 pm Post subject: |
Are pricing and options listed anywhere?
This conversion is really growing on me and I am nowhere near Cali.  |
hans j Samba Member
Posted: Tue Jan 17, 2012 7:55 pm Post subject: |
There is a 06A factory steel pan available too! I don't remember the part number but I think it is usually on 2.0. That's what I am going to do on my TDI conversion so it can take abuse if I am unlucky enough! _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
dredward Samba Member
Posted: Tue Jan 17, 2012 8:19 pm Post subject: Re: Another 1.8T hits the road !! |
| VWhead wrote: |
Here's some pics...
YAY!!!!! Is this yer van Paul? _________________ Cars owned: 1979/89 scirraco, 1983 gti, 1984 gti, 1986 gti, 1990 gli, 1989 cabriolet(2.0,16v conversion), 1992 gti, 1982 Westy, 1987 syncro Westy(w/ 1.8t conversion stg1 chip), and finally 2004 r32.... |
Crankey Samba Member
Posted: Tue Jan 17, 2012 8:26 pm Post subject: |
that looks very nice in there. great work.
I too am leaning more this way.
is there any reason it couldn't be mounted 'upright' without any tilt from it's original orientation in a doka, ?
I have 9 5/8" from the top of my WBX alternator to the bottom of the engine hatch.
I'm nearly 100% street driven so I don't need higher than stock ground clearance. someday I may get shorter springs, but I'm on carat springs now.
thanks for sharing your pics ! drool worthy ! |
Posted: Tue Jan 17, 2012 9:12 pm Post subject: |
Yeah, my Doka would like that in the back of it.
as insyncro said, price? |
Posted: Tue Jan 17, 2012 9:20 pm Post subject: |
| purplepeopleeater wrote: |
You kinda gotta look out for the PWR Steering pump when you put these engines uprite Russel @ syncro-nutz did a TDI uprite and i remember the pump was the lowest thing and needed to modifi the diesel syncro bash plate, |
Ryan Alfonso Samba Member
Joined: March 23, 2007 Posts: 101 Location: Half Moon Bay, CA
Posted: Tue Jan 17, 2012 9:36 pm Post subject: |
| Want. Want. Want |
Posted: Tue Jan 17, 2012 10:13 pm Post subject: |
power steering ?!? I don got no stinkin power steering !  |
Posted: Tue Jan 17, 2012 10:17 pm Post subject: |
| Crankey wrote: |
me either, not power steering rack anyways. |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10504 Location: Sunshine Coast B.C.
Posted: Tue Jan 17, 2012 10:30 pm Post subject: |
Great stuff!
Looks like the cat is supported off d-side of block. I have been using something similar.
Is the muffler supported from body? I imagine the turbo must quell some exhaust noise.
Interesting to have a look at another 15º install. I'm currently in the middle of carrier and exhaust redesign and am still making decisions. Very helpful to see your pics.
Thanks!
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
Tristar Eric Samba Member
Joined: July 25, 2004 Posts: 1265 Location: Portland, Or
Posted: Tue Jan 17, 2012 10:55 pm Post subject: |
| Excellence! I really like your lid spacer. I might have to borrow your idea there. Super clean, congrats on the BAR sticker. |
