Australian Custom 59 11 Window
Page: 1, 2, 3, 4  Next
Dasdubber
Dasdubber is offline
PostPosted: Mon Jan 23, 2012 5:20 am    Post subject: Australian Custom 59 11 Window Reply with quote
Hi everyone, thought some of you might like to take a look at 59 11 window microbus we have been restoring over the last couple of years for a customer. I run DAS Resto Haus here in Australia (VW restoration shop).....purists may not like the 'modernisation' of this bus, but we have attempted to retain an element of style consistent with the original design. So even if its not your 'thing', hopefully you can appreciate the work involved.
Cheers
Al
Well before I take a retrospective look and upload some of the 1200 odd pics we've taken throughout the resto, thought it might be good to preview how the bus looks in a 'close to completed form'
Dasdubber
PostPosted: Mon Jan 23, 2012 5:22 am    Post subject: Reply with quote
It started out life as a semi solid 1959 Microbus.
Before I dive into a heap of restoration progress pics, I'll fast forward a little to give you an idea of the direction we took ..
Dasdubber
PostPosted: Mon Jan 23, 2012 5:23 am    Post subject: Reply with quote
Like a lot of 50 plus year old buses, there are always lots of stubborn screws - rather than drilling and retapping all threads, where we can we use heat and then water/air to expand/contract the screw/screw plate to help uncrack them
So often people will assume "the rust is not too bad" when they can only see a small pin hole or two, but this is more often than not what is hiding underneath...
After blasting
The start of one of the major custom mods of this resto....a walk through conversion
A lot of Klassic Fab repair panels went into this bus (we are now the Australian distributors of these great panels)
Shaping walk through backs/sides
Dasdubber
PostPosted: Mon Jan 23, 2012 5:25 am    Post subject: Reply with quote
A hell of a lot of time was spent gapping the doors and apertures throughout the welding stage
None of the buses were perfect out of the factory so often a bit of tweaking is required for the repair panels
Dasdubber
PostPosted: Mon Jan 23, 2012 5:26 am    Post subject: Reply with quote
There are a lot of subtle (as well as some not so subtle) details on this bus including modified jacking points to keep the lines clean on the side of the bus as these are not very attractive in stock form. A bottle style jack will be used (if necessary) on the chassis rail (strengthened) but the jacking point has been 'cut and shut' so it can still be used a hoist lifting point
Lower windscreen sections had to be replaced as well
A donor door provided a replacement lower section (inner)
And a KF section plus a hand formed piece completed the rust repair on the outer skin
Lots of plug welds required for the cargo floor section
RHD locking ball handle Berg shifter is the ducks nuts
The start of the custom air conditioning installation
Another custom touch was the dash treatment including a glove box
I'll get some more pics up soon.
Cheers for taking a look
Al
74 Cosa
74 Cosa is offline
PostPosted: Mon Jan 23, 2012 6:39 am    Post subject: Reply with quote
What a beautiful job! Your "customer" should be very pleased.
Jacco Verveer
Jacco Verveer is offline
PostPosted: Mon Jan 23, 2012 7:42 am    Post subject: Reply with quote
None of the repair panels were perfect out of the factory so often a bit of tweaking is required for the buses
fixed it!!
edit forgot to say you make them work!! Embarassed
Andy P
Andy P is offline
PostPosted: Mon Jan 23, 2012 7:47 am    Post subject: Reply with quote
Showin' off the biz, eh, Al?
This is a killer build. Wink
Cheers & God Bless
'62 Beetle
Jägdwagen
Culito
11010101
Culito is offline
PostPosted: Mon Jan 23, 2012 11:36 am    Post subject: Reply with quote
Cool Cool
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
Dasdubber
PostPosted: Mon Jan 23, 2012 2:08 pm    Post subject: Reply with quote
jacco verveer wrote:
None of the repair panels were perfect out of the factory so often a bit of tweaking is required [b]for the busesfixed it!!
Thanks Jacco, you are right....a lot of the repair panels need tweaking....but likewise when you check door aperture and other internal measurements of these old buses and cross check them with factory specs, very few are exactly to spec after 50+ years. One repair panel will fit one bus perfectly, but will be not even close on another bus Smile
For anyone interested, here are some of our other resto's:
http://dasrestohaus.com.au/gallery2/main.php
Cheers
Al
Dasdubber
PostPosted: Tue Jan 24, 2012 2:19 am    Post subject: Reply with quote
The start of the air con evaporator (blower unit) cover
Lots of little details like filling in the original brake fluid reservoir access hole
And fabricating a new heater duct
Hydraulic clutch
One amplifier is mounted behind each front seat and is covered (more details later)
As the owner is a cyclist, he requested we integrate bike mounts (x2) in the rear cargo area that fold away under the floor so remain hidden when not in use
Deluxe bumper trim has been installed on both bumpers
More dash work
Dasdubber
PostPosted: Tue Jan 24, 2012 2:23 am    Post subject: Reply with quote
After quite a few hours the glove box door was close to completion
Coolers underneath the bus include the AC condensor, engine oil cooler and intercooler radiator (all with thermo fans mounted above coolers) plus small supercharger oil cooler - cable conduits/tubes etc have been relocated to allow fans to be mounted on top
Speaking of the engine, it will be a 2275cc type I based motor with AC compressor, single throttly body (coupled to Link G4 ECU), custom water to air intercooler, and a Rotrex supercharger which will produce around 7 pounds of boost. This was fairly early on in the mockup stage
Dasdubber
PostPosted: Tue Jan 24, 2012 2:25 am    Post subject: Reply with quote
The start of the custom roof lining (fibreglass/mdf) with the rear sub box (sealed enclosure) housing the 2 10in subs.
Itchy stuff....
Front sections
A T3 engine access hatch was donated to the cause to make engine access easier (funny that)
Lots of time metal working the panels before filler work ensued
More pics to come
Cheers
Al
ALLWAGONS
ALLWAGONS is offline
PostPosted: Tue Jan 24, 2012 9:48 am    Post subject: Reply with quote
Awesome build, all that work already makes me feel tired and not go to work!
tanhis
tanhis is offline
PostPosted: Wed Jan 25, 2012 3:43 am    Post subject: Reply with quote
Wery nice custom stuff there.
-58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-73 411 variant all metal custom
-69 typ 2, 9 seater
-89 vanagon camper conversion matkaaja
-08 3.0tdi phaeton
Dasdubber
PostPosted: Wed Jan 25, 2012 4:33 am    Post subject: Reply with quote
Thanks guys, I know custom stuff is not for everyone...especially the purists, but hopefully people can at least appreciate the work involved even if it isn't their cup of tea.
....some more pics....
Plenums for fuel injection runners ended up rectangular as height was an issue under the supercharger
Top of runners were bellmouthed into plenums
Wedgeports were selected by the longblock builders
Another engine mockup with cardboard intercooler for dimensions
Intercooler water pump
Intercooler water reservoir
Supercharger oil reservoir
More bare metal work before filler is applied
Dasdubber
PostPosted: Wed Jan 25, 2012 4:35 am    Post subject: Reply with quote
under the passenger seat we integrated a fire extinguisher mount which is on a hinged door
The first to be installed in Australia - a Red 9 Design double wishbone front end which incorporates rack and pinion steering
The shifter was relocated backwards for both better comfort and also to give more room when in first and third (for clearance to the air con vents)
A mid mount was fabricated and chassis horns and gearbox cradle have been boxed for extra strength
A custom spacer was machined to fit an aero-style filler cap and neck
Obviously in mockup stage at this point but the new filler/tank setup has a block back vent (to relieve pressure whilst filling) as well as a rollover vent which allows the tank to breathe but blocks if there was ever an accident and the bus ended up on its side/roof
arod
arod is offline
PostPosted: Wed Jan 25, 2012 5:11 am    Post subject: Reply with quote
Cool
the chupacabra is my homeboy
PeteSC
PeteSC is offline
PostPosted: Wed Jan 25, 2012 6:07 am    Post subject: Reply with quote
delete
rubbachicken
rubbachicken is offline
PostPosted: Wed Jan 25, 2012 6:14 am    Post subject: Reply with quote
Cool
lucy our westy
lucy's BIG adventure
meet 'burni'
Page 1 of 4
