Fredellus Samba Member
Joined: June 23, 2011 Posts: 275 Location: kern valley
Posted: Wed Feb 29, 2012 12:23 am Post subject: jb weld on fuel inlet tube ? |
simple enough question. has anyone hit their carb inlet tube/carb with jb weld to prevent it from coming out? i have an h30/31 so it's sort of what i'm thinking of doing this to.
let me know!
thanks |
volksnhousin Samba Member
Joined: July 18, 2006 Posts: 326 Location: Ellerslie, GA
Posted: Wed Feb 29, 2012 4:00 am Post subject: |
Do this or something like this.
I don’t think JB weld would hurt anything but I personally wouldn’t use it there. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33407 Location: Hot Arizona
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Wed Feb 29, 2012 7:08 am Post subject: |
| Clean tube and carb body tube bore with scotchbrite extra fine...(cut a piece of scotch brite like a Qtip for the bore) coat tube with red loctite threadlocker,install and let loctite set up 12 hours or so before using,end of issue. |
thechief86 Samba Member
Joined: January 18, 2012 Posts: 860 Location: middle tn
Posted: Wed Feb 29, 2012 9:34 am Post subject: |
| what about running a tap down the hole, and installing a threaded hose barb with loctite? i was thinking this would be a good day-off project.... i DO NOT want my car to catch on fire. |
dan macmillan Samba Member
Joined: October 19, 2003 Posts: 3110 Location: Northern Ontario, Canada
Posted: Wed Feb 29, 2012 10:06 am Post subject: |
Use a 1/8 pipe tap and teflon tape approved for gasoline {the yellow tape not the white one}
I stand corrected, a 1/16 NPT X 1/4 hose barb fitting is the way to go.
Thanks mondshine, I was not aware that they made them that small. _________________ Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone
Last edited by dan macmillan on Wed Feb 29, 2012 1:04 pm; edited 1 time in total |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2818 Location: The World's Motor Capital
Posted: Wed Feb 29, 2012 10:14 am Post subject: |
Thechief-
You are correct. a 1/16 NPT X 1/4 hose barb fitting is the way to go.
Use a brass barb fitting which is 1/16 NPT X 1/4. (1/8 NPT is too big for the carburetor top.)
They are a little hard to find at a hardware store, but a good source for fittings is:
http://fittingsandadapters.com/malpiptap.html
their stock # MPT-4-1 is a 1/16" NPT X 1/4" barb.
If you need a tap, here's a source for that:
http://www.amazon.com/National-Pipe-Taper-Speed-Steel/dp/B000U7LSPO
You won't need to drill the carburetor top to tap the hole; with the brass tube removed, the original drilling is just right.
Something to consider is that the safety wire setup shown in that photo does absolutely nothing to guarantee a seal between the brass tube and the carburetor top. Properly done, the threaded fitting will be a permanent fix. |
Posted: Wed Feb 29, 2012 10:22 am Post subject: |
^^thanks. i have a kickass hardware store right next to where i work. they have everything i need. i had already pulled my stock brass pipe out, scuffed it and reinstalled it with red loctite and a safety wire, but i'm paranoid. i can't afford the weber carb setup i want right now, so i want to be sure i'm not going to lose my car. i just recently had to fix leaky injectors on my jeep a couple of weeks ago, and i had another jeep catch fire because of leaky injectors several years ago. i was able to put it out and get it fixed, but it looks like a bug fire gets way out of hand way fast. this VW is the only car i've ever had that i liked as much as a jeep. i am too attached to let it go out that way.  |
tundrawolf Samba Member
Joined: February 24, 2009 Posts: 1384 Location: RIP Mishomi my friend. I will always love you.
Posted: Wed Feb 29, 2012 11:36 am Post subject: |
| JB weld works for fuel connection. For a while. Never know when it will "stop" working. Wet-Weld (I think that's the name) says it is OK for fuel applications. Neither is good to use on a carb inlet if you want to keep your car from burning to the ground. |
