Super beetle Self adjusting rear brakes
Beata
Beata is offline
PostPosted: Thu Mar 22, 2012 11:02 pm    Post subject: Super beetle Self adjusting rear brakes Reply with quote
I have a 73 super with self adjusting rear drum brakes.
There is an arm that adjusts the brake shoes automatically and I wonder if anyone knows what one should think about when assembling this?
JonF
JonF is offline
PostPosted: Thu Mar 22, 2012 11:33 pm    Post subject: Reply with quote
photos plz!
old vw's did not come stock with self adjusting brakes.
68 bug 1600sp 30/31
68 baja 1600sp 010 32ndix
flierbob
flierbob is offline
PostPosted: Thu Mar 22, 2012 11:53 pm    Post subject: Reply with quote
Is it possible to get self adjusting brakes for the rear on bugs?
Bob
Beata
Beata is offline
PostPosted: Thu Mar 22, 2012 11:57 pm    Post subject: Reply with quote
Look at the illustration below:
I have the second version of brakes.
It is item 32 that I wonder about. How should this be set up?
Perhaps it was only a European or Swedish option but 1303 73 and forward had as far as I know self adjusting rear brakes.
vw_hank
vw_hank is offline
PostPosted: Fri Mar 23, 2012 12:02 am    Post subject: Reply with quote
Not saying thy didn't have them in the US,,, But I have yet to work with/see A set. If the set up works that would be A nice up-grade!!
1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods!
Beata
Beata is offline
PostPosted: Fri Mar 23, 2012 1:15 am    Post subject: Reply with quote
Here is a picture of the brakes in a car (bad picture):
JonF
JonF is offline
PostPosted: Fri Mar 23, 2012 2:31 am    Post subject: Reply with quote
very interesting! looks like it might work off of the hand brake. when you set your hand brake it adjusts the shoes.
is there anything at the bottom of the backing plate where the adjusting stars would normally be located at to keep the shoes in place?
i wonder if this was just an option for sweden or if other countries may of had it also and how rare this is or isnt.
68 bug 1600sp 30/31
Beata
Beata is offline
PostPosted: Fri Mar 23, 2012 2:39 am    Post subject: Reply with quote
There is no lower adjustment. The metal block where the adjuster stars would be has only slots for the brake shoes.
I have read somewhere that it was a legal requirement in Sweden.
The adjuster is pretty thin metal and is bent on my car. It would be great if someone could tell me what to think about when reinstalling the shoes springs adjuster etc.
The springs are quite different to the "normal" version with the adjuster stars.
Joel
Joel is offline
PostPosted: Fri Mar 23, 2012 4:05 am    Post subject: Reply with quote
It was quite common on most cars of the same era, particularly Jap-scrap, I remember my 74 Celica having it and wondering why VWs didn't.
It works of a funky ratchet type setup when the handbrake is operated.
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
Willhelm
Willhelm is offline
PostPosted: Fri Mar 23, 2012 1:21 pm    Post subject: Reply with quote
A "pawl".
The pawl advances the star each time the hand break is cycled through. In theory anyhow. Corrosion from road salt wreaked havoc on that hardware. My 83(?) Dodge Charger 2.2 had the same set up.
torsionbar
torsionbar is offline
PostPosted: Fri Mar 23, 2012 1:35 pm    Post subject: Reply with quote
cool, i've never seen this before. interesting find.
Max Welton wrote:
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed.
Gerrelt
Gerrelt is offline
PostPosted: Fri Mar 23, 2012 2:24 pm    Post subject: Reply with quote
I beleive it's a swedish-thing. For some reason the Swedish beetles had these, from a certain year, standard. Legislation, maybe?
homepage
73 KAFER
73 KAFER is offline
PostPosted: Fri Mar 23, 2012 4:33 pm    Post subject: Reply with quote
I learn something new everyday. Think
Mark
1973 Beetle
#3 http://www.thesamba.com/vw/forum/album_page.php?pic_id=775620Kafer-Cup vintage road racer
Roostalee
Roostalee is offline
PostPosted: Fri Mar 23, 2012 4:36 pm    Post subject: Reply with quote
Wow, those are cool. Maybe it has something to do with trolls. Beata, you do have problems with trolls sabotaging your brakes, right?
Just kidding. My last name is Lundberg, which I hear is pretty common in Sweden. But I wish my last name was Porsche sometimes Wink
Every morning, Greggery drives his little red Volkswagen to the ugly part of town where they keep the government buildings. "Voodn, voodn! Boy it's so hard to find a place to park around here!"
old DKP driver
old DKP driver is offline
PostPosted: Fri Mar 23, 2012 6:43 pm    Post subject: self adjusters Reply with quote
I along with others have put the Vanagon self adjusters on earlier
bays.
I wonder if the setup in the pics are Rabbit/golf parts?
V.W.owner since 1967
vw_hank
vw_hank is offline
PostPosted: Fri Mar 23, 2012 10:22 pm    Post subject: Reply with quote
Porsche would be A good family name,, but cents Im not A Porsche, I'll stick with being A Hirst Wink
1302s sunroof..
Beata
Beata is offline
PostPosted: Sat Mar 24, 2012 1:34 am    Post subject: Reply with quote
Yes Lundberg is a pretty common name in Sweden!
Do yoy have Swedish ancestors perhaps?
I Guess I should look at a rabbit and see if they have thé same setup. My adjuster arm is pretty worn out and should be replaced.
Thanks for thé input!
