presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Wed May 02, 2012 7:59 am Post subject: |
derekdrew wrote: |
The Xantrex regulator you just linked to at http://xantrex.com/power-products/power-accessories/alternator-regulator.aspx looks fantastic. I wonder what the limitation is to "P-type" alternators. If I knew that that regulator would work with my subaru alternator, I'd order it today. Also, there is an odd spec of saying it outputs up to 6 amps. Alternators typically put out 75 to 175 amps. I never wondered to ask what the amp output of my regulator was before (frazzled). |
P-type means the field winding terminal is a positive voltage.
The 6 amp spec is how much field current the regulator can output. Alternators are sort of like amplifiers, a small field current creates a large output current. Regulators work by monitoring the output voltage, and changing the field current to compensate. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
shepherdsond Samba Member
Joined: April 25, 2005 Posts: 439 Location: Bellingham, WA
Posted: Wed May 02, 2012 8:14 am Post subject: |
Quote: |
Would this work instead of replacing the voltage regulator? Its a 12V 3 level charger with 12v DC input that I saw in another thread and thought might serve this purpose:
http://www.powerstream.com/lead-acid-charger-Catalog.htm
I guess at $154 there maybe cheaper options, or maybe not? |
The PST-BC1212-15 DCDC Charger on this site is a 7.5 amp charger so it appears to have higher output than the Xantrex and is quite a bit cheaper (Xantrex is arround $200 or more).. _________________ 87 Syncro Hightop Camper
3 knobs + solid shaft
2.2 Phase II Subaru
Hi-Top build thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=534517 |
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Wed May 02, 2012 8:16 am Post subject: |
derekdrew wrote: |
In looking at the choice of batteries, take a look at the difference between the Group 27 and Group 31 (XT) batteries at Lifeline. If you could fit the 31 the way I did, you would jump up a massive 25% or so in battery capacity (e.g., from 100 to 125 amp hours) and similarly on all the other metrics of battery power. A 25% increase in battery capacity is nothing to sneeze at and makes a little metal trimming seem worthwhile if you have the time, obviously not if you don't. None of the metal trimming you have to do to fit a 31 size shows!!! A separate detailed comparison between the PM-1 and the Lifeline 31XT would be of benefit to decide between the two batteries, but based on a quick scan of the specs, it looks like the Lifeline 31XT has power characteristics that make it look superior for camping, and the PM-1 has power characteristics that make it superior for vehicle starting. If these parameters are true, then the 31XT might be the best battery choice possible for Westfalia under the drivers seat since all of these batteries have enough CCA for the sorts of engines we install anyway. Maybe the PM-1 would be better when you have the stereo cranked up to 10,000 watts while you are winching though. |
The amount of battery capacity needed to crank a TDI with gear-reduction starter is very small - especially since in most all starting scenarios it starts in less that one revolution.
The 27s I already have here - although listed at 13" the case is 12" long, the handles make up the extra inch listed in the specs. 200 a/h will be fine. I can see where you could gain that extra inch with additional cutting, to fit 31s, but worry about tire contact it tight rough turns. Perhaps I will try those in the next project if I can prove to myself that tire rubbing is a non-issue.
Last edited by westyventures on Wed May 02, 2012 8:20 am; edited 1 time in total |
Posted: Wed May 02, 2012 8:19 am Post subject: |
shepherdsond wrote: |
The PST-BC1212-15 DCDC Charger on this site is a 7.5 amp charger so it appears to have higher output than the Xantrex and is quite a bit cheaper (Xantrex is arround $200 or more).. |
The Powerstream units are chargers, not regulators.
I will call my local alternator shop and ask if either Bosch or Subaru alternators are P type. If not, it might be easier to move to a marine type alternator that works perfectly with this type regulator. There is another company that also makes some interesting choices as well as HD alternators:
http://www.balmar.net/regulators.html |
Posted: Wed May 02, 2012 8:39 am Post subject: |
Quote: |
The Powerstream units are chargers, not regulators. |
OK, so what is the difference? The PST-BC1212-15 DCDC Charger takes a 12v (9amp) input and provides a 3 stage charging current (up to 7.5 amps) at voltages higher than 12v (13.8 I think). Isn't that what the Xantrex does? _________________ 87 Syncro Hightop Camper
2.2 Phase II Subaru
derekdrew Samba Member
Joined: October 14, 2007 Posts: 246 Location: Far Northwest CT
Posted: Wed May 02, 2012 8:41 am Post subject: |
There is no tire rubbing to fit the 31 size because the modifications to the battery box take place along the inside edge of the battery box near where people walk from the front of the van to the back between the seats, and these modifications do not require you to make the battery box deeper -- only wider -- in the furtherest possible distance away from the tires. All you do is take some metal out near where the seat belt bolts there near the middle of the van. Also, the metal trimming in that area *does not show*. The purpose of these large batteries is not engine starting, it is for extended run time while camping and using accessories. Otherwise, you might as well use a Group 41 battery. Karl, you absolutely MUST sell your 27 size batteries and switch to 31s. You know you want to don't you. How will you be able to sleep at night otherwise? |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9950 Location: Orbiting San Diego
Posted: Wed May 02, 2012 9:18 am Post subject: |
The Xantrex device under discussion is a modification to the alternator to add an intelligent voltage regulator capability instead of the standard voltage regulator. The output of the alternator is then programmable and adjustable. This is a more efficient charging method and the charge current is then dependent on what the alternator can put out, about 10+ times what the Powerstream 7.5 amp charger can do.
These are primarily intended for Marine type uses, where the engine runs continuously for many hours or even days. The program resets each time the engine is turned off. Then the program begins again when you start the engine. I have to wonder how much benefit this device offers for my driving and camping style.
Mark
OK, so what is the difference? The PST-BC1212-15 DCDC Charger takes a 12v (9amp) input and provides a 3 stage charging current (up to 7.5 amps) at voltages higher than 12v (13.8 I think). Isn't that what the Xantrex does? |
gl98115 Samba Member
Joined: April 22, 2011 Posts: 263 Location: Seattle, WA
Posted: Wed May 02, 2012 9:20 am Post subject: |
Good tips on mounting a PM-1 behind the driver's seat. I have mine in the little cabinet next to the water tank.
Has anyone looked at this ProMariner Digital Mobile Charge130?
http://www.pmariner.com/productFeature.php?ProductNum=05513&page=0
Pricey (~$450 street) but it looks like it will charge an aux battery with full alternator current and a three stage profile.
http://www.3tailer.com/promariner-digital-mobile-c...harger-12v
Question about the Xantrex Alternator Regulator is how to manage two batteries - run it with a Yandina?
Good topic for me as I live in an apt without convenient AC access. _________________ '87 faux-Syncro Westy w/ 2.3l GoWesty WBX
Posted: Wed May 02, 2012 9:24 am Post subject: |
derekdrew wrote: |
Derek, do what makes you happy. I've looked at the battery box modifications extensively before now, and in no way would I wish to compromise the integrity of the seat box structure, seat belt anchoring, or bracing. I saw first-hand how important it is in a head-on accident a customer's van was involved in.
Deeper (or longer, laying the battery on it's side) is the option I chose because I don't desire to have the look of a battery jutting up out of the box. I don't get where the mention of a 'group 41' comes in to this conversation? I've always used 91s anyway, when using std. batteries. 80 a/h, but only starting and light-duty accessory use. I already have two of the best batteries available and 200 a/h of storage. If I desire more in another configuration, I'll go with 260 a/h of storage via 2-6 volt deep cycles under the rear seat - but I doubt I will need more than the 200 however. |
Posted: Wed May 02, 2012 9:33 am Post subject: |
crazyvwvanman wrote: |
The benefit would be proper, full charging and greatly extended lifespan of AGM batteries, at least that's my take from all the reading I've done. |
Posted: Wed May 02, 2012 9:37 am Post subject: |
The question is how long of a charging cycle is needed to get the benefit. I shut my engine off every hour or two. When touring a scenic area I might stop every 15-20 minutes. Might make more sense to hook up to 110 once or twice a week and run a smart charger then. I am asking, not saying.
Mark
westyventures wrote: |
Posted: Wed May 02, 2012 9:41 am Post subject: |
I mentioned it before, but the low-buck solution that I've been using for a few years on my Subaru alternator is to insert a diode into the sense wire for the stock internal regulator. This bumps up the voltage by 0.7V. A couple bucks from Radio Shack and a few minutes to solder it in. _________________ 1986 Vanagon Westfalia EJ25
Posted: Wed May 02, 2012 12:26 pm Post subject: |
OK, here is a Group 31 battery under the drivers seat, snug as a bug in a rug. Actually, for these pictures, the rug covering the battery is not there so you see the battery itself. Normally, the battery will not be visible. Note how the swivel was trimmed so it would not hit the battery as you have got to be comfortable with that trimming off the corner and rear edge. Also, as for weakening the area behind the seat understructure, that only area that has been narrowed is the area underneath the letters 3-09 50131 in the first picture below. But as you can see, the area has not been narrowed by much, and the table post still attaches as it normally would.
You can see some more pictures to go along with these here if you want more: https://picasaweb.google.com/111803335891651546087/BatteryVanagonSyncroGroup31# You might have to monkey with that URL a little.
[img]https://lh3.googleusercontent.com/-f-C5DHGNr8c/T6F_8TpAIkI/AAAAAAAAAKo/PVzy29aWxIo/s800/Spring%25202012%2520Van%2520Photos%2520095.JPG [/img]
[img][/img][img][/img] |
Posted: Wed May 02, 2012 12:58 pm Post subject: |
Well, your idea of 'trimming' and mine are quite a distance apart. I'll just add that I would never offer this solution to a paying customer. If the customer 'had to have' a 31 in there, I'd deepen the box and widen it toward the tire. The RR of the driver's seat box is now weakened as well as the seat belt attachment point and the swivel tracks. Or am I being too critical? (I've been told I can be...) |
insyncro Banned
Posted: Wed May 02, 2012 1:13 pm Post subject: |
Dropped and widened is exactly what I have done.
During a full restoration when the front subframe is removed and all associated parts out of the way the areas are much easily accessed and the modifications can be done with basic bodyshop tools and experience.
A protected channel can be built to connect the two boxes, conduit have you.
Paying attention to the power steering lines, coolant lines and brake lines in that area is recommended. None of the three are stock in my vans any longer. |
Posted: Wed May 02, 2012 2:07 pm Post subject: |
Thinking about stength issues in the event of a catastrophic accident is a good idea. So, for example, if doing a mod like this, don't forget to add reinforcing steel bars/beams/elemnts to places inside the seat support channel that might have got weakened by the mod. That's what we did because we were afraid the seat understructure might be weakened otherwise. Also, be sure to leave the metal structure holding the seat belt bolt in place the way we did or else the seat belt mounting nut structure could be weakened too, a consideration that is correctly raised here by Karl. For some syncros with very large tires, there really isn't enough room to *lower* the battery box unless switching to a narrowish battery becauase otherwise the corner of the battery box will hit larger size tires. So, in my book, look to the inside (toward center of van) area of the battery box for expansion since the outside (toward the wheel) can't really be changed for those of us with large size tires. I wouldn't be surprised if the van that Dylan had with the dropped battery box either had a narrowish battery compared to the one I installed here, or had smaller diameter tires than 30", because otherwise Karl's concern about hitting the tire would become a real limiting factor in how far down the battery box can be dropped. I think it is good to be scared .... ponder things... sleep on them.... problem solve..... so, critical is good in my book and not a bad thing. |
WandS Samba Member
Joined: January 05, 2007 Posts: 228 Location: Miami, Florida
Posted: Wed May 02, 2012 6:53 pm Post subject: |
Karl,
I think i have found my battery. Thanks for letting me us know about the lifeline group 27 that fits in the battery box. I am guessing it should be leaps and bounds better than a typical AGM battery at that cost. Any recommendations for a great charger for this battery? I am ready to purchase my inverter, charger, fuses, wiring etc.
I thought about fabricating the boxes to go deeper, but it don't know how much above 100 a/h that is going to afford me.
Thanks for the great thread guys. This is all just in time. _________________ 85 Westy Weekender with a Bostig Conversion. |
Posted: Wed May 02, 2012 7:28 pm Post subject: |
The 27 and 31 are both the same height, so the box would still need to be deepened (in another thread someone has done this). Otherwise you'll still need to trim a lot, as Derek has, to clear the top of the battery. If you aren't turning the swivel it might be fine having 2" of battery above the top of the box. |
WandS Samba Member
Posted: Wed May 02, 2012 7:49 pm Post subject: |
Darn. For some reason i though you posted that you just had to but the bolts of the terminals. I don't have a swivel seat. Not sure if i want to deepen the box just to close the lid. Will have to take a look at that tomorrow. Sticking up may not be that bad. _________________ 85 Westy Weekender with a Bostig Conversion. |
Posted: Thu May 03, 2012 7:45 am Post subject: |
The reason I used to use the Exide NC-27 is that unlike most other Group 27 batteries, with that particular size of lead-acid battery you don't actually have to trim the entire edge of the seat swivel base in order to fit the battery, and if you want the swivel to work, it will, provided you trim only the *corner* of the seat swivel base. This will be much less dramatic cutting and make you feel better about the strength left. All other Group 27s which were not lead-acid traditional batteries I found (my search was not comprehensive) were too tall for this. I don't think it is a good idea to drop the entire battery box for people who run large size tires (e.g., 30") because otherwise the corner of the battery box will hit the tire more frequently. I am thinking that if Karl is planning to drop his battery box, that he will NOT drop the very end of the battery box that is over near the tire or I see troubles with large size tires. Instead, I'd drop only the 95% of the battery box which is furtherest away from the tire but NOT drop the corner that hits the tire, if you can understand what I am saying about the limitations of dropping. This issue will be eased with a Group 27 battery vs. a Group 31 battery because the Group 27 is narrower. Still, it is possible that if you are going to drop a Group 27 battery box that you will also need to move the Group 27 battery further inbound (toward the middle of the van) because of the need to stay further away from the tire the further you drop. In that event, in an extreme case, you might end up having to make the same cuts for a greatly dropped Group 27 battery that one might have had to make to fit an un-dropped Group 31 battery. Hearing further about what karl has to do to make the Group 27 batteries fit the way he wants to should be spectacularly interesting. The other comments about the wisdom of extending the battery box down and dropping it right down onto the frame are really excellent, and aside from the need to move the battery inbound (or get a narrow battery) there is a possibility that dropping batteries down to the frame could yield even more capacity of a battery than a Group 31. My guess is that such a battery would be a lot taller, but narrower, than a 31 or 27.
In closing, I will here relate an email I got from another vanagonite, which email did not make it into public yet dispite its creativity:
New list topic: How many 31 fit in a van?
Especially a van with the new GoWesty 31 mod. For only 3700 dollars
you can fit 14 additional 31s in this rack conveniently located
underneath the van, and you lose only an insignificant amount of
clearance, and you'll never notice as your van is now too heavy to
actually move.
Order yours today.
Mike
The email above sparked the idea that there could also be a double 31 club ("31/31 Club"), limited to members who have both 31" tall tires and also a Group 31 battery under the drivers seat. |
