RocketSurgeon Samba Member
Joined: May 26, 2005 Posts: 442 Location: Roseville, CA
Posted: Sat May 12, 2012 10:24 pm Post subject: Early bay tach how to (pic heavy) FAQ |
Ok if you feel like having a tach to fill that empty hole, this might be the answer(maybe not, it's not back lit ).
You'll need a few things
Auto zone Sunpro tach (its the cheapest quality tach I could find)
A blank plate
A speedo needle
Those two screws from the speedo
This 4x6 photo printed from your favorite place (I went to Walgreens and got some extras).
So first off disassemble the tach. The face comes off by twisting it with some force counter clockwise and the back is held on by two screws. Now take the needle off. This is a little difficult, you have to sort of rock it and twist but it will come off. Now take the two little screws off for the face and remove the little brace that holds the face, and your left with the guts. Also remove the light, it won't do any good.
Take the blank and with some vice grips or pliers pull off the center nub from the back. You wont need it so just destroy it, no bigie. Now take the blank and set it face down on a flat piece of wood and slowly hammer down the hump with a rubber mallet. You want it flat but it doesn't need to be perfect.
Next take the guts and line up the hole wih the needle shaft then mark and drill the holes. I went with an angle so the ring screws wouldn't ground out on the guts. ( please disregard all the other holes, I was trying to make it back lit. It didn't pan out. Also the holes for the ring are drilled in this pic also)
Now take the ring and just eyeball the holes for the screws( if you want to be anal measure the screws on the idiot light pod) and transfer those holes to the blank. I over sized them on the blank and just used hot glue to secure them on the back
Now screw the guts to the blank and trim the back cover of the tach as much as you want( I went way too far) and screw it back on.
Now you might want a circle cutter for the face, I picked one up at a craft store for about $8. Practice a couple times to get the size just right, then cut the real one, test fit it , add the small hole for needle ,square it up in the blank and attach the ring with the screws (hot glue). As you can tell the face has been updated throughout the build, but I think my final came out flawless. Unfortunately for me I used one of the beta versions for my face. Feel free to edit or modify it. The color is close (real close) but not exact.
Don't put the needle on just yet. You need to calibrate it. I've got a tach/dwell meter( so should you) so I just hooked them both up on an idling motor and matched the meter. Make sure the tach is set to 4 cyl. Test it a bit by reving the engine a little and you should be good
A note on my needle... The damn thing is fragile! I broke it. but I had a cabriolet speedo needle that I was able to repair it with. So just a warning it's probably going to break. Also the face might fade, mine hasn't in the few weeks it's been in there, but it probably will eventually.
And that's it hook that puppy up and enjoy the uniformity of it all!
_________________ 69 Westy |
Philo Beddoe Samba Member
Posted: Sat May 12, 2012 10:32 pm Post subject: Re: Early bay tach how to (pic heavy) |
 _________________ '56 T-1
'64 T-2 |
odecom5 Samba Member
Posted: Sun May 13, 2012 6:47 am Post subject: |
Great tutorial. Thanks!
Although the RPM is x100 in the one you printed (I see your template is now fixed though), hope it doesn't drive you mad, because it would me!
I never thought about doing it this way. I have a 3" tach that fits perfectly in the hole, just had to make a mounting bracket for it, works good, but I might steal this face and swap that out.
Thanks again. |
donemoto Samba Member
Posted: Sun May 13, 2012 7:22 am Post subject: |
What is the wire hook-up for the tach? i.e. what wire goes where? _________________ 1975 Campmobile
1962 Bug Convertible
Homebuilt VW Trike
1966 HD Sprint H
1940 HD ULH Flathead
1985 Electra-glide Classic with Tour-Pac
1968 Harley Rapido
1968 Honda CL Scrambler 175cc
1962 Honda Cub 50 Step-thru
1980 Honda Cub 70 |
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1558 Location: orlando
Posted: Sun May 13, 2012 7:33 am Post subject: |
| odecom5 wrote: |
Thanks again. |
It does drive me nuts, bu I was itching to get it in. I also flipped the 7 and 8. _________________ 69 Westy |
Posted: Sun May 13, 2012 7:36 am Post subject: |
| donemoto wrote: |
| What is the wire hook-up for the tach? i.e. what wire goes where? |
Black neg
Red switched power
Green to dizzy
White dash lights _________________ 69 Westy |
markd89 Samba Member
Joined: November 04, 2005 Posts: 682 Location: Los Angeles
Posted: Sun May 13, 2012 8:25 am Post subject: |
| Awesome result. Thanks for making the write-up! |
WestyMan1971 Samba Member
Joined: March 27, 2008 Posts: 693 Location: The Granite State
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Sun May 13, 2012 1:56 pm Post subject: |
Green actually goes to the negative side of the coil...to make life easier.  _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sun May 13, 2012 5:16 pm Post subject: |
| bugger101 wrote: |
| has now been added to the FAQ |
Awesome! _________________ 69 Westy |
Posted: Sun May 13, 2012 6:41 pm Post subject: |
| Stuartzickefoose wrote: |
Green actually goes to the negative side of the coil...to make life easier.  |
thanx _________________ 1975 Campmobile
Homebuilt VW Trike
1966 HD Sprint H
1968 Harley Rapido
1980 Honda Cub 70 |
Jody '71 Samba Member
Joined: July 16, 2005 Posts: 2842 Location: Manassas VA
Posted: Mon May 14, 2012 6:50 am Post subject: |
The Sunpro Super Tach II's are great. I had one in my old '85 Cherokee for years. It never flawed. Unlike the VDO tachs that are out there now and have been so damned problematic during various production runs. If I ever decide to put a tach in my Bus it will be a Sunpro for sure. Oh and Stuart, you get another  _________________ '66 Beetle
2011 Hyundai Elantra Touring |
Posted: Mon May 14, 2012 11:21 am Post subject: |
2 points!  _________________ Stuart Zickefoose
206-841-7324
[email protected] |
hippyvanman Samba Member
Joined: June 10, 2011 Posts: 126 Location: Raleigh, NC
Posted: Sun Dec 30, 2012 5:11 pm Post subject: |
WOW. Great writeup!! I have 1 question though:
- did you have to shorten the needle at all to make it fit the smaller gauge size? _________________ 2.0L FI 76 Bay "Sunshine" |
Posted: Sun Dec 30, 2012 10:17 pm Post subject: |
| hippyvanman wrote: |
- did you have to shorten the needle at all to make it fit the smaller gauge size? |
The original speedo needle broke but it would have needed to be trimed if it didn't. The replacement needle from a cabriolet tach was just right.
A little update; the photo face is fading and starting to curl. Soon I'll be replacing it with some sort of bumper sticker print on thin plastic. Haven't settled on it yet. _________________ 69 Westy |
obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 3037 Location: Commack, NY
Posted: Sun Dec 30, 2012 10:28 pm Post subject: |
You should look to have it printed on UV resistant vinyl. When you do, have them leave extra material around the edges, if its a 3" diameter, have them leave 1/4" extra or so. That way you can gently pull it taught, and when you screw the assembly together there is material that can grab to keep it from pulling back in time.
Jus an idea. _________________ Mike
1964 Beetle
2001 Eurovan Camper |
Posted: Sat Jan 05, 2013 2:10 pm Post subject: |
Oh, and one more. In the picture of the finished product in the gauge cluster, it looks like you added some sort of glass in front to make it look like the rest, how did you do That? _________________ 2.0L FI 76 Bay "Sunshine" |
chrisradioman Samba Member
Joined: September 20, 2007 Posts: 4872 Location: Swansea (Sunny Penllergaer) Wales UK
