grandpa pete Samba Member
Jalabert Samba Member
Joined: December 06, 2005 Posts: 633 Location: On the coast in NZ, somewhere...
Posted: Sat Apr 12, 2014 11:19 pm Post subject: |
Tom Powell wrote: |
engine dolly
Aloha
tp |
That looks like it'll work a treat in my garage Tom, thanks for the inspiration... _________________ http://thickrubber.blogspot.com/ Writing, Surfing, and Exploring NZ's deep south by VW...
'73 westy, 1700 type 4 with 34icts |
p.e.i.vw Samba Member
Joined: February 18, 2005 Posts: 144 Location: Edmonton Alberta
Posted: Thu Nov 20, 2014 5:36 pm Post subject: |
Has anyone else seen or used the Triple Lift garage jack that's available at a number of automotive stores? |
Brian Samba Moderator
Posted: Thu Nov 20, 2014 6:52 pm Post subject: |
That's the one yep. |
oscarsnapkin Samba Member
Joined: October 22, 2013 Posts: 558 Location: Bucks County, PA
Posted: Mon Nov 24, 2014 2:19 am Post subject: |
homedepot.com has it cheaper than Amazon. $129.99. I just bought a motorcycle/ATV jack, but I'm thinking I'd rather have that hydraulic cart from Harbor Freight. It would be much easier to load an engine on/off a pickup truck or onto a stand since it has a much higher maximum height. _________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind." |
billfred1 Samba Member
Joined: May 19, 2014 Posts: 287 Location: Bloomington, IN
Posted: Mon Dec 22, 2014 12:35 pm Post subject: |
Great. Thanks so much. This will be the 3rd time pulling my engine in the past 6 months (I like to tinker ). I've got the HF lift on order. This wood plate definitely makes sense.
Thanks for the great info. _________________ Bill
1966 Beetle |
Posted: Sun Jan 04, 2015 6:39 pm Post subject: |
Just used the atv jack for pulling and installing engine on my type 1. Nice. I also made a wood plate adapter similar to GP. THANKS. _________________ Bill
1966 Beetle |
cn63bug Samba Member
Joined: August 19, 2011 Posts: 114 Location: Mt. Juliet, TN
Posted: Fri Sep 25, 2015 1:31 pm Post subject: |
Awesome idea grandpa! I'm going to do this as well. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1745 Location: Mouth of the Columbia
Posted: Sat Oct 17, 2015 4:32 pm Post subject: |
I have used that jack to remove my T-4 but it doesn't go high enough or low enough. If I use my ramps to raise the bus up enough to get the engine out under the apron, the jack won't reach high enough to support the engine and if I use a plate like yours the engine won't go low enough to clear the apron. I end up raising the bus up just enough so the jack and plate supports the engine, disconnect everything, then when the engine is lowered I have to jack up the bus so the engine clears the apron. It's only a difference of about an inch. Might as well be a foot. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3855 Location: San Jose, CA
Posted: Sat Oct 17, 2015 5:51 pm Post subject: |
Lil' Lulu wrote: |
I have used that jack to remove my T-4 but it doesn't go high enough or low enough. |
Which jack? The one just linked from HF? Or any ol' MC/ATV jack as is being discussed here?
I'm planning to get one for my upcoming T-IV pull, but I do understand your dilemma...I've run into that in the past with Beetle engines. But it surprises me, because the T-IV engine seems so low-profile, I would've thought it'd be a slam dunk. But perhaps not.
Thanks.
(BTW, it's that on sale/sale one at HF I was thinking of getting.) |
KTPhil Samba Member
Posted: Sat Oct 17, 2015 6:15 pm Post subject: |
I just made up the wooden adapter described above. Putting a varnish over it now.
The latest jack from HF had its bolts a little closer together, which would make the underside pieces a little shorter to fit between the bolts. Also, I only used one layer of 1x2 on the bottom; I think it will hold it from sliding with just the one. With just one mine can slide front to back; we'll see if that's a problem or a handy feature. If it is a problem, I can add a couple of blocks to hold it.
There is a round rod cross piece (side to side) between the beams those bolts attach to, and two layers would interfere with it, though a notch could be cut. Once you look at it, you'll see how long to cut those pieces.
It will be many weeks before I put my motor in with it, but I know it's a much safer procedure, especially with just one person. Less chance of damaging anything, too. On my Type 3 FI motor, there is precious little room in any direction, and my old method of using a single floor jack left it wobbling and required more back strength than I now want to invest in the operation!
Posted: Sat Oct 17, 2015 6:33 pm Post subject: |
Busstom- The jack I have is the earlier version of the HF jack. Not really any different though. I could remove the carbs and gain a little bit of room getting it out but it's the oil filler that causes some of the problem. I remove the engine and trans as a unit. As I remember the travel is only 18". Any floor jack will be about the same. Believe the T-1 motor would be easier since the apron is removable.
I also have run onto this with my '65 bug. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1399 Location: Cambridge, MA
Posted: Sat Oct 17, 2015 6:50 pm Post subject: |
I use Harbor Freight 3 ton jack with their $40 support beam. A block of wood on the center of the jack takes most of the engine load, and the support beams keep if from tipping left or right. It can still rock forwards and backwards but it balances pretty well. Once it's down another block of wood on the body of the jack makes a very stable platform. With this setup and a cheapie 2 ton jack I was able to pull the engine and tranny together by myself without any hassle at all.
_________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
62 Dave Samba Member
Posted: Mon Mar 25, 2024 8:53 pm Post subject: Re: ATV / MOTORCYCLE jack adapter to remove VW engines;update |
Reviving this old post to give a big kudo to Grandpa Pete for the platform design. I bought a HF lift and made a platform per his design and it worked awesomely.
Thanks!!
This forum rocks. _________________ Dave
62 Type 1 sunroof
64 Ghia hardtop
69 Type 1, 68 Type 1, 73 914 2.0, 76 911S Targa....all gone but not forgotten |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16976 Location: San Diego, California
Posted: Mon Mar 25, 2024 9:53 pm Post subject: Re: ATV / MOTORCYCLE jack adapter to remove VW engines;update |
I had lunch with him once. Great guy _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Abscate Samba Member
Joined: October 05, 2014 Posts: 22679 Location: NYC/Upstate/ROW
Posted: Tue Mar 26, 2024 4:41 am Post subject: Re: ATV / MOTORCYCLE jack adapter to remove VW engines;update |
We haven’t heard from GrandpaPete in 4 years, I hope he at peace wherever he is. His work will carryon for eternity thanks to his contribution here. _________________ .ssS! |
KTPhil Samba Member
Posted: Tue Mar 26, 2024 9:14 am Post subject: Re: ATV / MOTORCYCLE jack adapter to remove VW engines;update |
I agree. The back pain he has spared me with that design is enormous! I have used it on my Fastback and recently my Bus. R&R went so much easier and safer! BRAVO!!
My only mod is that the clever height/cant adjustment gets in the way of my muffler and/or carrier, so I may replace it with a fixed pitch wedge that suits the particulars of my engine and driveway slope.
_________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
