Racerrojo Samba Member
Joined: August 01, 2006 Posts: 827 Location: ALBUQUERQUE 87120
Posted: Mon Jun 25, 2012 6:41 pm Post subject: Passat Cluster in a Vanagon! |
I found this by accident
Would love to find instructions on this mod _________________ Tight is tight... too tight is expensive!!!!
Too many vans and mostly all projects  |
BCWesty Samba Member
Joined: September 06, 2008 Posts: 165 Location: victoria
Posted: Mon Jun 25, 2012 6:54 pm Post subject: |
| Looks like the column stalks are different too. Looks good |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1945 Location: Sidney B.C. Canada
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Mon Jun 25, 2012 8:30 pm Post subject: |
| I like it! |
Posted: Mon Jun 25, 2012 8:36 pm Post subject: |
That's really cool, I wonder if it can be done with a subaru engine instead _________________ Tight is tight... too tight is expensive!!!!
NZer Samba Member
Joined: January 17, 2012 Posts: 87 Location: South Western Ohio
Posted: Mon Jun 25, 2012 8:45 pm Post subject: |
| Racerrojo wrote: |
That's really cool, I wonder if it can be done with a subaru engine instead |
That was my thoughts too! _________________ A sad looking 88 Westfalia, MT 2.1 with 150k on the clock and several issues! |
andymcc1 Samba Member
Posted: Wed May 15, 2013 8:22 am Post subject: |
Just came across this whilst Googling for 'Subaru cluster in Vanagon'.. anyhoo, I shot that video in the first post !
Thought people might be interested to hear of my progress since last year. I run two T3 Syncro's one with an AFN TDI, the other with a 2000my EJ25. My intention is to get the Passat instrument cluster working in both vans. It's been the TDI van though where I've done my development and prototyping.
I'm currently working on a kit which folk can use to fit the Passat cluster, though to use it does depend on some other work, mainly moving the lighting switches. An electric speed sender is needed, and most folk will need a pulse converter box (eg. Dakota SGI5) to get the speedo reading right.
For those wanting to keep the stock lighting switches, it may be possible to do a hybrid setup, by chopping out the central part of a T3 cluster, and using the central part of my metal bracket to mount the Passat cluster.
The kit will mainly be of benefit to those who've fitted a later VAG engine, either petrol or diesel, as it will work well with a later ECU, and has IMMO2 capability built-in. Many of these clusters have MFA capability as well, and to use this the correct stalks are needed. I used early T4 stalks, which involved swapping the ignition lock housing to a CE2 one. I also used a CE2 main lighting switch, thanks to an old post on the samba IIRC.
The kit is still in development, right now I'm waiting for the final version of the main housing and a polycarbonate window to come back from my water-jet cutting place.
Here's a couple of pics, should be self-explanatory but happy to answer any questions, replies may not be instant though as I don't use the samba that much.
'90 252 EJ25
'90 246 AFN
AFN TDI Build Thread
tam_shops Samba Member
Joined: November 15, 2012 Posts: 1531 Location: Vancouver BC
Posted: Wed May 15, 2013 8:44 am Post subject: |
Love it! Want it! It'll cost me! LOL
Wonder if the Passat can fix that stupid heater control too!? Hate that even more!
tam _________________ 1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885 |
Posted: Wed May 15, 2013 8:56 am Post subject: |
Hi Tam,
Thanks ! Funny you should mention the heater controls, I'm not a fan either.. The later South African vans have rotary controls more like a modern vehicle, possibly they could be transplanted. I don't know though, if the heater unit itself is different, and of course getting SA part in Europe or the US for that matter probably ain't going to be easy.
'90 252 EJ25
'90 246 AFN
AFN TDI Build Thread |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1125 Location: over by 'der
Posted: Wed May 15, 2013 4:33 pm Post subject: |
we need to dig further for this passat cluster mod. i wonder if it would work with a stock wbx. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2734 Location: East Nassau, NY
Posted: Tue Jul 15, 2014 4:12 am Post subject: |
I am having trouble getting the fuel gauge to work right with my Passat dash cluster.
It want's to read backwards- the lower the fuel level, the higher the gauge reads. I know I could probably pull the sending unit out of the tank and reverse the way the sweeper runs across the resistor. This is in a Syncro so I'd prefer to leave the sending unit be.
Does anyone know of an electronic device that I could use that will allow me to take the variable input from my sending unit and send out a different output to the gauge?
Any other thoughts on how to fix it?
Andrew- |
BenT Syncro Samba Member
Joined: January 07, 2005 Posts: 1088 Location: San Francisco
Posted: Tue Jul 15, 2014 4:37 am Post subject: |
| andymcc1 wrote: |
Hi Tam,
'90 252 EJ25
'90 246 AFN
Have thought about doing that except the SA vans are RHD and controls are in a different spot relative to where our LHD vans have out cables. I've played with Golf/Jetta Mk3 & Passat B3/B4 controls. Looks possible. The main impediment are the cable ends which need to be round loop rather than the dogleg ends on the Vanagon. Tried unsuccessfully to reshape the ends. They are made of high tension steel like that used on springs. I didn't have the right tools. Maybe heat can work. _________________ BenT |
Posted: Thu Jul 17, 2014 2:17 am Post subject: |
| xoo00oox wrote: |
Hi Andrew, the way I do it is by modifying the dash panel EPROM, this can be done via K-line without hardware changes. There are several lookup tables that control the needle sweep. _________________ '90 252 EJ25
'90 246 AFN
Syncrosport
Volkswagen Transporter, reloaded. |
Posted: Thu Jul 17, 2014 4:47 am Post subject: |
| andymcc1 wrote: |
| xoo00oox wrote: |
Hi Andrew, the way I do it is by modifying the dash panel EPROM, this can be done via K-line without hardware changes. There are several lookup tables that control the needle sweep. |
Interesting. Thanks for chiming in here Andymcc1.
If you look close at my pictures, you will notice that I switched clusters from a b5.5 to a earlier B5 one. I did this because I realized that the later ones used CAN to give a RPM signal input and I couldn't get the tach to work. Also, the B5 cluster has MFI and I would like to use that as well.
I know the EPROM can be modified on the B5.5 one, but can it on the B5 cluster?
Andrew- |
Posted: Fri Jul 18, 2014 3:34 pm Post subject: |
| xoo00oox wrote: |
Andrew- |
I interpret B5 as 3B is that right ? They started off in 97 and dash panels #'s 3Bn 919 nnn. Sure they're very similar, the later version have a larger EEPROM but the tables work the same, just at different memory addresses.
For me the biggest problem with the 920 parts is the red pixel displays which often have gone bad.
PS. Re. CANBUS I don't know if the same with petrols, but with the TDI there are sometimes versions of the ECU that are pin-compatible but with CANBUS added, so if swapping to a CAN cluster you can just add the wires to the ECU plug and harness and away you go. eg. on the 3B 82kW TDI the 'P' suffix is typical but was replaced in May 99 with 'GA' suffix with the CANBUS wires added. _________________ '90 252 EJ25
'90 246 AFN
Syncrosport
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12177 Location: Port Manteau
Posted: Fri Jul 18, 2014 3:44 pm Post subject: |
I know I've asked a similar question elsewhere, but has anyone running an mTDI installed one of these clusters, thereby bypassing ECU inputs? I gather the tach signal will take some futzing about, but are there any other concerns with getting all the functions to operate? I have a Mk4 cluster, fuel level potentiometer, VSS, as well as the engine sensors. I also have a Dakota Digital converter for the speedo _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
Posted: Fri Jul 18, 2014 3:52 pm Post subject: |
| Zeitgeist 13 wrote: |
| I know I've asked a similar question elsewhere, but has anyone running an mTDI installed one of these clusters, thereby bypassing ECU inputs? I gather the tach signal will take some futzing about, but are there any other concerns with getting all the functions to operate? I have a Mk4 cluster, fuel level potentiometer, VSS, as well as the engine sensors. I also have a Dakota Digital converter for the speedo |
But surely those with an mTDI would prefer the nice simple mechanical speedo ?  _________________ '90 252 EJ25
'90 246 AFN
Syncrosport
Posted: Fri Jul 18, 2014 4:00 pm Post subject: |
No, I like electronic speedos, which allow you to dial in the proper ratio for whatever tire diameter you're running. I do this with MBs, as well, even though I run converted mIDI engines in those. _________________ Casey--
'89 Bluestar ALH
NEAT, no ICE. |
Posted: Fri Jul 18, 2014 5:29 pm Post subject: |
Yes, that description sounds correct.
I am able to pull the bin file, can you help with what needs to be changed to what?
Did you ever come up with a kit to use these clusters? |
Posted: Sat Jul 19, 2014 1:43 am Post subject: |
| xoo00oox wrote: |
I am able to pull the bin file, can you help with what needs to be changed to what? Did you ever come up with a kit to use these clusters? |
Ah, well.. the kit is still 'in progress'.. Regarding the EPROM changes, once I'd got some basic info from TDIclub and elsewhere I invested a lot of time in developing the changes needed for use with the T3/Vanagon. This represents a chunk of the IP in my dash adapter kit, so no I'm not going to give that away, sorry. There's nothing to stop others doing what I did though. _________________ '90 252 EJ25
'90 246 AFN
Syncrosport
