jerome burley Samba Member
Joined: July 21, 2012 Posts: 10 Location: hailey, idaho
Posted: Sat Jul 21, 2012 9:44 am Post subject: 91 Westy/intermittent high idle/hot start problems.... |
Hello new friends,
My name is Jerome and I am new to this forum, but not new to VW's. I have had my 91 "weekender" since 96.
Over the years, the van will start idling high after warm. If I turn her off during this, she will not start. Appears flooded. Wait min of 20 minutes, foot to the floor, and she catches. Some fuel smell, some smoke, and runs fine untill the next time. She is stock. The van will purr and run perfect, and then this happens. She sits most of the cold winters here, but I at least start her up and keep the battery up.
I have changed plugs, wires, rotor cap. Have cleaned the grounds, but not for a few years. Am going out to do this now.
I found this site and hope someone else has found a remedy to this problem.
I keep reading about a "temp sensor" but it appears I do not have one. It is not a syncro. Thanks in advance for any enlightenment on this subject.
Nice being here, Jerome  |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10209 Location: Mt Lemmon, AZ
Posted: Sat Jul 21, 2012 10:47 am Post subject: |
Thank you Ahwahnee!  |
Posted: Sun Jul 29, 2012 9:02 pm Post subject: |
Just a follow up on my first thread.
Changed out the coolant temp sensor on my 91, and on the same day cleaned all the grounds to shining I could find. (Connectors looked sound so I left them)
Results: Seems to run smoother, idle better than I can remember for many moons.
Went camping this weekend, very hot in the 90's and she started every time, first time, and continues to run smooth. Definately the scenario in which I have been having start issues.
So far soooo good.
I am grateful for this forum, and thanks to all those past and present that helped!
Hope this helps someone else as well..... |
