sullydog93 Samba Member
Posted: Thu Aug 02, 2012 3:30 pm Post subject: Toyota 94 pistons - Hot VW article |
Is it worth the trouble, probable high cost? |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Thu Aug 02, 2012 7:59 pm Post subject: |
An air cooled piston has different metallurgy, expansion characteristics and dimensions than a water cooled piston...................................then again, maybe Gene Berg was wrong. _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
Fiatdude Samba Member
Joined: April 20, 2009 Posts: 1218 Location: now in MO.
Posted: Thu Aug 02, 2012 8:17 pm Post subject: |
I have aftermarket chevy pistons in mine --- no problems |
Hotrodvw Samba Member
Posted: Thu Aug 02, 2012 10:35 pm Post subject: |
I think it's a cool idea, but as the article states, you have to modify them a bit. I'd try it someday! _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
SRP1 Samba Member
Posted: Thu Aug 02, 2012 11:29 pm Post subject: |
DarthWeber wrote: |
An air cooled piston has different metallurgy, expansion characteristics and dimensions than a water cooled piston...................................then again, maybe Gene Berg was wrong. |
Nonsense, they run the same clearances, same material, same expansion rates.
That piston FYI is dirt cheap, made and sold in the after market by NPR of Japan
Same old NPR that sold VW P&C kits back in the 80's. But that dish is a POS! Even machined down it's no good in an air cooled unless it's gone and that can't happen, not enough material there.
I'n working on another piston at the moment from another engine, it's a forged 94mm
Mahle with teflon coated skirts. Pretty much the same thing everyone is used to seeing.
Would be considered a B piston and is a flat top with 4 small valve reliefs (not that it matters in a VW)
I'll have more details to post up at the later end of next week if it looks like a viable candidate, and the parts source shows their readily available. |
mark tucker Samba Member
Posted: Thu Aug 02, 2012 11:47 pm Post subject: |
ya Ive been looking at that piston too.and thinking about a 4 or 5 valve set of heads to go with it.
there is no mettelergy to it,just about everybody has a different mix,(alloy)it depends on how you set it up and what the cylinder does.the piston dont know or care WTF it is in. I thought about putting a set of my je 4 1/2"bore pistons in one of my scrap motors just fer the hell of it.might have to split a set of heads to do it, but thats not an issue. |
luckystiff Samba Member
Joined: September 28, 2005 Posts: 2252 Location: hickory,nc
Posted: Fri Aug 03, 2012 7:45 am Post subject: |
there's also the Icon 92mm toyota pistons. forged, no valve reliefs, basiclly C pin height, and fairly reasonable priced. combined with a set of AA thickwall cylinders another very viable option...ken... _________________ ITMC
Secret Service |
ralf Samba Member
Posted: Fri Aug 03, 2012 8:58 am Post subject: |
luckystiff wrote: |
there's also the Icon 92mm toyota pistons. forged, no valve reliefs, basiclly C pin height, and fairly reasonable priced. combined with a set of AA thickwall cylinders another very viable option...ken... |
true and i think they do have A height equivalents too?
one of the reason why i orderd a set of AA thickwalls..
u never know when you'd
need em ' _________________ Flow Through a Curved Conduit
porting my SP head for my brother's project
https://youtu.be/OS_mVjQuqgk |
Posted: Fri Aug 03, 2012 9:05 am Post subject: |
luckystiff wrote: |
I havent seen the icons, hows the forging?light or what?slipper? |
tmcdade Samba Member
Posted: Fri Aug 03, 2012 10:07 am Post subject: |
mark tucker wrote: |
luckystiff wrote: |
http://www.kb-silvolite.com/icon/icon.php?action=details&P_id=616
I was looking for a set of forged 88's, and found quite a few with .866"/22mm pins - the hard part is finding them without 4 deep valve reliefs or huge dish. If I could've found some without those 2 issues, I would've ran them. I didn't see that HVW issue, but I say go for it _________________ Travis
1972 Super Beetle
1907cc |
Posted: Fri Aug 03, 2012 3:15 pm Post subject: |
looks like a nice piece.my hyd roller cam motor was going to be a small motor(around 2000cc), but things change.I wonder how thick the dome is?it states it is for boosted apps, so it may have some extra under there along with being made right for the app. |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Fri Aug 03, 2012 8:37 pm Post subject: |
SRP1 wrote: |
DarthWeber wrote: |
Nonsense...anything that runs hotter is going to have different expansion characteristics. Lesson learned years ago in Metallurgy 101. Watercooled vehicles won't see the temps that air-cooled vehicles see. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Fri Aug 03, 2012 9:09 pm Post subject: |
That is true -- BUT aircooled engines run completely different tolerances than water cooled --- It is also true there is a completely different set of op temps in a boost engine vs. an NA engine -- -- if you setup a piston to wall clearance for the application you will enjoy success |
Lobotomy Samba Member
Joined: May 30, 2010 Posts: 517 Location: Traverse City, MI
Posted: Thu Sep 13, 2012 10:32 am Post subject: |
Bump. So who here has done this? I read the article, and now I'm really interested in piston alternatives for many reasons beyond them simply being cheaper. I wouldn't really use Toyota 94s in a 1915, due to the high RPMs that it can potentially put out, thus ruining the cast pistons, but what about a Toyota 92mm option for a 2180? You probably wouldn't go over 8k in a well built 2180, so cast pistons are a more viable option. How much machining needs to be done, and where? What cars do the 92s and 94s come out of?
I'm no tuning wizard, but my only fear is that the pistons may expand more than aircooled pistons, in theory, increasing friction, heat and damaging internals faster, but then again, I know dick about this kind of thing, so I'll let you magic men figure it out. _________________ Vehicles I have:
1974 Super Beetle "Reginald"
1983 AM General DJ-5
1958 Honda c-100 |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Thu Sep 13, 2012 5:50 pm Post subject: pistons |
[quote="SRP1"]
DarthWeber wrote: |
Nonsense, they run the same clearances, same material, same expansion rates.quote]
Then why do Wiseco's require extra skirt clearance? I see they have gained the nickname: "Seizeco"... _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1783 Location: Boise, Idaho
Posted: Thu Sep 13, 2012 5:59 pm Post subject: Re: pistons |
[quote="neil68"]
SRP1 wrote: |
DarthWeber wrote: |
Then why do Wiseco's require extra skirt clearance? I see they have gained the nickname: "Seizeco"... |
It is a matter of being cast vs forged. Forged pistons expand more so they need more clearance. |
Posted: Thu Sep 13, 2012 8:08 pm Post subject: |
nonsence, not because there forged,in reality they run cooler with less hot spots,but some have an isolation slot and some have holes in the oil ring slot.and there are may different types of aluminum, je had a higher silocon content than sieezco's, & Ive seen a lot more wizassco pistons with broken ring lands too. different pistons take different clearances in iferent applications. a car(wattercooler) bored & honed corectly can work at .0015 with some pistons, now the exzact same motor in a boat will seezzee in a hurry. why??? because the pistons run the same temp in both motors. but the cylinders in the boat have a big supply of nice cool water to keep them cool cool is small, so the piston expands as normal but cylinders dont so they grab each other.,but bearing clearances are about (some .001 more on a boat.)the same as they have hot oil keeping all at the same temp. but there isant a "special"piston for any of it aircooled watter cooled what ever the piston dont care it is going to run about the same temp for it's material(cast or forged, then there is the hyperutectic witch run even hotter) the piston dosent know or care what it is in. |
AlteWagen Troll
Posted: Fri Sep 14, 2012 9:01 am Post subject: |
[quote="SRP1"]
DarthWeber wrote: |
Any word? |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3467 Location: San Diego
Posted: Fri Sep 14, 2012 2:36 pm Post subject: |
The word is... nonsense |
modok Samba Member
Joined: October 30, 2009 Posts: 26822 Location: Colorado Springs
Posted: Fri Sep 14, 2012 5:48 pm Post subject: |
I think he is looking at a subaru piston probably
The subi piston is very short skirt, the pin is 1mm bigger
the aircooled piston probably does run a bit hotter than some other engines, but not anything that a little extra clearance won't make up for |
